Jose Mtanous avatar
I recently bought an RH200 MKII. The telescope looks like new and, after some minor tweaking (I still need to fine-tune the collimation), it delivers a very nice, flat field across my full-frame ASI2400. So far, so good.
However, I’m seeing some kind of halos or reflections around most stars. When shining a flashlight inside the scope, I can see some bright edges, although I’m not sure where they are coming from.
I’ve read online that this issue can be resolved by flocking the telescope, but I have no idea how easy or difficult it is to service an RH200.
If you have experience with the RH200, I’d really appreciate any advice or insights. Anything helps.
José
PS: The attached image is a crop of a 120s uncalibrated raw.📷 Screenshot 2025-12-18 103355.pngScreenshot 2025-12-18 103355.png
Those are not due to unwanted reflections but rather are the results of chromatic shift within the optics so I doubt it can be brought to a solution by flocking. In my experience the RH200 has been a terrible instrument I wouldn't touch with a barge pole. Good luck!
Jose Mtanous avatar
andrea tasselli · Dec 18, 2025, 05:24 PM
🫤OK, there are some reflections going but I never thought about chromatism. I will check with a mono camera and NB filers.
Thanks of the feedback
The chromatic shifts are only occurring for the out-of-focus part of the image, such as the halos. In focus is mostly the same focus as I remember it.
Jose Mtanous avatar
andrea tasselli · Dec 18, 2025, 05:38 PM
The attached image is in focus and close to the center of the sensor.
This could be chromatic effects along with a self-reinforcing diffraction effect:
https://app.astrobin.com/forum/topic/188005/reflectors/is-this-what-i-think-it-is#post-204347
If you still see the rings in narrowband, that’s it.
Jose Mtanous avatar
Tony Gondola · Dec 18, 2025, 05:44 PM
Thanks. According to the thread you pointed out, the patternt should not be visitble with L filter, but in my case it is clearly visible. I will definitely test with NB filters shortly.
Here an example on one of image of mine:
It is not very prominent because of the large pixels used but the red halo is bigger than the blue one.
Jose Mtanous avatar
I removed the camera and there are many shining circular surfaces inside the OTA. The corrector plate holder had two anodized surfaces that are very bright.
I then removed the primary and wow, I cannot believed the design of the baffle tube, it has 3 sections and it is short. You can easily see light comming from outside the secondary mirror. The concentric diffraction pattern matches the shape of the baffle tube.
I will 3D print a closed and slighty larger version of the baffled tube, if that don’t fix the issues I will flock as much as possible the rest of the tube. I hope I dont have to mess with the corrector plate.
📷 PXL_20251218_212704940.jpgPXL_20251218_212704940.jpg📷 PXL_20251218_214430278.jpgPXL_20251218_214430278.jpg📷 PXL_20251218_222605470.jpgPXL_20251218_222605470.jpg
Honestly, this optical design is so far out of my experience zone I really don’t know where to start. I certainly wouldn’t start by changing things without first talking to someone who really understands the design, like the people who made it.
Jose Mtanous avatar
Tony Gondola · Dec 18, 2025, 10:53 PM
I completely agree, I already sent a couple of emails to OS. No response. I hope they reply with a solution, but in the meantime I will play with some ideas. AFAICT, as long as I don’t mess with the corrector, I’ll be OK.
Jose Mtanous avatar
I have designed a closed baffle tube to replace the stock one.
📷 Screenshot 2025-12-18 180646.pngScreenshot 2025-12-18 180646.png📷 Screenshot 2025-12-18 182934.pngScreenshot 2025-12-18 182934.png
Jose Mtanous avatar
Yesterday I did some tests without the baffle tube. I was expecting lots of reflections, but to my surprise there were none and the halos completely disappeared.
The scope still needs collimation, but I’ll wait until I 3D-print a new closed baffle tube.
I’m not sure why OS installed an open baffle—the RH200 actually works much better without it.
I’ll report back after installing the new baffle tube and fine-tuning the collimation.
Jose Mtanous avatar
UPDATE:
I carefully collimated the RH200, the collimation it self was very easy, however I had to replace two stripped screws, so I have to unmount the primary one more time. After replacing the screws collimation was fast and easy.
These are the results without the bafflle tube abd good collimation. Full frame color camera.
Rainer Ehlert avatar
IMHO this looks very good.
Jose Mtanous avatar
UPDATE:
I have further tweaked collimation, still no baffle tube and this is the result of 1 hour integration:
Small Center crop 4X zoom
📷 Screenshot 2025-12-25 123412.pngScreenshot 2025-12-25 123412.pngCorner and center of full frame camera ASI2400:
So far, no weird reflections.
I am happy with the results and for now I will use the telescope without the baffle tube.
At first sight it looks good. 👍️
Jose Mtanous avatar
Finally, a clear night! After finetuning the collimation and tilt, the RH200 performed beautifully. These images are without the stock baffle. Stars look perfect corner to corner on my QHY268MM. I don’t own a full-frame camera.
These images were captured with an Astrodon Ha 5nm filter.
Felicidades
Jose Mtanous avatar
Finally, an image with the RH200 under dark skies. This is the result of 9+ hours with the RH200 and QHY268M.
After removing the stock baffle, carefully collimating the telescope and squaring the camera, the RH200 performed beautifully. The stars are very tight and round across the whole field of the APSC sensor. The illumination is also very even, and it only drops 10% at the corners.
These are the results:
Full image details:
https://app.astrobin.com/i/83of9r?r=D
Well Written Helpful Insightful Concise Engaging
Bravo, been a bit of a road this one.
TiffsAndAstro avatar
Jose Mtanous:
Full image details:
That's a remarkable first light
Officina Stellare RH200 AT reflection rings and how to fix them.
This is a follow-up to my previous thread: https://app.astrobin.com/forum/topic/208401/officina-stellare-rh200-mkii-at/help-with-rh200-halosreflections Quick update for anyone fighting RH200 arcs/reflections. After removing the internal baffle, star ...
Author previously discussed RH200 reflections; this is direct continuation of their troubleshooting.
18 days ago
Halo artifact troubleshooting on Esprit ED80 and lens cleaning safety
I’m looking for some troubleshooting help with my Esprit ED80. I have this strange halo artifact on mid to bright stars (see attached image). If I rotate the image train, the defect follows the scope, so I know it’s there, and it is equally present i...
RH200 halos/reflections; directly addresses similar halo artifact problems in telescopes.
Nov 26, 2025
Any suggestions: trouble achieving sharp focus with Edge HD
Recently I bought a second hand Edge HD 8. The tube was bought 4 years ago and in very good shape. Collimation is - as far I can see - all right. My main problem is: I can’t find good focus. Recently I captured the moon and Jupiter . Although PixInsi...
Optical issues with reflector telescopes; collimation and focus problems relevant.
28 days ago
Single spike on some stars - Askar Refractor
Over the last few months I have been struggling with puzzling spikes on some stars during RGB (no filter) shooting on my refactor. Here’s what I have observed so far about these spikes:Consistent over multiple nightsSpikes DO NOT appear with priority...
Halos and reflections in telescopes can cause localized optical artifacts.
Jan 8, 2026
Serious Stray Light Issue - William Optics UltraCat 56
I’m posting this to see if anyone else has experienced or can verify this problem in their UC 56 telescope. I received the telescope February 2, 2026 from Agena Astro. The quality control certificate that was enclosed was dated December 5, 2025. The ...
Addresses stray light and halo issues in telescopes, directly relevant to author's problem.
Mar 1, 2026
