Read noise Astrophotography avatar
CEM120EC — Real-World Review
(With Actual Guiding Metrics)
I realised something: there is almost no modern, accurate, real-world information on the CEM120EC.
Most people only post when something breaks.
So let’s correct the record because this mount deserves celebrating. 🎉
I recently dragged my RC10 astrograph from my observatory in Scotland up to my observatory in Sweden.
(By the way the Pulsar dome in Scotland is for sale.2000€)
This immediately crushed the weight limit for my beloved CEM70 actually it ”probably would handle it but wear out prematurely. I’ll never sell that mount it’s getting shipped to my dark-sky site in the Philippines. But this is about the 120EC
Build Quality
As with all iOptron gear I’ve owned, the build quality is excellent.
My only minor complaint: the Tri-Pier 360 paint feels a little soft.
But structurally?
  • Industrial-grade
  • Ridiculously rigid
  • Total overkill in the good way
Perfect for a heavy setup.
The Mount
The CEM120EC is the best mount I’ve ever owned.
Full stop. End of review.
…nah, let’s continue.
It behaves like a mount that should cost ten times its price.
It’s the first mount I’ve used where the mount completely disappears from the workflow:
  • no personality
  • no mood swings
  • no “good one night, terrible the next”
  • no drama
The only limit is seeing.
I guide with:
  • RA: LowPass filter
  • DEC: Resist Switch
  • 2–3s guide exposures (1s for calibration)
  • Extremely low aggression (this is key)
I calibrated PHD2 month ago and never had to touch it again.
Literally: switch on → point → focus → start sequence → forget…
(unless the EIS starts screaming “clouds incoming!”).
Unguided at 550mm, 300-second subs are no problem.
Guided? Unlimited.
I’ve had it holding 0.29 eccentricity all night on 300–600s subs.
I pushed a test to 1800s stars still behaved (ecc ~0.45″).
When iOptron says zero backlash, they mean it.
And the certification sheet in the box is a nice touch:
PE RMS 0.15″ which matches real-world performance.
Portability
Technically portable.
Realistically?
Only if:
  • it’s near your transport,
  • you have a team,
  • or you regularly bench 159 kg.
It’s a serious piece of hardware not a travel mount.
Locks, Cabling & Power
RA and DEC axis locks are essential for:
  • protecting the gears
  • mounting heavy OTAs
  • balancing safely
On-saddle I/O:
  • 3× USB 3.0
  • 2× USB 2.0
  • 2× 12V / 5A outputs
  • 2× 12V / 3A outputs
More than enough for a properly designed system.
Cable-management on the CEM120EC is excellent clean, logical, practical.
Setting it up in the observatory felt like cheating.
Adjustment Hardware
Altitude and azimuth adjusters:
  • ultra-fine thread
  • zero stiction
  • zero jump
  • genuinely smooth
There’s a proper scale on each axis for precision polar alignment.
My rule of thumb: 00°00′10″ or better in both axes.
Guiding Performance
  • RA: 0.07 px (0.16″)
  • DEC: 0.08 px (0.16″)
  • Total: 0.10″ RMS
  • RA Osc: 0.04
Flat as a ruler
📷 IMG_9109.jpeg📷 IMG_1488DC37-B578-49F7-A608-ABEF561A981A.jpegIMG_1488DC37-B578-49F7-A608-ABEF561A981A.jpeg
Lower altitude
📷 IMG_EC82A11F-D8D9-4C14-9B4A-FCC845E21C74.jpegIMG_EC82A11F-D8D9-4C14-9B4A-FCC845E21C74.jpeg
Behaviour Summary
The guiding graph is always the same:
  • low-amplitude
  • no sawtoothing
  • no overcorrection
  • no RA/DEC balance fights
  • no RA humps
  • no “encoder twitching”
  • no surprises
I haven’t tried the RC10 at long focal length yet galaxy season isn’t here
but based on current behaviour, I expect no drama.
Observatory Context
I’m running it on the Tri-Pier because this observatory is a prototype test site.
I don’t want a permanent pier yet I’m relocating everything to the Philippines in 2027:
B1 skies, ~0.7″ seeing.
This mount is coming with me.
If I could marry it, I would.
Until death do us part.
The combination of tri pier and my observatory design makes for a very stable platform.
