One year with a CEM 70
9 replies266 views
Read noise Astrophotography avatar
One year with the CEM70 exceptional results.
Tested at 550 mm and 1624 mm. Smooth as butter. Honestly, coming back into astrophotography after a break felt like stepping out of the Stone Age and seeing a TV for the first time.
When I went looking for real information on this mount, the “influencers” weren’t much help. Most of them spend 12 minutes with a teardown setup, then call it a “review.” Not exactly confidence-inspiring.
I compared the CEM design to a SWG. I have my reasons for not going SWG, but since I’ve never owned one, those reasons stay hypothetical.
I’ve been in this game since 2010 mounts, optics, cameras, active optics, even retrofitting a quartz encoder to a CGE Pro with a 5 Hz sampling rate to improve PE correction.
I tuned mounts for fun and tried every type of telescope before life took me away for a few years.
Coming back… there’s a lot of misinformation, wrong terminology, and user error. Trying to get a baseline before buying anything is like decoding an alien transmission.
So, if you don’t like long explanations, here’s the short version:
The CEM70 performs above its price class.
Just buy it. I get smooth sub-arcsecond guiding at 1.1”/px. My average seeing is 1.5–1.8”, with repeatable pointing accuracy.
Out of the box
The CEM70 performed extremely well. Zero drama. First thing that impressed me: the RA lock.
You release the RA clutch, then lock the RA axis with the supplied Allen key.
Brilliant idea it means you don’t stress the gearbox while mounting the OTA.
Shame it isn’t on DEC. I simply kept DEC unlocked and handled it extremely carefully. (I don’t recommend you do this unless you can genuinely manhandle the weight.)
The RA lock clamps both vertically and horizontally. Great for balancing — just remember to remove the key or the belts will express their feelings loudly.
Balance
I build my rigs to be inherently balanced. Rotators shift DEC slightly, but nothing dramatic. True 3D balance depends heavily on gearbox precision, and most consumer mounts have too much backlash for it to matter. A slight imbalance keeps the gears engaged and stops oscillation — this has always been best practice at this price point and below for all manufacturers.
The CEM70 only needs a slight imbalance.
Most mounts benefit from gearbox tuning out of the box, but that’s outside this post.
Short rule: your gearbox should sound linear.
Slewing too fast is the number one thing that kills gears, belts, and motor controllers.
And yes — I hear the oscillation in almost every YouTube video. Totally normal, but also a sign the slew speed is too high.
As a teardown mount or a permanent install, the CEM70 feels properly thought-through. I’ve used it both as a teardown and in the observatory.
iPolar
I used to contort myself into neck-destroying positions in wet grass or snow to look through a polar scope, trying to decipher everything without touching the mount. iPolar ended that nonsense.
My workflow when travelling to a new location:
  1. Let GPS set your lat/long before dusk.
  2. Use a broom handle to point the mount roughly north.
  3. Once the first stars appear, fire up iPolar — it works in lighter conditions than you expect.
  4. After initial alignment, then install the OTA.
If my guess is off, I’d rather correct a lightweight mount than a fully loaded one. I’m never far off.
Final PA: SharpCap + ATR26000M + native ToupTek direct-draw driver. Quick, accurate, repeatable. I run it a few times until I see ~00°00’10”. No more “PA offset” tricks — those died with film.
CEM70’s adjustment knobs are smooth with fine threads. People who struggle with DEC locks are overtightening them. If you’re using a tripod, let it settle before trusting any PA readings.
Polar alignment should be done quickly — speed improves accuracy. Iterate until happy.
Guiding
80% of YouTube users run PHD2 way too aggressive.
For me: Predictive PEC + Resist Switch, tight PA, low aggression.
Real-world guiding results (1.1″/px)
Across multiple sessions:
  • RA RMS: 0.21–0.31″
  • DEC RMS: 0.20–0.26″
  • Total RMS: 0.28–0.40″
  • RA Osc: 0.14–0.37
  • Peak excursions: all under ~0.7″
  • Zero lost stars
  • No RA/DEC limiting
For an imaging scale of 1.1″/px, everything stays well below the image scale and comfortably inside “excellent guiding” territory. The mount doesn’t hunt, doesn’t fight corrections, and doesn’t wander.
