Refractor vs. Astrograph Reflector for DSOs
Read noise Astrophotographyandrea tasselliArun HSonnyE
34 replies1.1k views
Megh Joshi avatar
Hey y'all!
I'm looking to upgrade my astrophotography rig and I'm choosing between the Askar 91F Flat Field Refractor (607mm FL) and Apertura CarbonStar 150 Imaging Newtonian (600mm FL and 570mm with Coma Corrector). What would be better for deep sky astrophotography (with special interest in imaging galaxies)? What do you think about using refractors and reflectors for DSO astrophotography?
There is no contention, a f/4 6" newt will win hands down. Still a bit on the short side as far as focal length is concerned.
Arun H avatar
Andrea is correct - the reflector will outperform the refractor in light gathering and resolution, the latter if your skies permit it. It is the better instrument for galaxies.
That said, having used both, for me the refractor wins hands down, simply because its convenience and robustness of collimation means I use it more often. I am currently taking my f/5 refractor with me to dark skies quite frequently, and I set it up and image in very little time. It is a joy to image with.  If I had to struggle with collimation, it would make the experience far less pleasant. The convenience is the deciding factor for me. Your needs and experiences of others may vary.
Alex Nicholas avatar
If your focus is Galaxies, 6” F/4 might be a little short, but then, not worse than a 3.6” f/6.7 refractor.
You have to factor in that the newtonian has more light gathering area (even accounting for the central obstruction), and at f/4, its almost twice as ‘fast’ at gathering light…
If you’re running a smaller sensor like the IMX585, IMX533 or IMX294, then a ~600mm focal length may be just fine for plenty of galaxies, but regardless of the desired target, a 6” F/4 is better than a 3.6” F/6.7.
Depending on your mount - the cost difference between the 150mm and the 200mm might be worth considering. 800mm will give you a lot more options regarding targets, and again, another massive step up in light gathering area.
Rick Krejci avatar
I guess “win” is a relative term. The refractor is plug and play with little worries about backfocus and collimation. The Carbonstar will not cover Full Frame with the Coma corrector if that’s a factor and it requires 55mm backfocus.
Aperture wins out in resolving finer details and collecting more photons, and the reflector will have less CA to deal with (although still some with the glass in the corrector). But, like Arun said, refractors are much easier to deal with with a portable setup.
I don’t know the edge correction of either optic, but especially if you’re looking at APSC, you’d have to compare raw images from each. I know with my 10” f4 Quattro with the well regarded Quattro coma corrector, I very much struggled to get a FWHM anywhere below the low 3”s. I was able to get similar or slightly better FWHM numbers from an Askar 140 APO despite the much smaller aperture, partly because it’s less prone to wind by a good bit and had nice optics. And my TOA-130 gets in the 2”s on a regular basis despite being yet smaller because of it’s incredible optics.
So all other things equal, yes, aperture “wins”. But all things are seldom equal.
SonnyE avatar
My preference is a refractor. But then, I Galilean. And basically, only interested in DSO Nebula. I blame the Orion Nebula for my addiction.
When starting out, after 5 months of narrowing down I had one wish list with a Newtonian Astrograph. My other list was a Refractor.
The refractor won due to the idiosyncrasies of reflectors. Things I didn’t want to deal with.
After 13+ years now, and only two telescopes, yep, still lovin my refractors.
I began with an 80mm triplet. Now I’m shootin through a 130mm triplet. After adding a FF/FR (0.8) my 130 dropped from 910 FL to 726 FL. Which works well for a wide variety of objects. And I’m currently using an APS-C sized sensor. (ASI2600MC Pro)
For the bigger/wider objects, doing mosaics brings them into view. Where the 80mm would take in a much wider Field Of View.
Peter Nielsen avatar
I have three f4 newtonians (600-1000 mm), one RC 1360 mm and one apo 480 mm. For details of galaxies (except the giat M31) clearly wins a higher focal length of 800-1000 mm as mentioned already. My personal prefererence are newtonians, which however always have the collimation problem. If you buy one, you have to deal with collimation which needs special equipment such as a laser or an ocal system and experience. However, it pays out on a long term run.
