IC1805 SHO with strange artifact
7 replies320 views
sanyahun avatar
Hello everyone!
Can anyone tell me what am I seeing here? I reprocessed this image a few times, it was always there. It is not visible on a single sub, but it is visible on the OIII stack I think (I'm at work at the moment, have to check when I'm home). I'm new to the hobby, sorry if it's nothing, just curious. Thanks!
Sandor
Respectful
Die Launische Diva avatar
Hello! That's not an artifact, but the small planetary nebula PN G135.6+1.0 (which is also known as WeBo 1), and it is bright in the OIII line, as you have discovered!
Marc Dickinson avatar
I've noticed this on several images and my own, I can't find anything referring to it.  I was planning on imaging it with C14, it seems to be at ~ 2h 40' 12"
61 deg 10’
sanyahun avatar
Die Launische Diva:
That is really cool, thank you!
Die Launische Diva:
Nice to know! I couldn't find the listing number on a Pixinsight plate solve, just curious, what did you use to find it was PN G135.6+1.0?
Marc Dickinson:
Die Launische Diva:
By performing a coordinate query in SIMBAD. This is what SIMBAD returns with the approximate coordinates you have provided in your previous post.
Tayson avatar
PN G135.6+1.0
Die Launische Diva:
Thank you!
what are these strange donuts in my newtonian reflector stacked image
I am a new to newtonian reflector, just bought a GSO 8" F5 with GSO 2" coma corrector. still not very good at precise collimation but I tried my best with collimation cap and laser. the issue is I always got these strange donuts like unfocu...
Discusses artifacts in stacked images from reflector telescopes, similar issue.
Jun 5, 2023
Artifact? Reflection? What is this in my IC2118 (Witch Head Nebula) Image?
I shot 265 60 second subs of the Witch Head and Rigel last night. I used my Rokinon 135 f/2 and ASI294MC Pro, with an Optolong L-Pro filter. All of the subs have a bright 'blob' not far from the center of the image, in the middle of the '...
Author troubleshooting unknown artifacts in nebula image stacks, directly relevant.
Dec 5, 2023
Round artifacts on image from Celestron Edge HD 8
EDIT: consensus seems to be this is dust on camera sensor cover, or on reducer, or somewhere in the image train. Solution: Clean, then shoot again and take new flats. If you think it's NOT dust motes, please let me know below. I understand calibr...
Identifies round artifacts in telescope images; similar diagnostic problem-solving.
Nov 8, 2023
