CDK14 telescope having color splitting issues on stars
9 replies282 views
Anthony Grillo avatar
More issues with cdk14 stars! First it was wonky stop sign stars and blob artifacts due to a faulty primary and secondary mirror that planewave had to take the scope back and regrind and coat both mirrors to correct, then it was flaring and weird diffraction spikes due to holes in the upper truss ring that I needed to cover to sort of fix (still have weird flaring) now its color splitting on stars!!
📷 mehstars.pngmehstars.pngAt first, I thought it was the reducer but after I went back and looked at other data, I realized I had separation on older data without the reducer, so now I’m stuck between the corrector and atmospheric dispersion if I imaged too low sometimes.
I do have some tilt with my 2600mc pro that I have been using to collect color data but its only at 3% according to astap and not that bad at all compared to both my 2600mm setups that show a whopping 13% (thanks zwo filter wheels!!) I haven’t fixed the tilt yet because like clockwork all my issues seem to pop up when its winter lol
I didn’t think tilt would cause the splitting on all the stars that’s why I wasn’t convinced it was causing it.
So, I came here to ask the pros what you think the issue could be!
If you look at my latest images nearly all of them have the splitting except my IC10 image where it isn’t as bad as it has been.
V avatar
Tilt and UV or IR wavelengths in the mix can cause this, I currently have this issue due to my 2400 having an AR window instead of a UV IR cut, but with my tilt issues solved, the IR remains the issue. I noticed that the fringing is roughly inline with the RA axis, and as such, I suspect it’s caused by atmospheric density changes causing chromatic shift; which with an ultra-wide bandwidth from running my system unfiltered, causes some pretty gnarly issues.
Other nuisance is the presence of UV and IR microlensing halos around my stars, and the washing out of my colors from having pretty fast equalizing of CFA transparency on the 2400 past 700nm. I’d really like to hope this isn’t the issue since you’re using a Chroma L filter, but with it’s bandwidth there is that extremely slim chance that it could be a symptom, but not a cause.
A bit more tilt adjustment, and maybe a tighter UV IR cut filter will fix the issue. My only concern is that in your images, it appears to be radial to center versus mine which is all coplanar, which to me screams mirror spacing or backfocus issues.
Anthony Grillo:
📷 mehstars.pngAt first, I thought it was the reducer but after I went back and looked at other data, I realized I had separation on older data without the reducer, so now I’m stuck between the corrector and atmospheric dispersion if I imaged too low sometimes.
Lateral CA is rather common feature for some optical systems employing correctors and has nothing to do with sensor tilt, if this is what you're showing (the variation needs to be a function of the field angle). At a glance I'd put the onus on the alignment of corrector but obviously you can't run without it.
andrea tasselli · Nov 29, 2025, 08:04 AM
Anthony Grillo:
Thanks for the insight!! I went back to my IC10 data and WR134, the ic10 color was captured with the 2600mc pro and the wr134 with chroma filters. Neither show the splitting like my 7217 data (color captured with filters) and my ngc672 data (taken with 2600mc pro)
Only difference so far is exposure time even though ic10 and ngc 672 were with the reducer and wr134 and 7217 were without it.
I just used those examples to show that I got the splitting with and without the reducer.
I don’t see what else is different except for exposure time unfortunately, so at the very least that rules out the corrector right??
Hard to say, it might be more obvious with either bright stars in the field or longer exposures. Luckily BXT should be able with this sort of error.
John Hayes avatar
I never saw lateral color with my CDK20. Take the reducer off and confirm that you are seeing the problem with the base telescope. Is the color separation showing in a radial direction about the center of the field? The only thing that could be causing this problem in the base telescope is the field flattener/corrector located in the baffle tube and it would be something that you would have to discuss with Planewave. Sure BXT can fix it, but it is generally bad practice to fix fundamental optical problems with software.
If the base telescope is fine and you only see the problem with the reducer, then it’s the reducer. In either case, my recommendation is to always ditch any reducer. If you want a bigger field, get a bigger sensor. Reducers can work but most of them cause all sorts of difficult to fix problems and they aren’t worth the trouble they cause. Keep your optical system simple and you’ll be happier in the long term.
John Hayes · Nov 30, 2025, 12:13 AM
Thanks john, always helping me out when I’m second guessing myself ha-ha. I think I can say with some certainty that it is the reducer; any color separation I had before that I noticed was only with the weird flaring I had around some of the brighter stars as you can see in my image of ngc 7217, that image was base configuration at full focal length with chroma filters. whereas my ic10 image was reduced and color taken with a 2600mc pro.
The separation is pretty much the same direction throughout the field, doesn't change about the center of the image at all.
I really wanted the reducer set up to work for the speed, at f4.8 the cdk essentially becomes a pretty neat astrograph but it also brought with it a host of other issues because of the tight back focus of the cdk reducer.
John Hayes avatar
Anthony Grillo · Nov 30, 2025, 02:34 AM
Watch my “Quest for Aperture” talk on TAIC. If you are sampling for resolution, the F/# doesn't matter. That reducer is just for field size. If all you want is field and you don't care about resolution, you don't need that 14” scope!
John Hayes · Nov 30, 2025, 02:43 PM
I will watch that right now!! resolution is way more important to me than field size since my main interest lies in imaging more compact objects or specific regions of the more extended nebulous regions, I’ve never really worried about FOV to much when considering my observatory set ups.
Rick Krejci avatar
Were the cases you were seeing lower in the sky? If they’re all the same direction, atmospheric dispersion could be at play. Just a thought.
Well written Concise
Are these halos caused by good seeing and diffraction patterns?
These aren’t filter or reflection halos, correct? I am now beginning to think This is caused by exceptionally good seeing and what I’m seeing is part of the airy disc?? or some other diffraction pattern?? These halos do not pop up on other nights and...
Author questions collimation issues; color splitting could explain halos.
Sep 29, 2025
Weird star halos on new cdk14.
hello all!! About a couple weeks ago I received my new cdk14 and since then every time I have imaged with it, I have been getting these halos around Brighter stars. I have been discussing this with others, and it seems narrowed down to either reflect...
CDK14 telescope having color splitting issues on stars — author has CDK14 with star issues
Dec 18, 2024
Odd shapes in stars - Pinched optics or something else?
I just replaced my 8” SCT for a SkyWatcher Esprit 150. So far I am happy to report that the first light shows the field is 100% flat. BUT…(there is always one in this hobby…) when I look closely at the frames, the bright stars have 6 point spikes on ...
Color-dependent star artifacts could relate to mirror or optical alignment problems.
Jan 18, 2025
Perplexing Issues with CDK14
Hi all, I've encountered two perplexing issues with my PlaneWave CDK14, that I would love some input on. I am chatting with Bill Dean over at PW on this, and while we both try to get to the bottom of it, I would love thoughts from people on this ...
Author experiencing CDK14 star issues; directly relevant to diffraction spike problems.
Apr 15, 2024
OOUK ODK10 mirror spacing & corrector placement
Hello, I acquired an ODK10 from an German Observatory for a very good price and received it today. It’s used and has seen better days, but I want to see if I can make it work. Mechanically it looks OK and the Observatory fixed the weird unstable cork...
CDK mirror issues similar to author's primary/secondary mirror problems.
Dec 23, 2025
