Stain appearing on photos
13 replies200 views
Wandrille VINCENT avatar
Hello, I have a problem with spots appearing on my photos. I have an ASI 533 MC Pro Color, a 150/750 Newtonian telescope, and a coma corrector.
Thank you in advance.
Are you shooting a proper calibration frames?
Here is the final photo with the calibration photos.
Could this be related to FLAT?
What I don't understand is that these two photos were taken on the same night without touching anything, and the stains don't overlap.
bigCatAstro avatar
Yes, how are you taking your calibration frames and what do your flat frames look like?
Well written Respectful Engaging Supportive
Probably a ghost reflection from the bright field stars.
Well written
If your calibration is good then, considering the large number if bright stars in both of these fields, I would tend towards that as well. It would be easy to retouch these out.
So it's not a problem?
bigCatAstro avatar
Wandrille VINCENT · Dec 17, 2025, 07:53 PM
You should be able to clone stamp/blemish blast out those issues on the starless version of your image. Looking at more of your photo examples, I also think you’re getting some kind of reflection from the bright stars. Those two targets are often tough when it comes to reflections due to the brightness of the stars and number of them.
Not that much. Stuff like this happens every now and then.
Here is the final photo of the horse's head. It's still very intriguing.
John Walsh avatar
It’s a reflection from the sensor glass to the glass of the coma corrector and back to the sensor.
Notice how you can draw a line through the centre of the frame from a bright star and you will land on the aberration, with the star and the aberration an equal distance from the centre point?
I had this with the TS Optics GPU corrector and my 700D. Almost cured with the better AR glass on the 2600NS which I have now but still there on extremely bright stars
alpheratz06 avatar
Any filter in the optical path?
Had this king of artefact on a RC8 with brilliant stars as Alnitak . I upgraded the UV/IR filter to higher standard and the problem was solved
Concise
Non, simplement un correcteur de coma.
WBPP Stacking generates Black and White result from OSC Light frames
Have faced a peculiar issue during WBPP Stacking in Pixinsight for two sets of of light frames . Others seem to work fine I have a OSC ASI 533 MC Pro along with Askar SQA 55 and my recent exposures of M42 and NGC 1499 have generated a black and white...
OSC camera with spots on images; similar equipment and processing workflow.
Mar 24, 2026
ChatGPT and oval stars
An interesting exchange with ChatGPT regarding a new onset problem with stars across my entire field of view being oval shaped, and all elongated in the same direction. Exchanges are summarized due to the wordy nature of ChatGPT. What is interesting ...
Optical aberrations affecting image quality; troubleshooting stars appearance issues.
Feb 13, 2026