Brian Puhl avatar
Read noise Astrophotography · Dec 7, 2025, 09:32 PM
I had to laugh just a little bit at your expense. When I was at NEAF last year, I put my hands on every single mount they had on display, and every one of them had very noticable RA gear slop. It wasn’t a good look tbf.
Jokes aside, I’ve been looking to move up to a bigger mount at some point. I haven’t ruled out trying a 120EC, simply because of the price point. Ultimate, I’m probably going for the GM2000. I know a few people that generally seem to like the 120 however. I also know alot of people that wouldn’t touch iOptron mounts with a 10 foot pole. I think what would really help us get a feel for the actual performance is sharing a guide log. I can show you screenshots of guide graphs that make my EQ6 look just as good as your 120EC, but conditions change, and in those poor conditions is where it will shine.
Brian Puhl · Dec 7, 2025 at 10:19 PM
Good question I’ve actually never needed to analyse my guide logs before because the mount has been so consistent.
I can upload whichever you want.
Honestly the logs all look the same because my guiding is extremely low-intervention PHD isn’t doing much at all.
For reference: my seeing averages around 1.5″, so these numbers aren’t cherry-picked perfect-night conditions.
On the backlash comment
Just to clarify:
My mount has zero backlash genuinely zero.
If someone checked RA/DEC slop at a show unit, that’s almost certainly because the gearbox wasn’t engaged and it was sitting on the axis locks.
If I had my mount on display, I also wouldn’t engage the gearbox hundreds of people pulling on the axis is a perfect way to damage a precision system.
So that NEAF experience doesn’t reflect actual performance in the field.
My own experience
I bought a CEM70 first it worked perfectly out of the box.
That’s exactly why I stepped up to the 120EC.
Same story: flawless behaviour because the system is set up correctly.
There are lemons out there with every brand, but most “problems” with these mounts end up being:
  • user error
  • bad balance
  • bad cable routing
  • wrong PHD settings
  • people chasing seeing
Logs? Sure. How many do you want?
I can pull a few, but they’re all the same.
PHD takes about 10 minutes to fully settle into the long-exposure low-aggression loop I use, and after that the graph is basically a straight line.
If you look at my guiding settings, there’s a very obvious clue:
PHD is barely correcting anything.
That’s encoder stability doing the heavy lifting, exactly as intended.
Clear skies!
Star eccentricity is usually around 0.30
I’ve never looked at guide logs I can see what needs adjusted be watching the guide graph. If you understand what you looking at then it’s obvious.
Brian Puhl avatar
It’s certainly obvious when you know what you’re looking at, I agree.
An RA OSC at 0.14 means PHD’s pretty much doing nothing. Your encoders are definitely doing the work. It does seem like the mounts doing extremely well. If it’s consistently like that, I’m guessing you just have some really good skies. Even on my 1 arc second nights, I still have a nice fine sawtooth action going, but I think I’m sampling the skies better with my 678M. Highly recommend the camera for guiding if you’re looking for an upgrade.
Rainer Ehlert avatar
Brian Puhl · Dec 7, 2025, 10:19 PM
GM2000
Not everybody has the money…
And about RA backlash there is none. I have two CEM 120EC2.
Slope? every mount has slope as it only depends how you test it
Brute force or with sensitive finger feeling…
Ashraf AbuSara avatar
I got a bargain bin second hand CEM70ec-Nuc from Agena for under $3k. There is definitely some backlash in the DEC on mine, which is very manageable. For the price it is a ridiculously good mount.
Here is a full PHD2 log from my backyard for those interested.
https://drive.google.com/file/d/1iBGx0ZeL9eeCtweJYefz2ib4BpcjfeDD/view
Well written Helpful Concise
CEM120EC
Which year did you get them?
I got them in April 2018 and are two CEM 120EC2 and those were the first two mounts with encoders leaving the iOptron premises.
What is your longest focal length you work with?
I do image at 3200mm focal length
Ashraf AbuSara · Dec 8, 2025, 01:27 AM
I guess you know that you can adjust the worm/worm gear mesh…
Rainer Ehlert · Dec 8, 2025, 01:44 AM
Thanks. Yes I am aware of this. I also adjusted the belt tension. It helped. But still not completely resolved. That being said the mount still performs significantly better than the price I got it for so I can’t complain.
Brian Puhl · Dec 7, 2025 at 11:39 PM
Hi sorry fell alseep
I’m currently using the ToupTek GMP462M. Honestly it’s been rock-solid: extremely sensitive, never fails to find stars. I also run a UV/IR-cut filter on it. Blocking IR keeps the guide star tighter and improves centroid positioning in PHD2.