CS Peter
Concise
Stjepan Prugovečki avatar
One of our older colleagues once said “Mirrors are for shaving , lenses are for astronomy…😂. Joke aside , it all depends. I am photographer, I rarely do visual and I do hav 3 refractors including Tak and LZOS. The main reason is that I have fixed piers with mounts permanently on. I just put scopes on and I am ready in few minutes with all 3setups. That, and often windy wether was the main reasons. Also I do not like spikes. Reflectors do win always on aperture and fast Newtonions on speed as well. They are cheaper , although really good ones are not cheap at all. If you get one with low price it is always a bit of adjustment and modification. And collimation and cooling is there as well. So if you like a bit playing with your instrument and you do have a proper mount and no strong winds, for astrophotography, fast Newtonian will always be better in what you get/what you pay ratio.
BlackStarsAstro avatar
I am currently using the CarbonStar 200 newt with CS flattener. It’s on a pier in a roll off roof observatory. Its definitely a refractor killer on a permanent setup. Collimation takes 10 minutes if needed. I would not hesitate taking it on a road trip, unless I had to fly, because the view is worth the climb.
“Unless you need rain. Clear Skies”! Heavenly Backyard astronomy.
ScottF avatar
I have the carbonstar 150 and a few refractors. The refractors are certainly simpler for grab and go, but collimation of a Newtonian is just a few minutes with a laser. Once you do it a few times , it’s no issue.
Ashraf AbuSara avatar
I have gone down this path and have finally chosen to just use my refractors over my reflectors. In fact I just ditched my Epsilon 160ED in my remote observatory for an UltraCat 108. My long focal length setup is just a TOA-130 5.1 inch refractor.
Obviously people have had incredible results with the Epsilon and it is a fantastic instrument, but there are some intangibles that you don’t hear about at first, like the significant illumination drop towards the corners on a full frame sensor, and the very very difficult process of getting your stars in the corners to look remotely acceptable. Add to that the immense amount of diffraction spikes you have to deal with when imaging rich star regions in the milky way.
Personally I found that processing the data out of my refractors was a far more enjoyable experience than it was out of the Epsilon, even if they were substantially “slower”. All my setups are under B1 skies. I never spent 20 hours on a target with my TOA and thought at the end, “I just wish I used an f/3.3 Epsilon instead”. This included dark and reflection nebulae targets, and IFN.
While larger aperture reflectors in theory should be able to get better details, I think the vast majority of them are wasted under skies with subpar seeing conditions that don’t support that aperture and focal length. Eventually I would love to have a massive reflector under pristine skies, but for now refractors are doing fine.
Arun H avatar
Ashraf AbuSara:
Personally I found that processing the data out of my refractors was a far more enjoyable experience than it was out of the Epsilon, even if they were substantially slower. All my setups are under B1 skies.
I would highly encourage people to look at Ashraf's gallery to see what can be done with a good refractor under good conditions!
Well Written Supportive
SemiPro avatar
Alex Nicholas · Nov 25, 2025, 12:31 AM
Running those sensors at F6.7 would require an eye watering amount of time to get a good SNR. They really only make sense if you can get the focal ratio down to around F/3 and below. Even then, by that point there are so many optical errors that become magnified at those focal ratios that small pixels might be a wash anyways.
As for the stated goal of shooting galaxies, the OP might find 600mm lacking. The fun really begins around 1000mm, ± 200mm. By that point, refractors start to get expensive, assuming you want a decent focal ratio.
If you do switch to reflectors, be prepared for soft images for a bit while you get the collimation situation down. Reflectors can be pretty fun though; your knowledge of optical issues (and how to deal with them) will increase exponentially and your wallet will thank you. The only cost you have to pay is a bit of your sanity.
Aloke Palsikar avatar
I have both a Newtonian Skywatcher 150p Reflector (f/5) and Askar Petzval SQA 55 Refractor (f/4.8) and while both are useful, definitely the Skywatcher has better light gathering ability especially for my small sensor Camera ASI 533 MC pro.
