Is This a Tracking Error?
3 replies182 views
Jerry Gerber avatar
Out of 12 good subs, this last one turned out oddly.  At first I thought it may be a computer display glitch, but when I examine the actual sub, it looks like this; there are two of every star.  Anyone know what is causing this?
Brian Puhl avatar
Probably jumped guide stars. Definitely a track between the ghosted stars, ever so slight.
Jerry Gerber avatar
Hi Brian,
I'm not using a guide scope or guide camera, the 10MicronGM1000 can track without guiding.  But I suppose it could be some kind of guiding problem.  It looks like the camera took two images of the same field but obviously out of registration.  It's a 3 minute luminance sub (-10c) taken with the ASI2600mm, the EFW 7x2 filter wheel.
Chris Jensen avatar
Possible wind gust bumping the scope is the only thing I can think of given you are not guiding.
Issue in ASIAIR autostretch preview, or actually FITS corrupted?
Good morning everyone. For some time now, I’ve been experiencing a strange issue during acquisition with ASIAIR PRO using the ASI678MC on long exposures. The phenomenon is particularly easy to isolate and observe by acquiring dark frames, so I’m shar...
FITS file corruption could cause duplicate stars in astronomical images.
Aug 14, 2025
Odd "circle" in imagery when taking photos
Hi all, Starting with: This is a 12” newtonian (1200mm), with a Poseidon-M connected to 50mm (round) filters and an OAG-MAX (with a coma corrector) - 56mm back focus So I’ve been banging my head against a wall trying to figure out what this is… I fir...
Discusses odd visual artifacts in astrophotography imagery similar to your issue.
25 days ago
Odd Horizontal Thick Line Artifacts
Hello. I’ve reached a point of frustration and I’m unsure how to proceed. I have some image stacks that show up with these odd looking horizontal “lines. I cannot figure out what is causing it. I pre-processed in WBPP using lights, darks, bias, flats...
Addresses unusual artifacts appearing in stacked astronomical images.
25 days ago
