I, like many other, use routinely DSLR for deep sky imagining and I'd wager that most use a mix of Canons and Nikons, with few Sonys thrown in the mix. Some will be modified and some won't. Here is a like for like (if such thing exists) comparison between my modified (IR cut filter removal) Nikon D5100 and an unmodified Fujifilm XT-1 using my 80mm APO. The subject is M42 (quelle surprise!) both because it is easy and because there is plenty of emission lines (OIII and H-alpha in the main) and reflection going on (plus IR). No filter was used in either case. The XT-1 shot was taken with high waxing moon (91% illumination) nearby in a very humid night. Having left the heating strip attached to the other scope I had to fight all night to remove condensation from the front lens of the scope but some light drop-off must be accounted for in this case. Other than that they were processed in the same way and auto-stretched at the end of the pre-processing procedure. No denoise was applied either. The image show a similar area around the "Running Man" nebula to better highight the baseline noise properties of the two cameras. Note also the effect of unfiltered light in the D5100 image which is going to make both stars and nebulae brighter although both were exposed for a very similar amount of time at the same ISO (though both cameras are ISO-less). Pixel size is essentially the same for both cameras so potential resoluion is about the same but the Nokon employs a standard Bayer colour filter arrangement while the Fuji uses the X-Trans arrangement. The Fuji also does away with the anti-aliaising/de-moiree filter in front of the sensor, which might explain some of the better than expected performance in the deep red region (for an unmodified camera anyway).
Howard Richard avatar
The noise in the Nikon may reflect the age difference of the cameras. The modified camera clearly does better with the Hydrogen Alpha.
Well written
Mono or OSC camera?
Hi again, I asked before many times about a scope to be as my third option or setup to use, and i didn't decide on anything yet for some reasons until recently i saw a new scope that is like 90-98% is the answer to my question, then this will lea...
Discusses camera selection for deep sky imaging, directly relevant to author's DSLR comparison.
Sep 12, 2023
QHY8L or Canon70D?
hello, I currently use a Canon 70D with my 80mm refractor and have the chance to buy a used QHY8L cooled camera. This is a 6 MP camera, while the Canon has 20.2 MP. Both sensors are quite big, which is good. Question is: would the cooling benefit me ...
Compares DSLR performance for deep sky imaging, relevant to sensor considerations.
Aug 12, 2020
LRGB-Combination in Pixinsight
I'm imaging in LRGB, and as my images get better and overall integration times get longer (RGB channels getting better), I noticed one of my biggest problems is combining L and RGB in Pixinsight. In acquisition, I use the same sub exposure time f...
LRGB combination processing relevant to author's deep sky imaging workflow and data handling.
Sep 18, 2023
