Laida SHO 5nm filters first light test
5 replies222 views
On my mono setup (ASI294mm) I originally used all the legacy 1.25" filters that I had/have, Astronomik IIc for LRGB and a mixture of Astronomik, Baader and Astrodon True-Balance for NB (Hb, Ha and OIII). Never actually had any SII filter previously.
The LRGB set failed spectacularly from the get go with my f/4 optics and was soon replaced by a much better performing set of 31mm ZWOs. The performance of the NB was ok, except for vignetting which was troublesome for both the OIII and to a lesser extent the Hb filter too. Ha was ok-eish. Still, the Hb BW is 12nm, the Ha is 6.5nm and the Astrodon is 6nm. Good but not great from my circumstances (B7 with low transparency year around) so I was looking for a filter set that would be tighter in bandwidth, had the same optical thickness and less clipping of the marginal rays and included the Sulfur filter.
Looking around for 31 mm unmounted filter set they are rarer than hen's teeth and just as expensive as they larger cousins the 36 mm one. Finally, after at considerable amount of research, I landed on this, to me unheard of, manufacturer of the Far East. The asking price was ridiculously low even for a 1.25" set (£83 shipped inclusive of taxes). They don't sell 31mm but the clear aperture of 26mm would have been a step forward compared with the 23mm of the Astrodon one and on par with the Baader's Ha.
The filters arrived within a fortnight and promptly went into the FW. Luckily I had a break in the weather which allowed a test in between weather fronts. Obviously clouds soon enough rolled in and I had to cut short on the SII exposures. Having ask for a SII rich target here the consensus was that for my location and time of the year a bright enough subject would be the the Heart Nebula and I went for despite the restricted size of the FOV, but again it was a test. After a week of clouds and inclement weather I had another break which allowed me to capture enough of the SII signal (but not enough of the OIII, sadly).  The images below show the main starless masters with just auto-stretch applied and nothing else:
Ha: 20x180s
OIII: 37x180
SII: 60x180s
Now, IC1805 isn't really OIII rich so I didn't expect a lot of signal except for NGC895. SII is new to me but given the transparency conditions I'm pretty chuffed on how it turned out.
On the basis of these 3 images I created a Forrax palette SHO rendering (with further curves to control background and mid-tone levels. No BXT was used but NXT was, to reduce the noise to a presentable level.
Overall I'm please with how things turned out and I cannot wait for a good chance to test the filter set on Alnitak.
Jan Erik Vallestad avatar
Good to see, mine have mostly been in the box since I got them in June. I bought them mostly for the heck of it because the price was so low. The 18mm filter thickness initially makes me think they may be a SvBony copy?
The only test I’ve done is with my 678mm/Samyang 135mm F/2 combo, at F/2 I saw some troubling signs of large halos at 30s exposures. But I didn’t get enough to really look into it. I’ve since replaced the camera with a cooled 585mm so this makes me more confident going forwards!
Tareq Abdulla avatar
I always keep looking at those “Asian” low prices filters or even any product so i can give them a try if i buy them, because i am tired of keep spending too much on products just because it is better made or quality while others can do it in lesser quality or lower cost, and if i buy too many items or gear then it is no point at all to keep buying only so expensive or high end items, for example if i have 5 mono cameras that i will use them separately at same time, i can’t just go buy only Astrodon or Chroma for all of them, even if i buy a cheaper one but not very cheap is also a waste, Antlia or Optolong is the cheaper version of high end but they aren’t super cheap, so then if there is something else even much cheaper than those and giving ok not bad results then why not, so Laida is one of them, i hope to see them making also 3nm filters if possible.
Just to follow up my own experience; Mine are going to the trash. This is utter rubbish just as I expected when I bought them. Might be an issue with QC but the halos I thought I saw with my initial tests are present and really bad at that.
This is 7hrs of Oiii data and this is just the worst of the bunch.
image.pngSafe to say I will be swapping these out with Antlia or Scorpio filters as soon as I can.
Jan Erik Vallestad · Dec 26, 2025, 05:59 PM
When you try Scorpio let us know, i think Laida need more time to perfect their quality control, Scorpio maybe not better but i feel they are doing ok for now and keep improving.
Thanks for sharing with us
Tareq Abdulla · Dec 28, 2025, 11:45 AM
As for Scorpio I will say that the dualband filters seem to be very good. I own the 7nm ones (Ha/Oiii and Oiii/Sii). I’ve only tested the Oiii/Ha filter but it was halo-free and looked the part:
ImageMixed with Antlia Sii here.
Does brand matter for LRGB filters?
I saw a post somewhere that Antlia SHO filters were good but their LRGB filters weren't? I have both and I am very happy with the 3nm SHO but wasn't sure if the LRGB filters were good or if I could do better, I know Chroma is the most expensi...
Discusses alternative SHO filter options; relevant for comparing filter brands.
Jan 26, 2025
More identical cameras, which last one to get?
Hi all, My Touptek camera of 571 mono arrived and delivered to me today, it is my second mono of 571 but as third one of 571 sensor , and now if i will use 4 identical scopes to do SHO LRGB then which forth 571 i should get, a third mono or a second ...
Discusses mono camera setup with SHO filters, directly relevant to author's imaging strategy.
Dec 12, 2024
Looking for Advice on SII & OIII Filters - Halo Issues with Askar D2
Hi everyone! I need some advice on narrowband filters. I currently own the Askar D1 and D2 filters. The D1 is fantastic great colors and truly halo-free. However, while the D2 produces nice images, I’ve been struggling with halos, which is quite frus...
Narrowband filter testing and comparison; relevant to filter performance evaluation.
Jan 29, 2025
Unmounted Chroma Filter Orientation
I have recently purchased a set of unmounted Chroma filters. I have been trying to get clear instructions on which side of the filter faces the camera. The manufacturers say it doesn't matter. Cloudy Nights has several long discussions that agree...
Discusses filter orientation and setup for astronomical imaging equipment.
Aug 16, 2025
Advice on duo-band filter selection for astrophotography setup
Hi, I am looking to expand my astrophotography setup with a duo-band filter. Well, possibly two depend on how the pricing goes. I’m looking to have my feel-pinions validated and possibly a correction from someone who knows what they’re talking about....
Author considering filter upgrades; duo-band filters relevant to their NB setup.
Aug 31, 2025
