Guillermo (Guy) Yanez avatar
Hello everyone,
As you may already know, NINA includes a useful plugin called Session Metadata, which allows you to save your metadata, weather data (if available), and image session acquisition details. These files are typically named:
ImageMetaData.csv
WeatherData.csv
AcquisitionDetails.csv
This information is valuable for later analysis. This is s screenshot of the NINA plugin:
I’ve developed an app that lets you upload these files (even if only partially available) and provides metrics, tables, graphs, and statistics that can help you understand your subs and make adjustments for future sessions.
You may find the latest release of my app here.
Upload the csv files created with the NINA plugin without editing to the app. It is freeware!
I’d love to hear your feedback—whether your files are read correctly and if the app is bug-free. Let me know if you encounter any issues.
I’ve also created a Help file to explain the metrics and what each tab includes.
Just as a simple example, you might notice that airmass (how high the object is in the sky) has a much greater impact on image quality than guiding RMS, as good and bad frames often share similar RMS values.
In one sample session, I realized I had mistakenly added too much exposure time near astronomical dawn. It would have been better to skip that last hour and adjust my next session accordingly. The bad frames coincided with the part of the session where the sky brightened too much near sunrise.
Feel free to use it and let me know what you think.
Enjoy!
Guy Yanez
Javier Temprano avatar
It looks very useful. I'll try it out in the next few days. Thanks for sharing.
Well written Respectful
I will certainly make use of this, thank you!
Rainer Ehlert avatar
Thanks for drawing my attention to this. Very interesting. I see in one of your graphs you include SQM measurements.
I have an SQM running 24/7 but how can I display SQM values and my Weather values at the same time in NINA?
Thanks Rainer
Rainer Ehlert · Dec 27, 2025, 05:59 PM
Thanks Rainer
Hi. I am using the Pocket CW2 from Lunático. I am assuming it works pretty much the same with any SQM unit. Here is my own experience with SQM readings:
  • Make sure you are using the ASCOM hub for weather readings in NINA.
  • The ASCOM hub will allow you to select different online sources and devices for various metrics.
  • Select your device in the ASCOM setup for the weather hub (e.g., CW2 or Unihedron) under Sky Quality or Sky Brightness, whichever works for your setup.
  • Make sure it reads as expected in the Imaging tab. See below.
weatherOnce you start a sequence, the readings should be included in each subframe FITS header and the session metadata weather file alike. I hope this helps.
Gracias Guillermo,
I can either run SQM or my Weather data which comes from Weather Underground but as there is no ASCOM driver for Weather Underground, so running both is not possible.
Thanks
Hola,
I downloaded your program Sequence Analizer v0.9, but, yes but, everytime I open it, Norton Antivirus closes it and then it starts again, even having told NortonAntivirus to run it anyway and having told NortonAntivirus to put it in the exclusion list.
Would be nice if you could do something against this
Gracias
Rainer Ehlert · Dec 27, 2025, 10:19 PM
Gracias Guillermo,
Thanks
Hi again. This driver might do the trick for you: https://github.com/spaceuma/ASCOM-WUAPI-ObsCon
I hope it does. Cheers!
Rainer Ehlert · Dec 27, 2025, 10:42 PM
Hola,
Gracias
Unfortunately, I think this is an issue on the Norton end. I Have had issues with Norton myself. It triggers false positives with some exe files created with Python modules such as this one. If the exclusion list does not work, try putting the file in the %appdata% folder or, here: C:\Users\<YourUser>\AppData\Local\.
I will attempt to add a digital signature to the executable in a future version and see if that helps. Cheers!
Well written Helpful Concise Supportive
Guillermo (Guy) Yanez · Dec 27, 2025, 11:10 PM
Gracias Guillermo,
Thanks
Thanks for your help but this sort of pages like the link one and eg. Github are like a “closed book for me”, I never do find wahat I am looking for in this sort of database…
Son un MIsterio no Descifrable 🤣
saludos
Rainer Ehlert · Dec 28, 2025, 01:11 AM
Gracias Guillermo,
Thanks
saludos
Hola,
I downloaded the following file
ASCOM_WUAPI_ObsCon Setup.exe
and while trying to run it it tells me that it can no run on my PC ¿?
kvastronomer avatar
Guillermo (Guy) Yanez · Dec 27, 2025, 09:56 PM
Thanks Rainer
What device is giving you “Star FWHM” metric? This would be most useful for a remote observatory where you can’t see the skies with your own eyes and rely just on numbers.
Well written
Rainer Ehlert · Dec 28, 2025, 02:03 AM
Gracias Guillermo,
Thanks
saludos
Hola,
Hi. I am not the owner of that ascom driver. I am not sure what is going on there. Try contacting the owner . Maybe you should try a different route and combine your SQM device (provided it has an ascom driver) and a different online source for weather such as OpenWeatherMap API using the ascom hub.
kvastronomer · Dec 28, 2025, 06:38 AM
Thanks Rainer
Sorry if that was misleading, as I simply used the NINA example image. You have raised an interesting point: monitoring FWHM in real time can help interpret clouds or obstructions in your current sky. Needless to say, the Sequence Analyzer can extract information from your subs for later analysis, but that’s not useful if you need a real-time reading. You may want to contact Lunatico and ask whether the CloudWatcher or SOLO can provide real-time FWHM—the PocketCW does not.
It would be interesting to have a StarFWHM reading taken directly from subs and sent to the ASCOM Observing Conditions Hub. I’m not sure how to implement that, but it seems plausible.
Guillermo (Guy) Yanez · Dec 29, 2025, 11:31 AM
It is not that important, it was just curiosity. Anyway it does not help me get a better Sky 🥴
Malcolm Park avatar
can the app have settings that persist?
I have to enter my camera and scope everytime I use it.
thanks!!!
Malcolm
New version of Python script to generate target acquisition.csv file from image files in a format suitable for upload using AstroBin's upload csv dialogue
Update 28th October 2024 I have just released the latest version of the script. v1.3.11V1.3.11 changes 1.0 Fixes bug where running the script for the first time from the installation directory would fail 2.0 Deals with the case where the filter names...
Script updates relevant to light frame processing and configuration parameters.
Feb 12, 2024
Long exposure acquisition sessions - more inputs
Hello, it would be great if there are more data options for "Long exposure acquisition sessions". I am doing mosaic and data will be collected from multiple locations. I would like to know in my acquisition input where have I done that sess...
Allows saving metadata and session data for acquisition sessions, directly addressing your needs.
Oct 30, 2024
Easy Way to Change Dates in NINA Framing for planning purposes
I have been trying to find an answer to this simple and obvious question in tutorials, and online forums but am striking out. I will brace myself for a "duh!" moment when the first response comes in, but… This is solely for planning p...
Sequence Analyzer V0.9 — Helps plan imaging sessions with metadata and weather data tracking.
Jul 3, 2024
Astrobin - Saving Long exposure acquisition sessions
Hi, I uploaded my photo to the staging area and added the acquisition sessions multiple times after which I press the save button. No acquisition sessions are saved though… I tried this several times… Seems I can save one session, but whe...
Discusses session metadata saving, directly relevant to acquisition sessions issue.
Nov 17, 2024
Rescue mission: stacking of NGC 5128
I'm at my wits' end and would like to ask for some help to save the data from a session imaging NGC 5128 that I thought would be an absolutely stunning image. I'm new to big telescopes, stacking and post-processing. I have Celestron 9.25 ...
Helps analyze and organize imaging session data for post-processing workflow.
May 11, 2024
