RASA11 (V1) - Strange severe tilt
18 replies306 views
Georg N. Nyman avatar
Over time, the performance of my RASA11 (Ver1) seems to get worse. I am still able to correct most of the optical problems with software like the BlurXterminator, but the scope needs an overhaul I guess. To demonstrate, what I mean, here a screenshot of a stack, taken with my ASI2600MC most recently. Analysis done by ASTAP - the tilt is enormous and seems to be very strange - tilt looks normally different - but why this strange shape - two sides extremely different compared to the other two?
Have you any idea what this might have caused and how to correct it? I have absolutely no clue what to do with that strange shape!
Thanks for any constructive feedback!
Georg
Rainer Ehlert avatar
Reading that analysis for me that is not tilt.
Just imagine take a paper and lift it on the two opposite corners.
Is that a stacked image or a single one?
Is this a telescope where the camera is where normally a secondary mirror is?
I am trying to find an explanation for that…
Please post a full size image in order to look at the star shape.
Rainer Ehlert · Dec 3, 2025, 05:05 PM
It is a stacked image
The telescope is a RASA11 - the camera is in the primary focus, no secondary mirror
full size imge - 300MB, not possible, here is a screenshot
📷 image.pngimage.pngthe upper left and the lower right corners are similar - the stars are donuts, the lower left and the upper right corner - the stars are more or less in focus and round
Hi Georg,
Sorry can not see anything as it is still to small, but from your explanation for me the only explanation is either a strangely pinched main mirror or the chip of the camera has bend up two corners and that is why two opposite corners have bigger stars the the other two.
Did you understand my analogy of the piece of paper being lifted on two of the corners?
Tilt would be only the difference between two parallel sides but never two opposite corners. Maybe 3 corners much different to 1 corner
Another thing I was thinking is perhaps a slight field rotation and PixInsight did not Align correctly the images.
This has happened lately a few time in my images.
I am just throwing ideas onto the table …
I am not an expert at all but have analysed a lot of images with the help of some friends here in Mexico
Rainer Ehlert · Dec 3, 2025, 05:48 PM
I agree and I understood your analogy as well!
I looked the start and the end of the night - well, that “double-tilt” is the construct of the integration of all files before and after meridian flip averaged. Why - well, at the start of the night the analysis shows one-sided tilt and at the end of the night, after meridian flip, it was inverted. That means, I have strong tilt on one side (fortunately nothing more serious), which I can correct with a tilt-corrector.
Here you see the screenshots before and after meridian flip
📷 TILT RASA ASI2600MC single fits start of night.pngTILT RASA ASI2600MC single fits start of night.png📷 TILT RASA ASI2600MC single fits end of night.pngTILT RASA ASI2600MC single fits end of night.pngI guess, that should be the solution for my problem - what to you think - does this sound reasonable?
Georg
Uuh, that does not look good. Never ever seen something like that. I had also a strange pattern but that was 3 corners quite similar and one completely off.
Have you checked all frames? I know that is cumbersome but would shed some light on it.
Do you have another camera to make some tests and so we can rule out the camera?
Is there a way to rotate the camera in front of that scope and so we could see if this pattern rotates too which would mean it is the scope. If it does not rotate it is the camera.
I can't see much but looks like the camera is tilted along one of the diagonals, nothing too uncommon. One corner is too near and the other too far.
andrea tasselli · Dec 3, 2025, 06:30 PM
I can't see much but looks like the camera is tilted along the diagonal, nothing too uncommon. One corner is too near and the other too far.
Very good point. Did not think about that. That happens when one corner is in front of the focus plane and the other corner is behind the focus plane which gives us unfocused stars. Shame on me.
But that must be a hell of a tilt.
Well written Insightful Respectful Concise
Oh, well, that an excellent idea - I did not think about that - of course, if the camera is tilted along its diagonal, two edges are similar - just the opposite way!
And of course, for a RASA with f/2.2 a slight diagonal tilt induces a large amount of tilt, because the depth of field is tiny… about 20-30 micron only, I think…
Shame on me as well, I did not think about that!
Thanks Andrea - your feedback is always very helpful!!
Well written Insightful Respectful Concise Supportive
churmey avatar
Had the same thing happen recently with a 2600MC. My 2600MM worked great with my Rasa 11 V1 w/ UFC right out of the box but when I went to put on a second 2600MC, I had this diagonal tilt. I spent no less than 2 hours working with the 2600MC’s tilt adapter trying to find the right combination. After approx 30 tries, I got it lol. If you don’t already know, small adjustments go a long way.
Supportive
ScottF avatar
What control program do you use? If you use Nina , it has a great plugin hocus focus. Run the sensor analysis program and it will show you exactly what is wrong and how to fix it, assuming it isn’t something strange.
Alan Brunelle avatar
Only could read this very quickly, so I may be off-base. But would it not be best to assess this sort of issue with individual subs? And as such, you might generate a separate imaging session to pick a field that has stars that are bright, so that you can take very short subs, to minimize seeing issues, etc.
Edit: Stacked data will likely cover up any true optical defects and may well make non-optical problems even worse. So single subs need to be studied. And that is how Hocus Focus works, not on stacked data.
My being off-based aside, then if you have an issue that is unresolvable with processing, as a former RASA owner, I have the similar experience of this sort of thing and the solution is likely going to be sending it back to Celestron for them to realign everything. If you want to do a collimation yourself, be prepared and be skilled. At best, you may just get the amount of improvement you need, even if not perfect. Worst case, you send it back to Celestron.