You mentioned saw-toothing what gear are you using, and what aggression levels?
Sometimes that pattern shows up when the guide aggression is a bit high or when min-move is too low especially if it’s too low. Min move i adjust depending on seeing.
I’ve guided with both PHD2 and MaximDL, with and without AO, It’s alway the same fundamentals. PHD2 differs because you can select different algorithms. Maxim DL just works. I’ve lost Maxim DL due to PC death and I refuse to buy it again.
My workflow:
  • PA first if that’s tight, everything else becomes easier.
  • No PA offset that idea died with film.
  • If I’m seeing oscillations, I increase min-move first; that normally calms the graph right away.
  • Then I fine-tune each axis:
    • reduce aggression until it’s under-correcting (slightly slow to hit target),
    • then bump it up just enough so it lands corrections cleanly.
  • Once RA and DEC are stable, I zoom in on the graph and continue to fine tune until it’s correcting only what’s needed no chasing seeing.
If you want to discuss this further just DM me.
CS!
Ashraf AbuSara · Dec 8, 2025 at 01:27 AM
I agree I love mine, I did tune the DEC backlash. Out of the box but in this price range it’s expected and has been true of all brands I’ve tried. my CEM70 has never given me a issue.
Rainer Ehlert · Dec 8, 2025 at 01:28 AM
CEM120EC
Wow how do they handle 3200 mm ?
I’ve got 2048mm 1624mm 550mm 328mm
It’s currently running the 550mm and I’ll swap out to the longer focal length for galaxy season I don’t anticipate any problems at all. Worst case I have a AO unit to hand. But that’s planned to go on the CEM 70 with RC 8 and RC 10 Astrograph for the 120EC
CEM120EC
I bought the CEM 70 last year the the CEM 120EC this year.
Rainer Ehlert · Dec 8, 2025 at 01:44 AM
There is a bit of an art to fine tuning backlash. I find the best average by listening to the motor as it drive the axis . Binding and stiction are the enemy here.
This is my post on my CEM 70
https://app.astrobin.com/forum/topic/206485/ioptron-cem70/one-year-with-a-cem-70#post-220039
Jesse Priolo avatar
At 550mm, you are probably rock solid.
My only concern would be moving up to longer FLs and the effects of SDE at very fine image scales. SDE won’t just show up in your PHD2 graphs - you have to go looking for it: Make a recording with PHD2 guiding corrections turned off, 0.5” exposures, at around Dec=0° & the meridian, then do a frequency analysis of the log file. The SDE is there, and you’ll see it.
My CEM70EC is unimpeachable at 910mm, but it does have about 0.4” peak-to-peak SDE, which has never been evident in any subframes at my current focal length. I’ve never tried a longer FL, and maybe never will. The mount guides reliably between 0.3-0.4” RMS on steady nights, somewhat better at higher declinations.
I’ve had three iOptron mounts: the CEM70EC, which is outstanding and reliable, night after night. I briefly had a CEM40, which had some wild Dec swings, that couldn’t be corrected by adjusting the worm meshing or belt tensions. I ended up having to return it, sadly. And then finally a CEM120 (vanilla, no EC) which, guided, is just as rock solid as the CEM70EC, without any risk of SDE. Two outta three ain’t bad.
I lust for a 10Micron mount, but right now, between the CEM70EC and the CEM120, which have both been more or less plug & play, I’m having a very hard time justifying a $12k-18k outlay.
Jesse Priolo · Dec 8, 2025 at 05:12 AM
I thought iOptron dealt with the SDE ? I tried to find more information on this but never could. I’ve watched the guide star uncorrected at 0.2s there is a slight pattern to the wobble but didn’t look too bad at 550mm. I have a SX AO which should catch the jitter I would never guide over 1000mm with out it. Once the AO is tuned it’s really really good if you can find a good guide star. The ToupTek guide can is very sensitive indeed. Comparable to my SX lodestar which was the gold standard 15 years ago. It’s still going strong
Jesse Priolo · Dec 8, 2025, 05:12 AM
Hi Jesse,
You touched a very delicate topic and yes, I am a big victim of SDE on both of my CEM 120EC2 mounts.
