Dave Stearn avatar
I have been working on my workflow for OSC Narrowband using the Askar SQA 55 and the 2600MC Pro. I drizzle 2X and then Resample down 2X to the native resolution after DBE and BlurXT.
I use Bill Blanshan’s SHO Colorization script. In this case I used a pallet that combines the SII to HOO.
My biggest challenge has been the stars. These were the SHO stars but I plan to add RGB stars later this month.
Interested in a critique on how the stars look.
https://app.astrobin.com/i/vlqavo?r=H
Rainer Ehlert avatar
IMHO they all look good
bigCatAstro avatar
The stars look very nice. Rev H looks great.
Did you use the synthetic RGB Stars script?
Dave Stearn avatar
bigCatAstro · Dec 6, 2025 at 02:49 AM
Thanks! I use Bill Blanshan’s script combines the linear SHO stars into the NB image.
My biggest challenge was processing the undersampled image. I drizzled 2X the ran Auto DBE, BlurXT and then resampled down to the native resolution before further processing.
bigCatAstro avatar
Dave Stearn · Dec 6, 2025 at 04:10 AM
Awesome, well, it looks great. Good job!
alpheratz06 avatar
I don't if my comment is relevant, but I use a slightly different approach :
  • Kill the stars and process the nebula stuff then
  • Either use the star pattern from multiband with SPCC to restore the original colors
  • Or (better) use a full Osc image with shorter exposures to have a full color star field SPCC then optionally kill the nebulae
  • Final blend starless plus stars with the ~ trick
Larry Cable avatar
alpheratz06 · Dec 6, 2025, 07:33 AM
this is also the workflow I adopt too
Dave Stearn avatar
alpheratz06 · Dec 6, 2025 at 07:33 AM
When I capture the RGB stars then I will process the RGB image and combine the RGB stars into the starless NB image. The current image was all NB so I combined the NB stars using the script. My main concerns were regarding the shape of the stars. The colors will be best using RGB stars.
The star shaps look great, even with extreme pixel peeping which is what you have to do to even make a judgement.
bigCatAstro avatar
Tony Gondola · Dec 6, 2025 at 02:43 PM
I agree, the SQA55 is pretty spectacular with nice star shapes.
SonnyE avatar
Sorry Dave, to me they look over processed.
Why do I say that? I was looking at some of your other images and if you notice the stars do vary in sizes and color and intensity.
In this case, to my eyes the stars look too small.
Beautiful image! But you asked about the stars and that’s what I think.
Concise
Dave Stearn avatar
SonnyE · Dec 8, 2025 at 08:22 PM
More likely due to the wide field view of the SQA55.
Star colors look nice. I assume that is what you are asking about? Or something else?
I like to blend my SHO stars with a custom PM to make nice gold and blue stars. You can use this math. It’s also a good blend option for narrowband in general.
R=.4*Ha + .6*Sii
G=.4*Oiii + .3*Ha + .3*Sii
B=Oiii
Dave Stearn avatar
Chris White- Overcast Observatory · Dec 9, 2025 at 12:38 AM
R=.4*Ha + .6*Sii
B=Oiii
Thanks, The colors and the star shapes. I use Bill Blanshan’s PM script which combines the linear nb stars using a similar formula but you can also adjust star size and saturation.
Frédéric Ruciak avatar
Hi Dave,
IMHO, and as a pure aesthetic consideration, the stars are too small to me. If this is what you intented to achieve, that’s good and your image is really beautiful but have you tried with the field stars shining a little bit more ?
Clear skies, Frédéric
Tommy Mastro avatar
Frédéric Ruciak · Dec 11, 2025, 10:05 AM
Hi Dave,
I’m the same way with my images. Historically, I always went too far with the star reduction. Since I started reducing them to half of what I used to, I like my star fields much better. I feel it helps the star color pop a little more as well.
Well Written Concise Engaging Supportive
NGC7000 and IC5070
Interested in critiques on my latest SHO image. https://app.astrobin.com/i/oxcn9d
OSC narrowband workflow with SQA 55 and 2600MC Pro directly relevant.
Oct 23, 2025
Heart and Soul nebulas processed with SHO colorization - feedback welcome
I just completed processing the Heart and Soul nebulas in Pixinsight using Bill Blanshan’s SHO Colorization scriptlet. The pallet is an SHO using the S+HOO option. 60 hrs of integration time with OSC and dual nb filters. RGB stars were added using Bi...
Uses same SHO colorization script and palette technique; directly comparable processing workflow.
Dec 21, 2025
Drizzle/Binning/Resampling
Fellow Astrophotographers, i am having a day off and thanks to the bad weather no new data to process, so I decided to make a comparison of (the same) differently sampled luminance data of my latest project. what do we look at? https://www.astrobin.c...
Discusses drizzle processing workflow with similar equipment and sampling comparisons.
Dec 22, 2024
[RCC] Seagull Nebula
Please provide your critique on the Seagull Nebula. It is imaged in dual narrowband using OSC. So far collected ~7-8 hours using L-extreme filter and 1 hr for RGB stars. The nebula is using the filter, while the stars are RGB (no filter used). Planni...
OSC narrowband workflow optimization; relevant to author's acquisition and processing strategy.
Jan 26, 2025
Drizzle when undersampling?
Hey All, I recently came across the concept of over/under sampling. Checked out my rig on astronomy.tools and see I am under sampling quite a bit. In this case, I have seen that drizzling could help this, to some extent. Tested it out and it seemed t...
Addresses drizzling and resampling strategy relevant to author's 2X drizzle workflow.
Feb 27, 2026
