How dark is really the dark DSO background?
12 replies•398 views
Rainer Ehlert avatar
Somewhere in the Internet I read the darkness of the DSO background is 27.42 mag per square arcsecond.
What would that be in RGB values ? šŸ¤” I always try to get my background between 10,10,10 and 20,20,20 …
Āæ?
Ruediger avatar
Hello,
My two cents…
I would deflect this discussion a bit. What I do not unterstand about the background ā€œblacknessā€ discussion is:
Gradients, mist, clouds… every thing what we consider ā€œnoiseā€ resp. ā€œlight pollutionā€ from the sky, we try to filter out and remove it in post processing. BUT: Sky glow we keep and say ā€œoh well, the background of DSO images should not be pitch blackā€. To be honest, I have never understood this argument, because space is physically pitch black! I know, some photons roam around due to straying, but they are actually neglectable). Everything what emits photons, we try to image: Nebula, galaxies, stars… but why suddenly empty space emits photons?
The only argument is pure esthetics, since pitch black background looks strange. And hence, the OP’s question can be answered in this way from my point of few: How you like it!
Rüdiger
Ruediger Ā· Dec 30, 2025, 08:43 PM
Hello,
My two cents…
Gradients, mist, clouds… every thing what we consider ā€œnoiseā€ resp. ā€œlight pollutionā€ from the sky, we try to filter out and remove it in post processing. BUT: Sky glow we keep and say ā€œoh well, the background of DSO images should not be pitch blackā€. To be honest, I have never understood this argument, because space is physically pitch black! I know, some photons roam around, but they are actually negleactiable). Everything what emits photons, we try to image: Nebula, galaxies, stars… but why suddenly empty space emits photons?
Rüdiger
šŸ˜Ž
Deep sky background isn't "pitch black", as seen from Earth hence the value given above. End of. Yet it is far darker than the darkest skies we can hold of onto, hence in that context it is indeed the blackest black but this is pure fiction since we can't image away from the Earth. As the answer to the OP then it's as you like it. RGB has no meaning to me as there is no way I can either quantify it or measure it in any objective way.
andrea tasselli Ā· Dec 30, 2025, 10:31 PM
Thanks Andrea šŸ‘ļø
Ruediger avatar
If you refer to me, you missed my point. I asked why one light pollution is removed, and the other pollution not. Is there an accepted and one not accepted pollution? I have a different opinion on this topic to yours. That’s all.
Ruediger Ā· Dec 30, 2025, 11:30 PM
Interesting. Light pollution is a known nuisance and the other pollution do you refer, are those the stars and galaxies we can not resolve? If yes, well then this is more or less part of my question and as published in my original post this seems to be that 27.42 magnitudes šŸ¤” and now again I ask, could we quantify this in RGB values or in PixInsight values like maybe RGB 5,5,5 and PI 0.07, 0.07, 0.07 🤣
Below an example which lacks a bit of contrast but I am testing the new PI process called MAS MultiscaleAdaptiveStretch
In PI the backgroung is around 0.1, 0.1, 0.1 and measured in Photoshop this is around 25, 25, 25
How does it look subjectively to you, does the background please your sight or is it too dark or is it too light šŸ¤”
Ruediger avatar
Hello Rainer,
my advice is purely pragmatic: Don’t make it pure black and not so bright that faint structures disappear. Do not obsess about it. It is commonly accepted that the background is ā€œsome howā€ dark grey and this fine.
I only have an issue with this pseudo scientific argumentation. Just to push it to top: Is a moon gradient in the image less natural than a sky glow? A non black background can only be argued based on esthetic aspects, but not science, as long as you not create a class ā€œless naturalā€ and ā€œmore naturalā€ light pollution. 🤨
To bring to the point: There is no formula to calculate ā€œtheā€ correct background values. At least I do not know one. But I am pretty sure, If there would be one: there would be an script or process in PI easily calculating it for each and every image. Since there is none… guess why…
As said: keep it not black and take care that tiny things are still visible. The rest is personal test and the judgment of of the individual viewer of your image. 20 viewer, at least 20 opinions. 🤣
And the most important: You have to like your own image! Dare to have your own taste!
(except you want to go for batches. In this case you have to follow other’s taste).
