Help to check Hocus Focus result.
5 replies166 views
Erik Guneriussen avatar
I am new to Hocus focus, just run my first atempt. When checking the tilt degree 0.023 against chatgpt is says very good. Is it actually that. Stars in my images is good when analyzed whti CCDInspector. Can sombody give me some comments/help to explain the result?
My setup is Skywatcher Esprit 150ED, Player One Poseidon MM Pro, Player One Phoenix with 2” Baader CMOS optimized filters. ZWO EAF, Skywatcher EQ8 Mount
Erik
It isn't 0.023% it's 0.023 degrees. As for the rest you're all set to go as you essentially have no adjustable tilt.
Concise
Thanks Andrea, corrected to degrees, and that you “conclude” with no tilt.
Phil Bordelon avatar
How did your run this check/analysis from NINA?
I run Aberation Inspector→ Run Autofocus which is a part of Hocus Focus in NINA.
