Nexstar hand controller firmware update failed, display showing odd squares
13 replies51 views
Barry Ziober avatar
trying to update firmware on nexstar hand controller, every time i try it says update unsuccessful, tried resetting and but didn’t work, then tried use newest cfm but that didnt work, contact celestron support but they are having holiday party today and closed down early, any suggestions how to update, now my controller has just a bunch odd squares on display. has anyone else seen this and got passed it? thanks much
bigCatAstro avatar
Barry Ziober · Dec 5, 2025, 06:30 PM
Have you tried pressing the number 4 and the Celestron logo button at the same time when resetting the hand controller?
Well written Concise
Barry Ziober avatar
celestron told me to hit 0 when turning on mount, i will try 4
bigCatAstro avatar
Barry Ziober · Dec 5, 2025 at 07:28 PM
🤞good luck!
Barry Ziober avatar
thanks but no luck, frustrating
bigCatAstro avatar
Barry Ziober · Dec 5, 2025, 07:37 PM
Ok, yes, that’s absolutely frustrating. I think the hand controller is bricked, but you may be able to force bootloader mode on the HC and see if you can “reflash” it. I’m assuming this HC is one with a USB port at the bottom of the wand and not a RJ45 jack, right?
Helpful Concise Supportive
Barry Ziober avatar
yes usb at bottom
bigCatAstro avatar
Barry Ziober · Dec 5, 2025, 08:13 PM
yes usb at bottom
Alright, this may take a while and, of course, not work—however; you may be able to recover the HC and force it to reflash the HC in bootloader mode. Try these steps:
Step 1 Disconnect Everything:
  • Power off the mount and disconnect the USB cable from the HC.
    Step 2 Access Bootloader:
  • Reconnect the HC into the Mount ONLY
  • Hold down the Celestron Icon Button and the number 7 button
  • Keep holding down those buttons and turn on the mount (note you are ONLY connected to the mount at this time)
    The HC should start flashing and say something like “BOOTLOADER” or “BOOTLOADER MODE”
    Step 3 Connect HC to Laptop:
  • Reconnect the HC via usb cable to the laptop/PC.
  • Launch Celestron Firmware Manager
    Step 4 Click “Seek Devices” and “Update”
  • As noted in the step, see if you can select the “Seek Devices” button and the “Update” button.
  • Let it rip.
    These steps may not work, but it’s worth a try. If it doesn’t then you’ll probably have to get another hand controller.
Barry Ziober avatar
thanks much for trying, my problem is i never see this “The HC should start flashing and say something like “BOOTLOADER” or “BOOTLOADER MODE”” but just a bunch of weird squares
bigCatAstro avatar
Barry Ziober · Dec 5, 2025, 08:50 PM
Well, that’s a bummer. I’m out of ideas for trying to revive the HC, might need to just order a new one.
Well written
Rick Veregin avatar
I’ve seen those deadly squares in the past too. It has been a long while since I did this, I will never try a Celestron update again unless things are totally failing. I still have that mount, but don’t use if very much anymore.
I wish I had taken good notes, or any notes that I could find now. I do have the general instructions though. And my recollection may be off, but here is what I recall.
  • Change to a really short top notch USB cable—this I know was when I was at my wits end and it finally worked.
  • Delete the CFM you had.
  • Disconnect the HC from the mount.
  • Connect the HC directly to your computer using the USB cable.
  • Launch the Celestron Firmware Manager (CFM)
  • Seek Devices in CFM, it will find the HC and show a "BOOT LOADER" message.
  • The Celestron Logo and 4 may help, but I don’t recall when to do this.
  • Start the Update and DO NOT disconnect the cable or power off anything until CFM reports success.
  • Verify by disconnecting and reconnecting the HC to the mount, then check the firmware version in the HC menu.
  • If the BOOT LOADER doesn’t show up, ignore it, and try pressing the update button anyway.
Some of the above worked, some maybe were things I tried but did not work. I can tell you I got it eventually, not sure how many times I tried, trial and mostly error, but I definitely tried the same and different things over and over to get it.
Good luck
Rick
bigCatAstro avatar
Rick Veregin · Dec 6, 2025 at 02:09 AM
Good luck
Rick
I haven’t seen this method work before, but if it does that would be awesome!
Rick Veregin avatar
bigCatAstro · Dec 6, 2025, 02:18 AM
Good luck
Rick
I haven’t seen this method work before, but if it does that would awesome!
LOL—I may be recollecting what didn’t work, rather than what did: when one does something two dozen times wrong, and only one right, one is more likely to recall much later something that didn’t work…🤞🤞
bigCatAstro avatar
Rick Veregin · Dec 6, 2025 at 02:58 AM
Good luck
Rick
Might as well try everything!
has anyone tried the Celestron star sense auto align? any success? is it worth using?
Nexstar hand controller firmware update failed, display showing odd squares — trying to update firmware on nexstar hand controller, every time i try it says update unsuccessful, tried resetting and bu
Dec 4, 2025
QHY10 on Windows 11
Has anyone gotten their QHY10 drivers to work on a Windows 11 machine? I have tried several suggestions found on Cloudy Nights to no avail. it may be time to retire the camera.
Hardware driver/firmware update problems on Windows 11 astronomy equipment.
Jul 23, 2024
ASIAIR+ has gone crazy
Hi all, this afternoon it seemed that the clouds had gone and I have mounted the equipment, when I started with the autoguiding there came a moment when the stars deviated a couple of seconds, as if the mount stopped tracking and then abruptly return...
Firmware update troubleshooting relevant to mount control system issues.
Nov 11, 2024
TPA Plugin Update Fails to Install
Today I tried to update the TPA plugin and I got a messsge error that the update failed. I uninstalled the TPA and when I tried to install it back it also fails to install. I then uninstalled NINA and reinstalled it and the problem persists. I tried ...
Both involve failed updates and reinstallation attempts with persistent issues.
Aug 2, 2024
How to Connect to AM5 from ASIAIR+ ?
Hi everyone, I’m trying to connect to my AM5 mount from my ASIAIR+ via WiFi, but I keep getting a connection error. This is what I have done so far. 1. Powered up the AM5 and connected the hand controller. 2. Used the SkyAtlas app to update to the la...
Nexstar hand controller firmware update issues similar to mount connection problems.
Sep 30, 2024
