Strange moving object in Dolphin Head Nebula data
2 replies175 views
Ryan Benbow avatar
Hi All,
I was just going through some recent data I have acquired on the Dolphin Head Nebula (Sh2-308), and while blinking through the data I noticed this weird spot that kept bouncing erratically around in my subs.
It shows up in slightly different spots in each of my 5 min sub exposures in both my Ha and Oiii data. I captured the data on the 29 and 30th of Dec, I also went back through some data from last year and could not see it present in the older subs.
My setup is
William Optics FLT120
AM5N mount
asi2600mm Pro
Antlia 3NM filters
I was hoping if anyone could shed some light on what this may be?
bigCatAstro avatar
Ryan Benbow · Dec 30, 2025 at 09:35 PM
Hi All,
My setup is
AM5N mount
asi2600mm Pro
Antlia 3NM filters
The first thing to analyze and rule out is some sort of internal reflection—off of the corrector or filters. That’s where I’d start off first.
There’s a bright star on the middle left of your frame that is drifting in and out of your subs. The object seems to be moving in a similar pattern with the drift of that star in the frame.
Ryan Benbow avatar
Thanks BigCatAstro,
Yeah , I think your right. Slowing it down and looking at it more closely frame by frame, it consistently matches the relative movement of the bright star Udra (cropped out of frame of the gif)
Thanks for your help.
Can anyone explain what I am seeing?
I noticed some bright green spots about the size of a star in my most recent image. The spots were in a cluster in a single area in the image. After looking at the subs, I saw a cluster of pixels that move around as I blinked through the registered s...
Moving pixel clusters in registered subs match your observation pattern.
Mar 29, 2025
Strange persistent structure/artifact in old (2025) subs — what could it be?
Hi everyone, Quick (and kind of funny) question. I revisited some March 2025 data of the Dolphin Head Nebula—only 13 × 180s frames. A few days ago I resumed the project and decided to register/align those 2025 subs to my new 2026 data so I could comp...
Discusses similar artifact issues in Dolphin Head Nebula data from different timeframe.
Jan 24, 2026
An Asteroid...Apparently
Hey All, I was imaging LDN 1584 last month when I noticed some aberrant small streaks in the stacked results over 2 nights. The position of the streak had changed from one night to the next so I blinked through the individual subs and saw what looked...
Similar experience detecting moving objects in astrophotography data through blinking technique.
Jan 22, 2026
