Lunt LS50tha and ASI585MC Pro compatibility and focus issues
8 replies63 views
Girish avatar
Did anyon try to pair up Lunt LS50tha with ASI585MC Pro? I am having focus problem and I am not able to where if I use say ASI174MM mini then all works well. I do believe I have correct backfocus setup for ASI585MC Pro but still. Any idea clue? whether the two are compatible to each other or not?
In the mini, the sensor is 8.5mm from the front face of the M28.5 ring. In the 585 the sensor is 6.5mm from the front of the camera case. You should be able to use that information to match sensor positions. The 585 is perfect for solar work and will work well once you get it sorted.
Well Written Helpful Concise
Rick Veregin avatar
I have the Lunt60, but unfortunately different telescope, focuser etc, so I don’t have direct experience.
Since the 174mm mini is 8.5 mm distance to the sensor and the 585MC is 6.5, so all else being equal you would just need to focus out 2 mm. However, I believe the mini is a female attachment, the 585 is male. So how are you attaching the cameras to the blocking diagonal, you must need a different adapter for the two?
Are you having trouble focusing in far enough, or focusing out far enough? I recall seeing somewhere that the Lunt50THa can have trouble with some cameras with insufficient backfocus, so they could not focus in far enough. As I recall they screwed the camera directly into the diagonal, after removing the adapter on the diagonal.
Another solution is to try a short barlow in the diagonal, that may extend your backfocus if you can get the barlow right into the diagonal.
But I have a question, why are you using a colour camera. You ideally want to use a mono camera, you loose too much resolution and too much signal—signal is really important for solar, with the filter there is not much light, and you want your exposures to be as short as possible. And you are trying to focus on a red light image, as blue and green will be totally black. This means you are only using ¼ of the pixels, the Bayer process will try to fill in the other pixels, but you are losing a lot of resolution. So it may not be very sharp because you are skipping pixels—your 350 mm is giving you a resolution of only 5”. And red is not a great colour for the eye to focus on either. Could this be the issue?
Rick
Girish avatar
Thank you guys! now we have clouds for next 2 days so will try out with what you guys suggested and will share outcome so that it would be helpful for others too!
Girish avatar
Thank you guys! I was able to setup with the ASI585MC Pro and worked like charm!
I posted the outcome images of my first ever solar at: https://app.astrobin.com/u/sam_d_Silva?i=gaq092#gallery
Great! Glad you got it sorted…
Rick Veregin avatar
Awesome, glad you got it worked out!
Girish avatar
Attached test result! it still needs a lot of improvement and yes will keep on sharing the outcome!
Girish avatar
And another one!
BAADER RCC COMA CORRECTOR , BACKFOCUS AND NO FOCUS
Hi there I’ve bought this coma corrector, and the documentation says its backfocus is 91,5 mm. I have a SkyWatcher 250 Quattro, and I’ve replaced the focuser with a more robust one. The problem is that in order to reach focus, I have to insert the co...
Backfocus setup issues with optical equipment compatibility problems.
Aug 12, 2025
Focus Issue with OIII filter on edgeHD 8
Hello, I recently acquired a 533 mono camera and have been collecting some test shots weather permitting. I use Zwo Eaf for focusing. With the Luminance filter the focus point was very close to my previous configuration (osc camera + cls filter). Las...
Focus issues with ZWO camera and narrowband filters relevant to situation.
Aug 12, 2025
Dual narrowband imaging issue
I'm new to using dual-narrowband filters in combination with a OSC camera, and I'm faced with the following problem. During one of the last sessions, I used an Antlia ALP-T 3nm Ha-OIII filter with a ToupTek ATR2600C camera. The filter is inst...
Addresses focus problems with narrowband equipment and OSC/monochrome camera combinations.
Aug 6, 2025
