how to collimate skywatcher explorer 130p
7 replies141 views
Nikolaos Bafitis avatar
on the back it says it is already collimated in factory but it obviously isn't, there are no actual screws to collimate it, only the secondary, what should I do?
Brian Puhl avatar
https://www.astro-baby.com/collimation/astro%20babys%20collimation%20guide.htm
Apparently there is a cover on the back side that you need to remove to access the collimation screws. See step 4.
Concise
Brian Puhl · Nov 22, 2025, 05:36 AM
unfortunately the scope she is using isn’t my model. I have been experimenting with my scope and there really is no way to collimate the primary mirror.
Then you'll have to use the secondary mirror's screws and hope for the best.
Which isn't too unusual.
Kristof Vandebeek avatar
Can you share a picture of the back?
Brian Puhl avatar
Nikolaos Bafitis · Nov 22, 2025, 04:28 PM
As I understand it, your scope and hers are designed almost exactly the same. That's why I linked it.
Erlend Langsrud avatar
Most of the time, I dob’t touch the secondary. I will explain why below:
These is only one element in a newt that has an optical axis: The primary mirror.
There are only two ways the optics can be misaligned si that you get abberrations
  1. Off center of the optical axis.
  2. Not perpendicular to the optical axis (essentially introducing tilt.
  1. Is by far most critical. Especially for visual or planetary. You only neet a pinhole to fix that one. Only adjust the primary until the reflection of the pinhole is in the centre marking. Every bit as accurate as a laser.
  1. Takes a chesire, a laser or an Ocal (kamera) I have all of them.
All the other ways a newt can be misaligned only affect vignetting.
Odd "circle" in imagery when taking photos
Hi all, Starting with: This is a 12” newtonian (1200mm), with a Poseidon-M connected to 50mm (round) filters and an OAG-MAX (with a coma corrector) - 56mm back focus So I’ve been banging my head against a wall trying to figure out what this is… I fir...
Not relevant; discusses imaging artifacts, not collimation procedures.
25 days ago
Collimation; "confirm with a star test at night". Wat!
Hi! I just got myself a RC10 Truss (TSRC10T64), and while waiting for the sky to clear (it’ll be weeks!) I’m trying to prepare as much as I can. This is my first reflector, so collimation is of course a hot topic :) Every tutorial I have found ends w...
Relevant; discusses collimation challenges and alignment procedures for telescopes.
Feb 12, 2026
Takahashi e-130D Primary adjustment
Hi everyone, I’ve tried searching, but just can’t find a clear explanation. The adjusting screws on the rear of the primary mirror- in what order must I undo in order to assist collimation? I have previously removed the mirror for cleaning, then at o...
Relevant; addresses primary mirror adjustment screws and collimation procedures.
Oct 13, 2025
