Seeking advice on Chroma LRGB filters for monochrome CCD cameras
16 replies299 views
Kevin Dixon avatar
I am planning to upgrade my LRGB filter set which is to be used with a monochrome CCD camera. I am considering the Chroma LRGB set of filters. I would very much appreciate hearing from owners of these filters about their experience with the filters and monochrome CCD cameras. Thanks in advance.
Clear skies,
Kevin
Well written Respectful
Andy 01 avatar
Chroma make fabulous filters, been using them on my mono cams for 5 years now, no haloes or fringing, never had an issue with them - highly recommended!
Andy
Kevin Dixon avatar
Thanks very much Andy. I am very pleased to hear of your experience with the Chroma filters.
Clear skies,
Kevin
Arun H avatar
Kevin- I have been using 31mm Chromas since 2018. They are excellent and the customer service has been top notch. Chroma stands behind their product and ai think you can buy with confidence.
Ashraf AbuSara avatar
I have purchased maybe 4 different sets of Chroma filters of different sizes. I had only two issues with two different filters and Chroma replaced both of them with just one email, no questions asked. They even sent the replacement before I sent back the faulty filter. So they are highly recommended in my opinion.
Are you just buying the LRGB filters? If it is just the LRGB filters, you might find that you get excellent performance from cheaper brands like Antlia or Astronomik. I think where Chromas are worth the premium is their narrowband 3nm filters.
Well written Helpful Engaging Supportive
Arun H avatar
Ashraf AbuSara:
In an ideal world, one would simply buy Antlia LRGB and possibly Ha and SII filters and Chroma OIII filters. The problem is that the Antlia's are 2mm thick (other than the 50mm size which is 3mm thick) and the Chromas are 3mm thick. This will cause a difference in the optical path length to an OAG if you are using one and would have to be readjusted each time you go back and forth between the two brands.
Well written Helpful Insightful Concise
Bill McLaughlin avatar
I have had Chroma, Astrodon, and Astronomik filters. Of course the Astrodons are great but not available anymore except used.
Between the Astronomiks and Chromas, the Astronomiks were OK but the green did have a slight halo and the narrowband (these were the fast version) were kinda wide at 6nm. The other issue is that they were quite thin at 1mm so often need to be paired only with other 1mm thick filters which are not as common as the 3mm thickness (both AD and Chroma and others).
The only odd thing that I have noted with the 3nm Chroma narrowband filters is that for some reason I have had a very hard time establishing reliable and repeatable offsets. This was true with both of the two sets I have used. I really can’t explain that but it was not an issue for the Astrodons that were identical spec-wise.
Arun H · Dec 9, 2025, 03:17 PM
Ashraf AbuSara:
Agreed. That’s pretty much why I never mixed and matched filters as I use OAG exclusively for all my guiding. Even the 50mm round I just didn’t want to deal with a possible headache.
Rainer Ehlert avatar
I guess about filter thickness this is no problem when using NINA and making a Filter Offset calculation and then NINA applies it automatically when changing filters…
If it works…
Arun H avatar
Rainer Ehlert:
No - this has nothing to do with filter offsets. The OAG would have to be physically moved or it will not be in focus. Filter offsets will allow you to get the main cam in focus. They will do nothing to change the path length to the OAG which is ahead of the filter wheel. With regular same thickness filters, the offset is small enough, and guiding software is forgiving enough, that small changes in path length with filter changes so not matter. But a 1mm thickness difference will absolutely make enough of a difference to require refocusing the guide camera.
For me it works and that is why I mentioned it, but OK, I am no expert…
I know it affects the OAG but we need to know what f/X we are talking in order to know the critical focus zone and so we could know if the OAG is very much affected or not.
Just guessing…
Astro Jeep avatar
I am by no means wealthy, but I have learned over the years that buy once, cry once fits very well when it comes to Chomas. I have a 1.25” set and a 36mm set. It drained my pocketbook each time I purchased, but I am completely happy with them. If you go cheaper, and you want Chromas, you will have spent more money in the long run when you eventually buy what you wanted in the first place. If you have the monochrome now, but haven’t saved up the needed funds for the Chomas, you could always just shoot mono in the meantime. Mono images can be beautiful if done right.
Helpful Concise Supportive
Astro Jeep avatar
Bill McLaughlin · Dec 9, 2025 at 03:29 PM
That is odd. I have two filter wheels loaded with Chromas. I have had no issues with offset with Chromas. I know you do not know why, but of course I am curious now. I would email Chroma, and let them know. They have great customer service.
Supportive
Kevin Boardman avatar
Kevin Dixon · Dec 9, 2025 at 11:33 AM
Clear skies,
Kevin
I have Chroma 50×50 3nm and they have been fantastic. If Chroma is in your budget it’s a no-brainer in my opinion.
Supportive
alpheratz06 avatar
If you can afford Chroma, go for it.
As regards LRGB, astronomik would be a good compromise.
Willem Jan Drijfhout avatar
Chroma filters are perhaps the best in the industry. I am using a full 50mm LRGB+3nm narrowband set and very happy with them. I sincerely wonder if in today's world they are worth the premium pricing though. When I moved my setup including the Chroma's to a remote site, I was in need of a new set of filters, so gravitated to Chroma again. Just to discover that their price had doubled in just over 5 years! That just did not sit right with me and I eventually settled on an Antlia set and very happy with it.
Helpful Insightful Respectful Concise Engaging
Unmounted Chroma Filter Orientation
I have recently purchased a set of unmounted Chroma filters. I have been trying to get clear instructions on which side of the filter faces the camera. The manufacturers say it doesn't matter. Cloudy Nights has several long discussions that agree...
Chroma filter orientation and handling guidance directly relevant to purchase.
Aug 16, 2025
Optolong L-PRO and SC8
Hello, I am looking to purchase a broadband filter with my SC8 to improve further my acquisition data. I was wondering if anyone is using it with an SC8 shooting at F10 or if you use it with a focal reducer (celestron or starizona). If you have any e...
LRGB filters for monochrome cameras; relevant to broadband filter selection discussion.
Aug 14, 2024
Seeking review/feedback of HEM27
Hello AB Would love to know opinion/ feedback from Ioptron HEM27 users. There is lot about AM5 but not so much for HEM27. I have been using GEM28 for the last two years but now looking for an upgrade. I am planning to use Literoc tripod with the moun...
OSC camera mentioned; filters relevant to potential equipment upgrades.
Aug 30, 2024
Antlia Dark Series LRGB Pro Imaging Filter Set - 2" Mounted - anyone using?
Is anyone using this particular filter set under dark (Bortle1-3) skies? Our remote imaging group needs a new 2” filter set and the Antlia has nice overlap between R, G & B. I have heard many complaints about Antlia filters having bright star hal...
Alternative LRGB filter set for monochrome imaging; similar use case comparison.
Dec 31, 2025
LRGB filter reviews and recommendations
Hi gang, Filter technology has changed and improved greatly over just the last few years. As such, my 30-year-old set of 1.25" LRGB filters is well past its 'sell by' date, and I would like to update it. I use them with a QSI CCD camera ...
Specifically about LRGB filters for monochrome CCD cameras; highly relevant.
Feb 8, 2024
