Getting good guiding results with short exposures on ASIAIR setup - But have lots of questions….
10 replies158 views
docgroggy1 avatar
Just looking for some friendly advice.
New to astrophotography. Got my first mount February of this year.
Last week I bought an ASIAR plus, ASIAIR 220mm mini guide camera, and the SVBony SV165 (40mm, 160mm focal length) guide scope for my rig (Sky Watcher Star Adventurer EQ GTI + Canon 90D (unmodified) + 100-400mm lens). For simplicity sake, I have been shooting at 400mm because guiding at 100mm would be << 1:5 ratio.
Watched a lot of videos on guiding with the ASIAIR and SWSAGTi, most suggest guide camera exposure times in the span of seconds. Regardless, I’ve been getting what I think is really good guiding (<0.7 - 0.8 TRMS) using really short exposures (0.1 - 0.2s). The mount is very well balanced and PA was < 0’ 20”. Seeing is generally really good, but do have some local LP in a B4/5 zone I would guess 1-4 FWHM.
Variables:
  • Mount Load: ~6.1 lbs (per google; but likely closer to 7 IMHO)
  • RA Aggression: 65%
  • RA Max duration: 600 ms
  • Dec Aggression: 85%
  • Dec Max duration: 600 ms
  • Exposure: 0.1s
  • Guide Scope Gain: 325
  • Guide Stability: 2”/5s
  • Dither 10 px every frame, RA only (why is this the recommended setting for the SWSAGTi?)
Is there any reason not to continue using these settings? Am I introducing unintended artifacts?
When looking at the guide star histogram, there are two numbers, Size & Peak. What are the units for these? Is that FWHM and <I>?
What is considered good guiding? (I’m in a B4/5 zone with generally good seeing).
How do you recommend focusing the guide scope and is it true that being “a little out of focus” helps?
This is a low ish res result of an image with these settings
📷 IC1369IC1369
https://app.astrobin.com/i/e7ua1d/📷 IC136
Brian Puhl avatar
If it works, I’m not gonna tell you to stop, but you are going to be chasing seeing pretty heavily at that speed. Generally speaking with any mount that lacks encoders, I run 1-2s exposures. Things like the AM3/AM5 with the large periodic error feature actually do decently well at 0.5 but they so heavily rely on good seeing, it’s a tough balance.
With a mount like that, getting under 1 arc second seems really good, unless you are mistakenly giving RMS in pixels. Even that is perfectly acceptable.
I would probably go with 1 second guide exposures, but the ASIAIR is not something I’m familiar with. PPEC algo on the RA axis should help quite a bit, if it’s an option on the ASIAIR.
As for the guide star, size should be the HFD, peak is the ADU value. If you’re running 8 bit mode, it will peak at 256, if you’re running 16 bit mode it will peak at 65k. You want the guide star to have a nice point to it, not a plateau. If it’s a plateau you should consider either lowering gain, or tweaking your guide star preferences.
“Good Guiding” is when your system can perform UNDER your imaging scale. Most people say shoot for 70% of your image scale. Try not to confuse this with your guide image scale, as they are two different things. We want the performance to exceed that which our main imaging camera can see. If your image scale is 2 arcsec per pixel, then ideally I’d aim for 1.5 arc sec guiding or better. You want to keep the peaks inside that image scale as well. People with bigger scopes have much smaller imaging scales, and we must guide even better.
Focusing your guide scope is pretty simple. Get it somewhat close, i.e. round stars. Use PHD to grab a guide star, but do not guide on it. Rack your focuser slowly and watch the HFD number. You want it to be as low as you can go. Once you’ve found the lowest point, you’re golden. The basis on being ‘out of focus’ is because PHD uses a centroid algorithm to guide on the star. Personally, I do not agree with that consensus, but as an OAG user, there will always be some focus shifting when switching filters, which means that guide star will change size often.
I hope most of these will make sense for you, as ASIAir kinda dumbs things down, takes away some ability to tweak things. Theres tons of folks using them, but let me tell you, you’re better off with a nice inexpensive miniPC mounted on top, and using windows RDP to log into it.
Habib Sekha avatar
docgroggy1 · Nov 9, 2025, 06:13 PM
It’s been over a year since I used ASIAIR and things might have changed since then.