During two years having had the first EC2 mounts from iOptron I helped them to solve a lot of their software bugs but the SDE problem in my mounts is still rpesent and especially at 3200mm focal length it is visible in the RAW images but thanks to Russell Cromans BlurXTerminator my images do have round stars.
After a time they left me standing alone in the rain with no solution. That is the only reason why nowadays I would stay away from iOpton due to them not compying with their responsability.
At the beginning hte SDE was terrible and after updating until the last firmware version it looks like the SDE got smaller but it is still there.
OK, I am imaging at 0.245” arcseconds per pixel. Takahashi Mewlon 250S (Uncorrected Dall-Kirkham) with a ZWO ASI 1600MM Pro.
You can see my images under my profile.
Of course if I would have had the money I would perhaps bought 2 AstroPhysics but never a 10 Micron as there is no representative in Mexico and the US representative, well I will not say why I would not have bought 10Micron from him.
There are a few AstropHysics in Mexico and the service is quite acceptable. This are the issues one has to deal with living in a country far away from the technical possibilities.
All in all I would be careful to recommend the encoder mounts from iOptron but the mechanical mounts with NO encoders are very well built and so I would say reliable.
If one wants to buy encoder mounts from iOptron I would want to get a written confirmation that there is no SDE problem with them and if yes I have the right to return them at their expenses, or get them for a 3 month trial period.
Rainer Ehlert · Dec 8, 2025 at 04:42 PM
Hi Jesse,
Very fair points on SDE, and thanks for raising it clearly.
Right now I’m only running the CEM120EC with the Sharpstar Z4, so I’m at about 1.4″/px imaging scale and guiding around 1.1″/px with an OAG. At that scale and with my typical seeing (~1.5″) any SDE in the 0.3–0.4″ range would be buried under seeing/guiding noise, which matches your experience with the CEM70EC at 910mm.
So far I’ve seen no sign of SDE in real subs at 550mm. Eccentricity stays around 0.29 all night on 300–600s exposures. But I completely agree: that doesn’t translate to how the mount behaves at 0.25″/px and multi-meter focal lengths.
I’ve also run PHD2 at 0.2s exposures with guide output disabled just to observe the raw star motion. There’s a slight pattern, as expected, but it’s random enough that centroid rejection, averaging, and min-move easily filter out the outliers. Whatever micro-motion exists is well below the threshold that would influence guiding at my current scale.
The unguided high-rate test you described (0.5s, DEC ≈ 0°, meridian, then frequency analysis) is exactly how I’d characterise it properly when I move to longer FL. I appreciate you putting real methodology behind the SDE discussion that’s the level it deserves.
For anything above ~1500mm, I actually have a Starlight Xpress Active Optics unit ready. I’ve used AO before with long-FL systems, and it does a very good job cleaning up the high-frequency motion that shows up when you work below the seeing limit. So when my longer scope goes on the 120EC, AO will be part of the workflow.
And at 3m focal length with ~0.25″/px, I would definitely recommend AO as well. At that resolution you’re operating in a regime where both mount and seeing need to be exceptionally stable, and AO is a very effective tool regardless of mount brand.
For my current use case (550mm), the 120EC completely “disappears” as a variable predictable, repeatable behaviour every night. When I move to long FL, I’ll document everything honestly.
And yes once you get into that sub-arcsecond regime, the last bit of star shape really comes down to centroid stability and post-processing. Average centroid position matters, and tools like drizzle and deconvolution (BXT in “correct only”) can tidy up the residual signal that guiding and seeing can’t fully smooth out.
Clear skies, and thanks again for the detailed input.
Well written Helpful Insightful Engaging Supportive
John Tucker avatar
I recently purchased a CEM 40EC based on my excellent experience with Ioptron customer service on my previously acquired CEM25P. I have only gotten it out once due to endless overcast here in Florida and some obligatory travel.
On that occasion I struggled to balance the mount and was shocked to find that the counterweight bar was not 180 degrees from the dovetail saddle. (It wasn’t even close! Probably between 170 and 175 degrees!) Apparently on the CEM70s the precision which which this is set at the factory is so low that there is actually an adjustment screw for this, but mine was so far out of kilter that the range of adjustment provided by the screw was insufficient.
