Bluish patch appearing in stretched images despite unchanged optical setup
Jorge Roqueandrea tassellibigCatAstro
25 replies437 views
Jorge Roque avatar
This started happening about two weeks ago, and I haven’t made any changes to the optical train.
Setup: ZWO 2400MC + EdgeHD 11 at f/10 (no reducer).
I’ve been taking flats the same way as always, but for some reason this issue is now appearing and I’m not sure why.
These are 900-second subs, and the histogram looks good using a 3 nm dual-band filter. However, when I stretch the image in PixInsight, I notice a bluish patch / blue stain appearing in the image.
Well written Engaging
Larry Cable avatar
have you checked the various surfaces in the image train for any polutants?
I had a similar issue on the window of my DSO camera where the temp & humidity interacted with cleaning chemical residue … created a foggy halo…
good luck
p.s does for camera have a dew heater??
Concise
bigCatAstro avatar
Jorge Roque · Dec 21, 2025 at 07:54 PM
Have you tried other stretching options in PI, e.g. Statistical Stretch with the Seti Astro Suite script package?
I wonder if it would have similar results.
Have you applied any background correction prior to stretching? Otherwise try an older flat and see what happens.
Jorge Roque avatar
same setup 300 sec + x.7 reducer 1hour data without applying anything image.png
Tom Marsala avatar
My guess would be a flat issue, seeing I have been banging my head against them for two weeks on my last target using my 2400.
Tom
Yes, you got a problem with your flat.
Jorge Roque avatar
i’ll retake flats and make sure that my setup don’t have any leaks and check the sensor just in case
bigCatAstro avatar
Jorge Roque · Dec 21, 2025 at 09:58 PM
Yes, good luck! I hope it turns out that this was the issue.
Well written Respectful
Jorge Roque avatar
also same setup 2800mm + dual band filter 3nm + zwo 2400mc 600sec bortle9 same flat panel, same adu 32k (Took it on November)image.png
Jorge Roque avatar
During the last corrector cleaning,which I did exactly a month ago I applied alcohol with cotton and unintentionally used circular motions in the central area rather than straight center-to-edge strokes. I believe this may have introduced a thin residue or scattering layer on the corrector surface.I’m going to re-clean the corrector tomorrow using straight center-to-edge strokes. I’m 100% confident this is the issue and not related to flats
bigCatAstro avatar
Jorge Roque · Dec 22, 2025 at 01:17 AM
Well, there it is! Great job figuring it out.
Jorge Roque:
*I always did that (that is circular motion) when used to clean my correctors and I was none the worse for that. Besides, it would be the job of the flat to correct for that. But, whatever that might be, I hope you can succeed.
Rainer Ehlert avatar
Jorge Roque · Dec 22, 2025, 01:17 AM
Try mixing some Ether, up to max. 20%, into your alcohol but it should be Isopropilic alcohol at 99%. Normal pharmacy alcohol does not evaporate that good but Ether helps it to evaporate much faster without leaving any residue.
Larry Cable avatar
thought so - same issue I had … glad you have a solution (no pun intended)
Jorge Roque avatar
thanks! tomorrow first thing in the morning I’ll go to CVS to buy 99% isopropyl alcohol, distilled water, and optical wipes.
Stu Todd avatar
Not optical wipes! Just use cotton wool or pads. Optical wipes have chemicsls in them.
e.ferriani avatar
Did you consider ice on the camera lens?
I had an effect like your when on enviromente temperature like +5°C or more i set -10°C.
On my ASI294MC some ice born on the glass.
My new rule is when the temperature is more 5°C i set the cooler on 3°C, if the temperature is less than 3°C i set -10°C or less.
Concise Supportive
Jorge Roque avatar
Stu Todd · Dec 22, 2025, 05:46 AM
copy
Jorge Roque avatar
e.ferriani · Dec 22, 2025, 06:33 AM
But I’m in Miami, and nighttime temperatures are usually around 21 °C. I already ordered a full-frame sensor cleaning kit just in case for my ZWO 2400 sensor
TiffsAndAstro avatar
Jorge Roque:
Re take darks and bias as well, if you usually use those.
It's possible they are out of date
Jorge Roque avatar
SOLVED
After cleaning the corrector plate again, the problem was still present. At that point, I focused on the camera instead. I opened it and performed a deep cleaning of the sensor area, including the desiccant tablets (microwave for 1min), the heatsink, and the fan, which all had a significant amount of dust buildup.
After cleaning the camera, I was able to confirm that during a linear stretch everything looked normal again, with no patterns visible.
1 hour F10 Monkey Nebula from Bortle 9 Linear Stretch and BLX
Well written Helpful Concise
Tom Marsala avatar
So then what would be your analysis? Dew building up on the sensor area? Good to know!
Jorge Roque avatar
Tom Marsala · Dec 26, 2025, 07:37 PM
yes, that’s my conclusion as well. It was most likely moisture buildup in the sensor. When I opened the camera, I noticed that one of the four desiccant tablets was partially loose, and when I regenerated them in the microwave they released a significant amount of moisture
Jorge Roque · Dec 26, 2025, 07:29 PM
SOLVED
Hola Jorge,
I do not want to be picky but in order to have a real comparison of before and after you should have imaged the same object where you detected the problem.
IMHO Saludos
Issue in ASIAIR autostretch preview, or actually FITS corrupted?
Good morning everyone. For some time now, I’ve been experiencing a strange issue during acquisition with ASIAIR PRO using the ASI678MC on long exposures. The phenomenon is particularly easy to isolate and observe by acquiring dark frames, so I’m shar...
ASIAIR autostretch and FITS issues may relate to image corruption causing artifacts.
Aug 14, 2025
Bayer-like checkered pattern on mono subs
Hi everyone. This started happening about a week ago: I have this checkered, debayer-like pattern all around my subs, even though I’m using the ASI1600MM, which is a monochromatic camera. The pattern is gone if I zoom in or out a little bit. It’s sti...
Checkered pattern troubleshooting may help diagnose the bluish patch artifact issue.
Oct 5, 2025
Help - Vertical bands - Flats is the culprit - Can someone help me understand what's happening ?
Hi, Recently I am noticing some weird band like structures in my images. My setup - QHY600PH-M + Takahashi Epsilon 180ED + Astronomik Filters. I Captured RGB images in QHY 2CMS-1 Readout mode at 56 gain for broadband images. (mistake) After noticing ...
Flat-related vertical band issues could explain the bluish patch appearing after stretching.
Nov 23, 2025
Photometric filter for imaging nebulae
Is there any reason why I shouldn’t use a photometric V filter is a replacement for a Lum filter in an LRGB image?? Well it would be VRGB in this case ….. With an ever changing work schedule and the outlook this week is pointing to finishing just on ...
Discusses optical setup changes affecting image quality; relevant to filter substitution effects.
Jul 21, 2025
Diagnostic help, please
Hello, I have searched many sites looking for similarities regarding a worsening issue I have been fighting for some time. I hope that posting here and attaching some photos will help with the diagnosis. Essentially, my stacked light frames using the...
General diagnostic help post may contain relevant troubleshooting for image artifacts.
Oct 19, 2025