However I would weigh the benefits as below
Skywatcher 150P
  1. Better images and sensitivity
  2. Good on fixed setups like Pier mount. Bulky for Outdoor transport
  3. Some initial setup issues in Camera & filter wheel mounting, Collimation
Askar SQA 55
  1. Light and portable. Easy to carry with its own case
  2. Good and easy to use . No backfocus issues
  3. Good results on a Tripod as well as Pier mount
I use ZWO AM5N mount in both cases and hence am happy with both the scopes
Hope this helps
Georg N. Nyman avatar
My view is pretty clear - what are your preferences? Is it easiness to operate, maintain and handle - then go for a refractor, is it speed and resolution - then go for a reflector.
Refractors usually in these days are easy to handle, no mirrors to be aligned and recalibrated, no mirrors which collect dust and spider webs, BFD is usually quite easy to achieve and balancing is also easier to do. But the main drawbacks are speed and resolution. Speed - onless you own a money printing machine, you are stuck with probably f/4.6 or similar as maximum speed for any refractor unless you want to sell your home. Most refractors are somewhere between f 5 and f7 - refractors, which are probably still affordable. That means you need to have more good and clear nights for imaging than with a fast reflector.
Reflectors can be a sensitive to travel, a bit more effort is needed to maintain them in a fine state of optical performance, the need recalibration - probably once a year or so and they need more effort to balance them properly ( especially Newtons). But their main advantage is speed and resolution. Reflectors can be very poweful regarding light collection - f/2.2 as example for the RASA series or f/2.8 for Sharpstar, not to talk about the speed monsters from ASA or other manufacturers - the new H-2 as example with f/2.95. This means half or even ¼ of the integration time compared to a fast refractor combined with a much higher resolution.
But they (most of them are “open”) need cleaning at least once a year and they need to looked after more than a refractor.
If you don´t mind more work with and during imaging, then go for a RASA - their speed will surprise you. You can take a “final” image in one night for which you need two to three nights with a conventional reflector or four to eight nights with a refractor. But the RASA got major restrictions - unless you use a tiny system with integrated filter changer like the QHYminiCam8, you cannot use a normal mono camera with attached filter changer - you must change filters, one by one, manually. Or you can use an OSC camera with a multiband contrast filter like those from Askar - the Color Magic C or D series.
I use a 12” TrussRC with three options - f/8 at 2450mm fl, f/6.4 at 1950mm and f/5.4 at 1650mm, a RASA11 with f/2.2 at 600mm and a Hypergraph6 with f/2.8 at 420mm. A reflector I do have on my mind for the time when I cannot handle my current systems anymore (I am getting 77)… so to say, a retirement optics - easy to handle and simple to maintain :-)
One last remark - check carefully your options, look at the varios sytems before you go an buy one!
Georg
ScottF avatar
Another option is the 190mm mak-newt. I think it’s made by a few different companies? Sky-Watcher makes one. It’s a bit heavy but you’ll get 190mm of aperture, f5 so it’s pretty fast and no star spikes.
Clayton Ostler avatar
I have to admit I am biased, but I gave up trying to use newts. I felts like I was messing with collimations all the time, and never felt confident that I had it right. And every time I hit a bump driving to site in the jeep, I worried I had to start over and redo collimations and calibrations.
No doubt the larger aperture gets more light, and not doubt that lb for lb you can get way more aperture for way less weight and money. I had a 6 inch refractor and the fear of dropping that while mounting/unmounting on a freezing cold night was a real thing.
I honestly feel like for me the 130mm refractor is the sweet spot, if I wanted more aperture after that, Id be going SCT or Astrograph,
My uneducated view on dealing with Coma was that it was a total pain, and if I have to drop 300$ on a good Coma Reducer, then the money I saved over a refractor just got offset.
(Yes I know refractors have CA, but if you get a good triplet, its almost un noticeable. )
My refractors generally dont have to deal with cool down wait times or mirror shift,
I feel like people much smarter than I still love Newts and Astrographs, so I might be missing something, or I am just extra lazy.