For my personal taste, your image looks perfect background wise. But this is of no importance - you have to like it. šŸ˜‰
PS: Many people work with un-calibrated displays or even mobiles. There the black point of the displays differ so much, that any discussion about correct background is completely wasted time.
Engaging Supportive
Martin S. avatar
One thing I tried recently is to stay consistent across images. Once you see your whole gallery, it looks much better if the images have similar background darkness and tint. Especially when you want to print them and hang on the wall next to each other. Not always possible, but good to keep in mind.
Well Written Concise
John Hayes avatar
Ruediger,
The empty sky is actually not black as in the absence of photons. First, the black body afterglow from the big bang is red-shifted all the way down to about 2.7K and that radiation is remarkably uniform to about 1 part in 25,000 over the entire sky. The Gegenschein, which is backscattered light from interplanetary dust in the solar system is bright enough to see with the naked eye under a very dark sky. It’s pretty directional but regardless, it’s a region that stand out as brighter than the surrounding sky. Olbers' paradox argues that in a homogeneous, transparent space filled with stars, the number of stars grows as the square of the distance to perfectly cancel the 1/r² radiometric light fall off with distance so the sky should be uniformly as bright as the sun. The problem is resolved by realizing that the universe is not homogeneous, it is full of absorbing material, and it is not infinite. However, space is full of emitters and light is scattered from interstellar dust. From space, the empty sky is indeed very black and much darker that what we see under the atmosphere, but it is certainly not absolutely black.
As for processing, we generally don’t want to present the sky as absolutely black to avoid a couple of problems. First, stellar profiles look unnatural when the low-end part of the Moffat brightness profile gets truncated. Second, when we display faint extended objects, the regions with the lowest brightness may sit only a couple of ADU above zero. When you make the background too black, a lot of that low brightness stuff become invisible and appears to be truncated, which looks terrible. Setting the background level a little bit above zero fixes this problems and if it’s done right, it still provides the appearance of an inky-black background.
Helpful Insightful Engaging
Ruediger avatar
Hello John,
many thanks for your elaborated answer. It is exactly supporting what I stated.
  1. only very few photons roam around and space is very, very dark (differs a bit from regions)
  2. Not to make the background pitch black is an esthetic point.e.g. Star shape and value truncation
To conclude: yes, space is basically black, but we stretch the very little remaining light extremely to get nicer results. It is a kind of workaround for well known issues.
Rüdiger
Do not take it too serious…
Deducing from John’s answer we should then make our background with a subtle but very subtle touch in Red
We managed to get another year done and let us see what does us bring 2026, hopefully 365.25 days of clear night skies. Let it rain during the day but not at night 🄓
Wish you all a Happy and Prosperous Year 2026
Ruediger avatar
Rainer Ehlert Ā· Dec 31, 2025, 08:03 PM
True! Let’s take an BXT, NXT image of the background radiation and have a beer - Cheers!
Wait! They did already - Dooh!
Happy new year!
Multiscale Adaptive Stretch MAS in PixInsight
Hi, Two days ago I heard about MultiscaleAdaptiveStretch I have been playing with it and as an advanced beginner I like it. It saves me a lot of pre-stretching time with HistogramTransformation (Sorry, Never understood GHS šŸ˜µā€šŸ’«? I also tested VeraLux…...
Discusses PixInsight processing techniques relevant to background level adjustments.
Jan 1, 2026
New scripts for PixInsight: ExtensionToolset
Hi everyone, I have developed ExtensionToolset, a collection of scripts to support image processing and analysis in PixInsight. Features included in ExtensionToolset: - AdditiveColorCalibration: A high-accuracy and robust additive color calibration t...
PixInsight scripts for image processing and analysis applicable to background work.
Aug 10, 2025
WBPP Frame Selector (new): how do you decide which frames to reject?
Hi everyone, I’m new to the AstroBin forum, but I’ve been doing astrophotography for quite a long time. Glad to be here šŸ™‚ Recently, WBPP in PixInsight has implemented the Frame Selector, and I’d like to learn how to use it properly. Until now, I’ve a...
WBPP frame selection in PixInsight relates to image quality and background handling.
Feb 4, 2026
