Reducer/Corrector High-Quality Options for a 10" Truss Tube Ritchey-Chrétien Telescope (Larger than 2")
5 replies147 views
Tommy Mastro avatar
Hi all,
I picked up a used iOptron 10" Truss Tube RC. I tried using the APM-Riccardi M63 reducer/corrector with it but no matter how I connected it, I could not reach focus. When directly connected to the end of the focuser tube, my camera sensor was too far away. When I set it inside the tube, my sensor was too close.
Then I tried with the 3" Explore Scientific Reducer/Corrector and had similar issue. I could not reach focus when connecting directly to the focuser tube (with all extensions removed, my camera sensor was still too far away). And could not figure out a way to connect it with the reducer inserted within the focuser tube.
I can always use the 2" Apertura reducer for RC telescopes, but it is low-quality (or not as high-quality as other options), and it would probably cause vignetting with my full-frame camera. I don't want the reducer to be the weak link in my imaging train. I would like to give the iOptron RC a reducer/corrector that compliments it well without reducing its optical potential.
So, what are other RC users using other than the inexpensive 2" Apertura? I would love to hear from RC users on how they are configured? What reducer/corrector are you using and how did you make the connection so that you reached focus?
Thanks,
Tommy
Tobiasz avatar
there is the Sharpstar 2508 0.8x Reducer Corrector designed for RCs. Many shops are selling rebrands of that reducer like the TSRCRED from TS or the Omegon Pro Reducer. I think an Artesky rebrand is there, also. You should check that out.
Reaching focus depends on your focuser, what have you currently installed?
Tommy Mastro · Dec 8, 2025, 12:14 AM
What do you mean by that? Why not drive out the focuser to the desired focus position?
A RC with a 2.5” reducer always ends up with a short 3 inch focuser, where the reducer is inserted into the focuser tube. Depending on the setup you may also need extension tubes for the reducer INSIDE the focuser tube which eats up precious backfocus.
Hot take: Did you verify your mirror spacing with a ronchi eyepiece? My RC provided a lot more backfocus after fixing the mirror spacing with the ronchi.
Regards
Tobi
Tommy Mastro avatar
Tobiasz · Dec 8, 2025 at 08:43 AM
Regards
Tobi
I’m new to RCs so I’m not familiar with the Ronchi method. I will Google it.
I’m not sure what you mean by drive out the focuser to the desired position. I am using the stock factory focuser. When I set the reducer into the focuser so the rear of the reducer is connected to the end of the focuser tube (instead of the front of the reducer screwing on to the focuser tube) it is too close and doesn’t reach focus.
I will definitely look for the Sharpstar options. Thanks!
Nathan Smith avatar
Yeah defiantly check out the mirror spacing. I can alter my focus point 40-60mm by adjusting the secondary spacing a few mm
Concise
Tobiasz avatar
Tommy Mastro · Dec 10, 2025, 12:17 AM
Regards
Tobi
The guide I used can be found here. https://lambermont.dyndns.org/astro/rc/Ronchi-testing-the-focal-length.pdf
It is short and straightforward and can be done with your eyes against a star or with a photographic ronchi. Both are offered by Gerd Neumann Shop for example. I use the classic ronchi eyepiece without a camera against a star. Please beware that fiddling with the mirrors will mess up the collimation which will be visible in the Ronchi eyepiece. I always collimate the secondary with a laser after every change, so that the effect of the error is small. It does not have to be perfect only when you're done to verify.
My mirror spacing was messed up at first and my changes worsened it so I needed two evenings to fix that (first time with a Ronchi). But for now it looks very good. My focal length increased to 2040mm, which is around f/8.2.
So it is the other way around? You would need more in focus travel to reach focus, even with only the focuser attached and no extension tubes? If so, that is unusual and I think your mirror spacing might be really off here. Without a reducer, how long is your backfocus distance from the back of the tube to the focal plane? AFAIK it should be around +-240mm depending on the tube design.
For comparison, my RC backfocal distance is somewhere around 270-280mm with the fixed spacing.
Regards
Tobi
Tommy Mastro avatar
Thanks guys. I’m going to look into everything discussed here and see if I can’t figure it out. I will report back this weekend.
Tommy
Well written Respectful
Two cameras two fov options?
I’m looking at picking up a William Red Cat 91 with a ZWO ASI2600MC Air. I played around with the FOV of that combo on Stellarium and found that while it was great for Andrometa galaxy and M42, it just didn’t have the reach for most of the galaxies o...
Discusses reducer/corrector options for improving field of view and resolution trade-offs.
Dec 16, 2025
Askar 130 PHQ Tube Size (where focuser connects)
Hi, I am replacing the stock focuser on the Askar 130PHQ with a better one. Has anyone have experience doing this? If so, how did you find the size in millimeters where the focuser connects to the scope tube? Thanks! Jerry
Discusses mechanical connections and modifications to telescope equipment.
Jan 12, 2025
Custom Newtonian Builders in the US?
Hi, I'd like to build a 10" F3 newtonian with a curved spider, and a Big Paracorr coma corrector for full-frame astrophotography. I want a carbon fiber tube and everything screwed into the focuser (including coma corrector) then OAG then Fil...
Discusses reducer/corrector options for large aperture telescopes like author's project.
May 8, 2024