The trick was to set the guidecam as the main camera. This will allow to see the image it produces. Bij using the focus option you should be able to see the star size which will change by adjusting the focus on the guide scope.
FWIW, when I started two years ago I fortunately found the following ASIAIR guide which I found to be very useful. Perhaps there are some points of interest for you.
https://www.highpointscientific.com/astronomy-hub/post/how-tos/zwo-asiair-guide
docgroggy1 avatar
Thank you Brian for the advice. This was super useful!!!
I was concerned that by having it with such a high frame rate, that the mount may not be designed to make adjustments at that rate of corrections.
Maybe a few years ago I would have gone with my own mini PC and a laptop. But just don’t have the bandwidth — I really would like to know what’s going on under the hood and the ASIAIR makes it difficult. Especially since documentation of what is an actually being shown is thin at best. Regarding guiding numbers, those are in arc min/arc sec. But the “size” is not clear to me if it’s pixels or arc sec. And if it’s FWHM.
But I want to thank you again for not being roosters (but in French) like people on CN. I had the worst interaction on CN when I posted this in the Beginner AP Forum.
Quinn Groessl avatar
I probably wouldn’t dither as often. I dither once every 5ish frames for 5 minute exposures. Once every 10ish frames for shorter than that. That’s still more often than many people.
I believe that they recommend dithering in only RA for that mount because it is known to usually have a decent bit of backlash in the declination axis. And if it’s not that, the. It’s people mixing up the GTI and the non-GTI.
docgroggy1 avatar
BTW this was the result https://app.astrobin.com/i/e7ua1d
(I need to get a better image uploaded but it’s not terrible)
docgroggy1 avatar
Habib Sekha · Nov 9, 2025 at 07:25 PM
Thx
docgroggy1 avatar
Quinn Groessl · Nov 9, 2025 at 08:00 PM
What are the drawbacks of dithering too often? I imagine it’s that you probably can lose a non-insignificant amount of time over the span of the night waiting for the mount to settle after dithering.
Lemme ask you a follow up question, would you answer it differently for a dedicated AstroCam vs. DSLR or just in general? I’d imagine the walking noise on a DSLR greater than with a cooled dedicated astrocam. I certainly would like to decrease my dither frequency. Gonna give your settings a try (if we have clear skies this month).
I use a dedicated camera. I’m not sure if using an uncooled camera really changes the frequency.
And yes, the biggest drawback is the time you’re spending settling instead of imaging.
docgroggy1 avatar
TY
docgroggy1 avatar
Just shared my latest version. Trying to figure out out what the prior was so much redder. Only significant difference was 2 additional hours and did a 2x drizzle integrating all my data (8.5h)
Need Help With Guiding My AM5
I have a brand new AM5 that I hoped to use for the first-time last night. Sadly, all I got was frustration. Getting my polar alignment was okay, slow because it's a new mount and I am not familiar with the adjustments. My trouble began when I tri...
Author struggling with guiding setup; candidate discusses guiding with similar equipment.
Mar 12, 2024
Recommended star guide camera for 50mm guide scope?
what is a good star guide camera that fits the Orion 50mm guide scope? if there is not one what is good star guide scope, thanks all
ASIAIR setup guiding discussion relevant to guide scope and camera selection process.
Dec 2, 2025
Asiair Calibration Settings for Using and OAG
I have a Celestron Edge HD with a 533MC pro and 120MM mini guide camera with my Off Axis Guider. What are the best calibration and aggression settings to use in the ASIAIR plus? I can’t seem to get below 1” when guiding. When I was using my Celestron...
ASIAIR plus guiding setup with similar equipment and calibration concerns.
Mar 1, 2024
Better parameters to adjust the guiding with ASIAIR?
Hi, I would like to know what guiding parameters you use with the SW SA GTI and ASIAIR, especially the number of calibration steps. Max AR and Max DEC.Thanks in advance. Ferran.
Discusses ASIAIR setup and guiding, directly relevant to author's equipment and questions.
Nov 21, 2024
Struggling to improve my telescope guiding performance
I’ve been struggling to improve my guiding for a couple of months now, despite any changes I make it doesn’t seem to have a major effect for improving my total rms. Gear Used:Sky Watcher 150iExplore Scientific ED102ZWO OAGZWO ASI 120MM Relevant Setti...
Author recently purchased guiding equipment and seeks advice on improving performance.
Feb 20, 2026