I sent the mount back to iOptron and they replaced the mount head without charge, but overall I was astounded to see a problem of this magnitude and obviousness on inspection leave iOptron’s factory. A Google search revealed that others have run into this problem as well. I was also surprised that iOptron required a copy of my receipt to apply the warranty to repairing what could ONLY be a manufacturing defect and a severe one at that. On a $5000 mount (which is less than the other mounts discussed on this thread, but still…)
Looking forward to getting out and trying out the mount, but I’m a little nervous given the fact that a defect of this magnitude got through inspection.
Read noise Astrophotography · Dec 8, 2025, 09:42 PM
If you still have the, open it in the PHD2 Log Viewer, then check the FFT frequence (using Analize selected RAW, in this case the full recorded time) and at 3.3 sec the arc sec value and that is your SDE error.
At the moment unfortunately I have no stats with fast exposures times.
📷 image.pngimage.pngYou will see a statistic like one below and 3.3s is the key value (at least on my mounts as I do not know what they have changed but the mounts cost now US $ 2,500.00 more than what I paid for it)
Below you can see my Peak To Peak 4.1” error unguided at 3200mm focal length
And here guided Peak to Peak 1.1” at 3200mm focal length
John Tucker · Dec 8, 2025 at 10:14 PM
Oh, that must have been extremely frustrating to discover totally understand the shock. The good part is that iOptron sorted it out quickly and replaced the head. At least that gives confidence that they stand behind the product when something slips through.
I actually thought the adjustable counterweight bar was a clever feature for fine-tuning OTA balance. On my CEM70 it was perfectly fine from the factory, but my focuser shifted the balance a little, so I added a small saddle weight and then used the CW bar to compensate. You really don’t need to move it much. I also made a slight DEC tweak, but that was just because the mount was built in a much warmer climate than where I’m using it now.
My CEM70 has been a very solid performer. I posted a full one-year write-up with tips, tricks, and guide graphs to show the methods work. I’ve owned many mounts since 2010 back then 14″ peak-to-peak PE was considered good. After trying a lot of brands, this is the first time I’ve genuinely felt like I got something of real value for the money. The CEM70 did so well for me that a year later I stepped up to the CEM120EC.
Hoping your next clear night goes smoothly once dialled in, these mounts can surprise you in a good way.
CS!
Read noise Astrophotography · Dec 9, 2025, 03:01 PM
This applies only for low altitude setup’s but not for compensating some DEC imbalance. This was at the beginning of this iOptron mounts a common problem.
One of mine had that too and it happens when the DEC assembly is not correctly seated on the RA axis pipe.
And even worse was the fact that I was not able to tighten it correctly and so the counterweight was dancing when passing the meridian but I was able to fix it by myself.
Astrophotography on a Budget: My €341.12 ($399) DIY Harmonic Mount Review & PHD2 Test
V3 Mini Performance: My Results After Two Months of Testing (Solar & Deep-Sky) Hello everyone, Lately, my inbox has been flooded with questions about the performance of my V3 Mini mount. After more than two months of rigorous testing, I wanted to...
Real-world mount performance metrics similar to author's V3 Mini testing approach.
Sep 11, 2025
Emcan Astro EM31 Pro : Mount review.
[size=200]Emcan Astro EM31 Pro Review.[/size] NOTE: I reached out to Emcan Astro regarding my intention to purchase the mount, and indicated that my intention was to provide a review of the equipment once I’d had some time with it. At this stage, I w...
Real-world mount review with guiding metrics similar to EM31 Pro review format.
Oct 12, 2024
Guidescope Recommendation for RCOS 20" ?
I work at our local observatory where we are fortunate to have an F8.2 RCOS 20" on an AP GTO3600 mount. We would like to upgrade from our current 80mm F6 guidescope to something with a longer focal length. With a focal length of 4115mm, I don...
Real-world guiding metrics data relevant to optimizing guidescope setup performance.
Aug 1, 2025
Guiding help
📷 IMG_3877.jpegIm currently out taking pictures as i post this. Ever since i got this 2600MM Pro, my guiding has been relatively bad. This current graph has been consistent for a couple months now. I cant understand why because the camera doesnt corr...
Real-world guiding metrics data relevant to troubleshooting mount performance issues.
Nov 28, 2025
EQ6-R Pro oscillations
I have been the very happy owner of a SkyWatcher EQ6-R Pro for the past 4 years. Until now it has served me well, driving my Esprit 100 and RC8 all round the Southern Sky, on typically one night every four. The mount is remain fixed between sessions ...
Real-world guiding metrics comparison for alternative mount consideration
Jan 14, 2024