My opinion
bigCatAstro avatar
Clayton Ostler · Nov 26, 2025, 05:21 PM
My opinion
You’re not lazy, sometimes things just don’t work out with certain types of equipment and you need to use what works for you.
I could not get collimation good enough for taking images with my older Newtonian, granted I was using a terribly suited one for imaging. No matter what I did, I couldn’t do it. I just lacked the overall skill to do it right, I’m not afraid to admit that.
Ease of use and set-up/breakdown led me over to using a refractor over a newtonian. For me, I wanted a set-up that I didn’t feel like I could make excuses for not using and one that wouldn’t be a detriment in participating in this hobby.
Arun H avatar
Clayton Ostler:
I agree. I have a 110 mm today and would get a good 130 mm if I could, like an AP 130 GTX or a TOA-130.
I own a 200mm ONTC f/4. It certainly is great at gathering light, but, I'd find that I would spend significant amount of time at the beginning of the session getting it collimated. The tools confirmed the collimation, but clearly, there was a difference between the tool saying it was collimated and the collimation as recorded by my camera. With the refractor, I have no such issues, apart from a small period of acclimatization, it is set up and go.
No doubt I could get better images with the 200mm than the refractor (and I have ), but the low stress nature of it and its portability is the winner in my book. If it feels like work, it isn't worth doing.
Tom Boyd avatar
Clayton Ostler · Nov 26, 2025 at 05:21 PM
I have used both the WO FLT132 (910mm) and the 200 Carbonstar (800mm). And after using the Carbonstar for the last few months I have decided to sell the FLT132. A quick note about my usage case; I set up and take down every night, sometimes traveling to a more remote location.
  1. The FLT132 with rings weighs just under 30 lbs. The Carbonstar with rings clocks in at about 15 lbs. If you have to set up and take down a lot, don’t underestimate the importance of lugging around that extra weight.
  2. FLT132 at native focal length is F7. Carbonstar is F4, and the Carbonstar has more aperature , both help me make the most of my limited sky time.
  3. While not a consideration for me (obviously since I bought both), there is a cost consideration. The Carbonstar is easily less than half the cost of the FLT132.
I too, initially hesitated going with a reflector because of the need to collimate. But, I gotta say, at lease with this straight Newtonian it’s not a big deal. Five minutes before setup, and another five minutes for a quick touchup while it is on the mount. Easy, peasy…
Read noise Astrophotography avatar
I started astrophotography in 2010 and I’ve owned almost every type of telescope since. Here’s the blunt breakdown:
Refractors:
Convenient, quick, easy. Great for widefield. But they hit the ceiling fast unless your bank account is unlimited. Premium refractors get expensive very quickly for the aperture you get.
Reflectors / RC / Newt:
If you set them up properly, they deliver far cleaner light and far more performance per euro. Almost all of them benefit from a focuser upgrade that’s normal but once dialed in, the results speak for themselves.
My setup today:
  • Widefield: refractor (speed + simplicity)
  • Galaxy hunter: RC astrograph
My RC with all upgrades ended up around €4,000.
A €4,000 refractor simply cannot match an RC in optical performance or resolution. Not even close.
And for context:
Almost every professional observatory on Earth uses RC or RC-derived designs. There’s a reason for that they scale, they handle long focal lengths properly, and they’re built for real deep-sky work.
If you want convenience → refractor.
If you want long-term performance → reflector, especially RC
Helpful Concise Engaging
Astro Hopper avatar
Newtonian if quality of photos is your goal. Sharper, with 0.95 coma corrector comes to F 3.75 so much faster and better for high bortle.
This is not realistic comparison.
If you put in comparison much better Apo the maybe we could talk about that, but Askar 91 F flat is on lower side of quality.
Read noise Astrophotography · Nov 27, 2025, 07:09 AM
Refractors:
My setup today:
And for context:
For galaxies, the resolution of the optical train is most important. RCs clearly can have higher focal length, resulting in higher enlargement, but this is not resolution. Most import for resolution is the aperture of the telescope, not so much the focal lenght . I have a f4 1000 mm newtonian (250 mm tubus opening) and a 1626 mm RC with 200 mm opening (f8). For my galaxy pictures, the newtonian clearly wins. In addition the correct collimation of a RC at least in my hands is a problem (for me). From the earth the resolution of telescopes with a larger opening than about 250 mm is strongly limited by the seeing influence of the athosphere. This is certainly better on moutains and lousy in my location in Northern Germany.