In simple terms:
the CEM70 guides under the image scale and stays there.
Cable management heaven
Built-in USB hub, power hub, and powered USB ports. This eliminates cable torsion and more importantly saves me from cable OCD and the resulting existential crisis. Thank you, iOptron.
Conclusion
After a full year teardown mode, observatory mode, short focal length, long focal length the conclusion is the same:
It performs. It’s consistent. It behaves. It doesn’t fight you.
📷 IMG_209DD695-6546-4114-BC52-44004FBA6E49.jpegIMG_209DD695-6546-4114-BC52-44004FBA6E49.jpeg📷 IMG_5466.jpegIMG_5466.jpeg
📷 IMG_5090.jpegIMG_5090.jpeg📷 IMG_7866.jpegIMG_7866.jpeg📷 IMG_EC82A11F-D8D9-4C14-9B4A-FCC845E21C74.jpegIMG_EC82A11F-D8D9-4C14-9B4A-FCC845E21C74.jpeg
For anyone curious about the sampling and performance:
I’m guiding through an OAG at 1.1″/px and imaging at 1.4″/px, which gives the guider slightly finer resolution than the main camera. That’s the ideal ratio it catches small drift before it ever shows in the subs. Guiding sits around 0.28–0.40″ total RMS (RA ~0.21–0.31″, DEC ~0.20–0.26″), so the tracking error stays well below the imaging scale. As a result the stars are seeing-limited, not mount-limited. Star metrics stay tight and consistent: eccentricity ~0.30, HFR ~1.9–2.2 px, FWHM ~4.4 px, and FWHM MAD ~0.24 px. This matches exactly what you’d expect from a mount performing comfortably under the image scale.
Well written Helpful Insightful Concise
bdejong11129 avatar
📷 5073.jpg5073.jpgMy expirence has been the same as the OP. Initially I ran this on the GEM45 that I bought with my Redcat 71. While the GEM45 performed ok, the CEM70 handles the C11 far better. Thus is important in galaxy season when the reducer and OAG are along for the ride. It adds up for sure. This mount lives outside and under a Telegizmo cover with a desiccant bag.
One thing that I love about the iOptron mounts is the sensors for finding zero position. Each night I simply uncover the scope, power it up, zero the mount which is polar aligned on the pier and we are running. I also share the GPS unit between the two as it really only needs it on power up to set location. This is super handy when I travel with the Redcat.
Guiding is solid and well under the image scale. Meridian flips are spot on and reliable. I can run it all night with no concerns.
I have had the CEM70 for about 18 months now and the GEM45 for 6 years. Both work perfect and have given me no issues. I have only performed yearly breakdown and lubrication cleanup and application. That is a super simple procedure and keeps things running smoothly. The software has what’s necessary and you dont need a support discord to run it and get the mount configured.
For me, iOptron has it right.
bdejong11129 · Dec 23, 2025 at 04:27 PM
Hi sorry just seen your reply.
outside all year round! Oh my .. mines lives in a dehumidified obs.. maybe that’s overkill?
Glad yours is also working well
Clear skies
AstroRBA avatar
bdejong11129 · Dec 23, 2025, 04:27 PM
Me too ! - CEM120 in my case; on a permanent mount, year round, on my outside deck with a custom Telegizmo cover. I can be in business within 5 minutes and shut down also within 5 minutes. Very little else to do except for occasional flat frames. I’ve even run it below the minus 10 low end temperature spec. I just set the slew speed at 512 with no issues.
AstroRBA · Jan 12, 2026 at 10:05 PM
I was so happy with the CEM 70 I bought the CEM 120 EC . It’s power on select target go to bed. I built a little box for mine.
AstroRBA avatar
Read noise Astrophotography · Jan 12, 2026, 10:13 PM
Looks good! I was thinking of getting a nice dome but if I spend any more money on astro right now I’ll be the one in a box! Ha ha!
AstroRBA · Jan 12, 2026 at 11:49 PM
Where in the world are you ? I am selling my 2.2m Pulsar Dome. It’s in Scotland I am in Sweden soon moving to the Philippines well soon ish next year
AstroRBA avatar
I’m in southern Ontario where I have no room for a dome in my backyard BUT I have been thinking about a dome for another scope that I have set up in California at a friend’s place.
