Initial results on the AP 155 CS
3 replies147 views
Bill McLaughlin avatar
NOTE: Repost of an evaluation I posted on the AP forum.
After weeks of typical Pac NW crap weather I got the system calibrated and tilt adjusted and a model and all the other prep. I selected double cluster since it was quick and I wanted to do optical evaluation. Not exactly Astrobin level for a final image - that will have to wait for summer - but plenty good for evaluation.
The initial look at the monochrome RGB and Ha bands in the individual frames seemed to show slight elongation in the corners but I went ahead and did flats and darks and calibrated and combined them. Roughly 25 frames per band, 60 second unguided RGB and 600 sec Ha, also unguided (not shown here). The 1600 can handle the 155 unguided, which is nice.
The results you see have been calibrated, registered and combined using Normalize Scale Gradient and the gradient from our nearby small town removed with Graxpert and then histogram stretched and noise reduced. There was no aberration correction or other processing of any kind. The apparent slight distortion had vanished, despite still being present in the mono reference frame (and the rest of the subframes). This was true for all bands. Dynamic PSF showed all stars in corners and center round at over .89 for all I checked (and most were higher).
This is truly the best I have ever seen from any of a fairly large number of refractors I have used in 30 years!
Arun H avatar
But did it make the Popular Mechanics list though? That is the true test!
Rajat Kumar avatar
Arun H · Dec 4, 2025, 12:19 AM
Nice first report Bill. Looks like Rolando delivered.
Well written Respectful
Star shapes on Samyang 135mm
I have adapted the lens using the Vetec IMX571 camera. The problem is the the bad star shapes in 3 of the corners. In 1 corner it looks prolonged, another corner it has a tail. The tilt is 11 % according to ASTAP. On my EOS 6d my stars look good. I a...
AP 155 CS tilt adjustment and calibration; relevant optical tuning experience.
Jun 17, 2025
Tilt adjustment in galaxy season?
I'm just getting into serious tilt adjustment and commonly see it advised to do adjustment, at least initial adjustment, on rich Milky Way star fields. Is there any way to do this during galaxy season in the northern hemisphere when there aren...
Discusses tilt adjustment and calibration procedures for astrophotography systems.
Mar 25, 2025
Evident tilt only when using Ha filter??
I have been observing a strange situation where I can notice some tilt when taking exposures through the Ha filter, but not through other filters. I finally decided that that was annoying enough to use a tilt analyzer (I used ASIStudio in this case -...
Tilt adjustment procedures directly relevant to diagnosing filter-specific tilt problems.
Aug 5, 2025
Flat sample with Orion UK ODK12
Hi, I’m looking for a flat subframe sample acquired with this telescope and a full frame sensor (or Aps-c it’s also ok). Any channel will do. A jpg posted in the forum is fine. Thanks a lot Stefano.
Initial results post likely includes calibration frames and subframe samples.
Jan 8, 2024
Which imaging acquisition and processing techniques could I learn more about to increase image quality and accuracy?
Hello, I use a full-frame mirrorless camera, I mostly do daylight photography, some night photography and astrophotography too. I did hightlight in bold keywords to make it easier to scroll thru, for those that don't want to read most of my post. Bef...
Relevant for learning astrophotography processing techniques to improve image quality.
Dec 29, 2025