The argument that RC are used by NASA and all other professional astrophotgraphers is simply the easy construction of RCs for space conditions. Also the seeing is perfect in space with no athmospheric artifacts.
Again, I think from my experiences, a newtonian is better (for my) galaxy astrofotographies.
CS Peter
Well Written Helpful Insightful Concise Engaging
Peter Nielsen · Nov 27, 2025, 01:07 PM
Refractors:
My setup today:
And for context:
For galaxies, the resolution of the optical train is most important. RCs clearly can have higher focal length, resulting in higher enlargement, but this is not resolution. Most import for resolution is the aperture of the telescope, not so much the focal lenght . I have a f4 1000 mm newtonian (250 mm tubus opening) and a 1626 mm RC with 200 mm opening (f8). For my galaxy pictures, the newtonian clearly wins. In addition the correct collimation of a RC at least in my hands is a problem (for me). From the earth the resolution of telescopes with a larger opening than about 250 mm is strongly limited by the seeing influence of the athosphere. This is certtainly better on moutains and lausy in my location in Northern Germany.
The argument that RC are used by NASA and all other professional astrophotgraphers is simply the easy construction of RCs for space conditions. Also the seeing is perfect in space with no athmospheric artifact.
CS Peter
Hi Peter,
You make several good points especially about aperture and seeing limitations here in Northern Europe. Resolution is ultimately determined by aperture, and you’re absolutely right that poor seeing can negate much of the theoretical advantage of larger instruments.
But I think there’s a key distinction worth highlighting, because it’s easy for readers (especially new imagers) to take personal experience as a universal rule:
A well-collimated RC and a well-collimated Newtonian behave very differently, and they’re designed for different strengths.
For galaxy imaging specifically:
  • RCs maintain fixed mirror spacing, so focus holds consistently across the entire field.
  • There’s no coma, so stars remain stable without needing a corrector.
  • The optical design scales cleanly to long focal lengths, which is why virtually every professional system doing high-resolution galaxy or photometric work uses some RC-derived variant.
  • The field is inherently flatter, which helps with larger sensors.
A Newtonian certainly wins for you personally because you’ve got your F/4 tuned well and you’re comfortable with that collimation process. But a misaligned RC will always underperform even compared to a much smaller refractor. They’re extremely sensitive to tilt and mirror spacing.
That’s the important part:
RC performance depends almost entirely on collimation accuracy.
Once an RC is properly aligned and the focuser is stable, its strengths for galaxy work (contrast, tight stars, long FL detail) become very obvious.
So in short:
  • If someone wants convenience and minimal maintenance → a refractor makes sense.
  • If someone loves tinkering and fast, wide fields → a Newtonian can be fantastic.
  • If someone wants long-term, high-resolution galaxy performance → an RC is usually the better tool, provided it’s collimated correctly.
Your results with the Newtonian speak for themselves but the design differences are still worth keeping clear for people comparing optical systems.
Well Written Helpful Insightful Respectful Engaging
Read noise Astrophotography:
It's not.
Camera Upgrade
I'm thinking about upgrading my Astrophotography Camera, is the ZWO ASI585MC Pro a good choice for upgrading. Right now i'm using a Fibonax Nova 800 Camera. Any Thoughts on this?
Relevant for understanding telescope options when upgrading astrophotography equipment alongside camera.
Jul 23, 2025
Thinking of adding the Apertura CarbonStar 150 w/0.95x Comma Corrector to my collection
Hi Folks, As the subject line says, I'm thinking of adding the Apertura CarbonStar 150 to my current collection of telescopes…. My current collection consist of in order of shortest to longest focal length: WO Redcat 51, Celestron C6-Hypers...
Discusses Apertura CarbonStar choice for astrophotography alongside refractor options.
Aug 27, 2024