Still on hold with my Medicare Advantage plan… I should add, in my experience, a possible cause of the gradual image degradation that you are seeing may well be caused by the fact that the central housing for the corrector plate mount for the secondary optics may be getting loose. This can cause the secondary optics housing to 1. rotate (if you repeatedly contact the housing for the typical purpose of adding or removing filters, cameras, etc. Especially, removing the main adaptor compression ring, which can get bound if tightened too much.), 2. translate, by simply sliding across the corrector plate because of its weight. For these to occur, the tensioning ring and gaskets that hold the secondary optics would have to get loose. This can happen over time because of differential heating and cooling, etc., just like anything that is screwed will get loose. I have to say that I did rotate my secondary a bit even when it was tight because of how tight the camera adaptor was. Even the slightest movement, rotation, or translation can/will mess up the alignment. In such a case, if you were to even mention that the secondary may have slipped to a person at Celestron, they will immediately tell you you need to send it in for collimation.
If you read the RASA white paper, you will have learned that the building of a RASA includes a rather detailed matching of primary, secondary and corrector plates to get the telescope to even be collimatable. This no doubt includes slight aspheric inconsistencies in each of these elements to which rotation could screw things up. But I won’t get into collimation of a RASA because I cannot help. I have seen some DIY RASA stuff online.
Helpful Insightful
Alan Brunelle · Dec 3, 2025, 11:56 PM
Alan, you are absolutely right - see one of my previous posts. I checked the tilt in single subs as well - before and after the flip and the reverse. That means, it is a strong one-sided tilt which is summed up to a double-sided one in the stacked image, the one, which I posted initially.
Rainer Ehlert · Dec 3, 2025, 05:46 PM
This is incorrect. Tilt can absolutely be along the diagonal of the chip. One corner would be intrafocus and the opposite diagonal corner would be extrafocus. The other two corners remain at the same plane as the center, and are at focus.
George,
You need to understand that tilt analysis is using HFD as a proxy for measuring tilt. There are several factors that influence the HFD measurement of a field, focus being chief among them. When performing tilt analysis with a single frame, and comparing that to another single frame you are assuming that both frames are at perfect focus. I’m talking about microns of focus position here, especially with fast systems like RASA where your CFZ is very small. So any focus shift that makes your focus a few microns away from perfect, such as thermal changes to your system, or mirror shift, will amplify or possibly invert your tilt analysis. You also have the compounding effect of field curvature on tilt analysis due to backspacing error (or optical system limitations on field correction). The only real way to perform a robust analysis of system tilt is to analyze a focus bracket run using ASTAP Hyperbolic Curve Analysis, or NINA Hocus Focus. You may find this information helpful as you navigate the topic of tilt and spacing. https://www.dropbox.com/scl/fi/dotyh2gzmojmy75p5kvby/2025-09-12-3nd-Revision-A-guide-to-fixing-tilt-and-spacing-with-objective-analysis-Chris-White.pdf?rlkey=ek4ys23120p9hujidi9xjfnh9&st=r3t9vd3f&dl=0
Well written Helpful Insightful Engaging Supportive
Chris,
Thank you for your feedback! I have contacted the German importer for Celestron products and they confirmed that they have a skills and tools to overhaul the RASA11. In their opinion it would be very advisable, that I keep my hands off the scope as it is very delicate to put right… well, it will leave me about 6 weeks without it, but I think it is worthwhile to go that route and ship it to their shop.
Well written Respectful
Chris White- Overcast Observatory · Dec 4, 2025, 11:53 AM
You are right and I already admitted that I was wrong…
Issue in ASIAIR autostretch preview, or actually FITS corrupted?
Good morning everyone. For some time now, I’ve been experiencing a strange issue during acquisition with ASIAIR PRO using the ASI678MC on long exposures. The phenomenon is particularly easy to isolate and observe by acquiring dark frames, so I’m shar...
Author uses ASI2600MC camera; candidate discusses ASI678MC acquisition issues with ASIAIR.
Aug 14, 2025
Inconsistent tilt results from ASTAP despite stable FWHM values
I was analysing about 50 recently taken 60” subs (luminance) from one of my setups and out or curiosity checking the tilt values - strange result: All subs are within a reasonable FWHM range (2.0-2.4), but their tilt varies between almost 0 and sever...
Author reports strange tilt analysis from ASTAP; candidate directly addresses inconsistent tilt results.
Mar 24, 2026
Star shapes on Samyang 135mm
I have adapted the lens using the Vetec IMX571 camera. The problem is the the bad star shapes in 3 of the corners. In 1 corner it looks prolonged, another corner it has a tail. The tilt is 11 % according to ASTAP. On my EOS 6d my stars look good. I a...
RASA11 tilt problems corrected with software; directly relevant to your tilt issue.
Jun 17, 2025
Rare pattern stars on samyang 135
Hello. I purchased from second hand this lens a few weeks ago but I have not been able to test it until these days. I'm noticing some very strange patterns in the stars, like a rhombus or teardrop shape. I have previously the same lens but I have...
RASA optical performance degradation over time; your lens shows unexpected aberrations.
Dec 2, 2024
Celestron RASA V1 versus V2: practical differences and value
Hi everyone, I’ve been looking into the Celestron RASA telescopes. Recently, I came across a V1 offered for about half the price of a new V2, which made me curious about the practical differences between the two versions. From what I’ve read, the V2 ...
Author owns RASA11 Ver1; candidate compares RASA V1 and V2 models and value.
Mar 17, 2026
