Moravian Flat Frames
3 replies•91 views
cardiofuse avatar
I have a new Moravian C3 6100 Pro
Can someone tell me how many ADUs to shoot my Flat frames; I see the gain is set to .79 and I use Artesky at 5 sec exposures?
Bill McLaughlin avatar
Basically whatever gives you a good histogram central to the dynamic range with no fully saturated pixels. I use the histogram tool in NINA to find the combination of panel brightness and exposure time that does that for each filter.
cardiofuse avatar
Thank you. Do you know how to set the gain on the C3 6100?
If it is like the C3 26000 then either in NINA or in the driver.
Wanderer astro flat panel V4 - weird numbers with NINA
Hi guys. Recently I bought a Wanderer astro flat panel V4 for my FRA 400 that will go remote in september. Last night I finally installed it and got a chance to put it to work with NINA. I obtained some strange exp time / brightness numbers and I'...
Discusses flat frame exposure settings with different flat panel equipment.
Jun 13, 2024
Gradient in dark frames
Hi everyone! I recently bought the Player One Poseidon C Pro camera and after a very long period of cloudy nights it finally cleared and I got to try it. When taking the lights everything was normal. When the sun rose again the pictures got very satu...
Discusses flat frame issues with different camera; relevant to flat frame troubleshooting.
Mar 5, 2026
Help - Vertical bands - Flats is the culprit - Can someone help me understand what's happening ?
Hi, Recently I am noticing some weird band like structures in my images. My setup - QHY600PH-M + Takahashi Epsilon 180ED + Astronomik Filters. I Captured RGB images in QHY 2CMS-1 Readout mode at 56 gain for broadband images. (mistake) After noticing ...
Addresses flat frame problems causing image artifacts; directly relevant to flat frame technique.
Nov 23, 2025
