Strange artifact in images with Askar 120 APO setup
4 replies184 views
Juan Pablo De la Cruz avatar
Hi, I’m getting a strange artifact in my images — has anyone experienced something similar?
Setup:
– Askar 120 APO
– ZWO Filter Wheel
– Antlia V-Series LRGB filters
– ZWO OAG
– ASI2900MM
– SkyWatcher EQ6-R Pro
Any ideas on what might be causing it would be greatly appreciated.
Luminance Filter
Screenshot 2025-11-20 211632.jpgRed Filter
Noah Tingey avatar
Looks a lot like the OAG prism is blocking your sensor. Loop exposures on a flat panel and adjust the depth of the OAG until its no longer darkening your FOV.
Alex Nicholas avatar
Thats your OAG pick off prism. Flats will correct it, but id be adjusting it so there is no shadow so flats are only correcting vignetting
Thanks, Noah and Alex! Tomorrow I’ll adjust the OAG. Sometimes I get overwhelmed and miss the obvious things.
Well written Respectful
Solved!!! Thaks for the help.
Blue halos around stars after LRGB combining in PixInsight
Hello all, I took subs with LRGB filters with an APO - processed them equally in PI and after combining them as LRGB, many stars show this strange blue halo - which does not exist in the single mono channels - any idea how they came into existence an...
LRGB combining artifacts with APO and similar camera setup may match issue.
Oct 30, 2025
What Is This Shadow In The Image?
I was attempting to process the Witch Head Nebula image with my SeeStar at dawn when I noticed an unusual shadow that appeared despite the enhancement. I'm not sure what is causing it. Is it something in the field of view, or could it be related ...
Strange artifacts in images; similar troubleshooting approach needed.
Nov 26, 2024
FLAT with a strange pattern, I can't properly correct the LIGHTS / SkyWatcher APO ESPRIT 120 / x0.77 Reducer SkayWatcher / QHYY 268 mono / Chroma 3nm SII 36mm and OIII
Hello, I have a problem I can't seem to solve. If anyone can shed some light on it, I'd appreciate it. I'm testing a new setup: SkyWatcher APO ESPRIT 120 / x0.77 Reducer SkyWatcher / QHY 268 mono / Chroma Ha 5nm 36mm / Chroma SII 3nm 36mm / Chroma OI...
Flat calibration problems with APO scope could relate to artifact cause.
Mar 18, 2026
(Worm Gear) Mount Advice
Recently had to do some maintenance to my EQ6-R Pro Mount due to guiding issues and thought I'd share for anyone who may be struggling with similar issues. ———— I’m using an EQ6-R Pro with an EdgeHD 8, OAG, and ASI2600MM. Mount is about 2 years old a...
EQ6-R Pro mount maintenance may address guiding-related image artifacts.
Dec 16, 2025
Weird artifact in CLSCCD images that won't calibrate away
Hello, I’m attaching two quick images taken on the same night (two different objects, saved as JPGs for size) - one HA, one CLSCCD filter (OSC camera). Flats taken with a panel that same night. If you look in the CLSCCD image, about a third of the wa...
Unknown filter artifacts that won't calibrate away similar to your issue.
Sep 24, 2025
