TS Optics 115/805 Photoline with 0.8 reducer - elongated star issues?
3 replies128 views
Harald Becher avatar
Anyone using the TS Optics 115/805 Photoline with the 0,8 Reducer for it?
I have elongated stars on one side in the bottom and the top, but ok stars on the other side, when using 55mm working distance (APS-C Sensor).
What is your experience with the scope with that reducer regarding the imageing quality?
Thanks
Looks like tilt to me.
codwyer avatar
Also looks like tilt to me. Your star sizes on the right hand side are similar to mine, maybe same type of skies, when I had this scope. Right side looks top-bottom consistent, tilt or sag somewhere.
check the whole-focuser rotation on this scope, those brass holding screws for focuser attachment to the OTA can be loose, and the locking screw if that is the focuser you have on it.
thx, yes same focuser. It was tight, no gaps or movement possible.
TS changed the reducer. We will see
Problems with my Quattro Skywatcher
Hello, I have this problem with the stars, my equipment is a Quattro 250p with coma corrector. One side is ok, but the other the stars are no uniform.📷 IMG_0728.png
Similar non-uniform star problem on one side of frame.
Sep 28, 2025
What Reducer to use with the Explore Scientific ED APO 127
Hi folks, yesterday, I bought my long wanted Explore Scientific ED APO 127 FCD100 with Hexafoc and carbon tube. It was 20% off and so I took the chance to buy it. It will arrive tomorrow and I'm looking forward to get some great images with it. S...
Discusses reducer usage issues with similar APO telescope setup.
Feb 2, 2024
ChatGPT and oval stars
An interesting exchange with ChatGPT regarding a new onset problem with stars across my entire field of view being oval shaped, and all elongated in the same direction. Exchanges are summarized due to the wordy nature of ChatGPT. What is interesting ...
Discusses oval/elongated stars across field of view, similar optical issue.
Feb 13, 2026
