extreme offset vignetting in flats and lights
11 replies244 views
Anthony Grillo avatar
This issue has persisted for a while now through at least 3 set ups and I honestly cannot for the life of me figure out what is causing this.
Here is an image of one of my flats which displays the extreme offset in vignetting in my imaging train which I originally thought was due to the filter wheel not centering filters over the sensor. The filter wheel seems spot on when I look at it move and stop and I’m using 2” unmounted chromas with a 2600mm pro.
I have tried moving various adapters to no avail and I my stars are round edge to edge so it cannot be tilt?? if it were tilt this bad, I would think I would notice instantly.
My imaging train at the moment is all m54 and m68 using an Optec sagitta OAG, planewave 0.66 reducer and ZWO filter wheel.
here is the flat in question giving me trouble📷 annoyingflat.pngannoyingflat.pngUsually, they calibrate just well enough that my images are mostly flat but lately I keep getting over correction with them and honestly, I would rather just find the root of the issue.
scope is a planewave cdk that was spot on with collimation from factory according to skywave.
Only thing I can think of still is the filter wheel or something I’m my imaging train is way off center and I’m leaning toward the camera/filter wheel combo.
Any insight would be greatly appreciated as usual!!!
Paul Larkin avatar
Hi, Anthony.
I am not an expert in resolving this, but I do not see in your post how you take your flats. Whether fabric over the front; flat panel; etc. If fabric or something similar, what do use to take them, e.g. NINA FlatWizard etc.?
I imagine those who could better help would probably want to know this, because it’s another set of variables in the flat making process and could therefore be another contributor to your problem.
Perhaps one aspect of checking might be to see if your stretched subs (maybe stacked) also show a similar degree of vignetting. If not, I would imagine it may be something other than just the image train, which from what you describe, is not so narrow as to be a likely culprit.
And finally, if this is a new problem (i.e. did not exist with this scope etc. before) then the question might be, what have you changed? Of course if you have had this problem since day 1, that is possibly a moot question.
All the best, Anthony. There will be some gurus here who will likely be able to help more.
Cheers.
Paul
Well written Helpful Respectful Supportive
Brian Puhl avatar
I know you said the filter wheel looks like it’s stopping centered, but it might be due to a unidirectional setting. I’m not familiar with ZWO, but if there’s an option for unidirectional, I would turn it off. It was an issue with QHY filter wheels for a bit, their fix was flashing new firmware that got rid of uni.
I’m almost willing to put money on it, almost. I just dealt with the same exact issue on a CDK14 with QHY wheel.
Helpful Insightful Respectful Concise Engaging Supportive
pfile avatar
what is the actual difference in pixel values between the dark part and the light part? it may look much worse than it actually is just due to the STF.
and on the topic of unidirectional vs. bidirectional filter wheel motion, at least with ZWO the advice has always been to run in unidirectional mode in order to assure repeatable filter registration. is this no longer the reccomendation?
Paul Larkin · Nov 9, 2025, 02:54 AM
Hi, Anthony.
Cheers.
Paul
I have had this issue with multiple different setups but all with zwo cameras and filter wheels, I use and EL panel and Nina flat wizard to take my flats.
At first, I thought it was focuser sag or something like that because I take my flats with the scope horizontal with the roof closed facing the wall, but I was able to verify that not the case just by aiming the scope at zenith, plus I can see the vignetting slightly in my lights also
Brian Puhl · Nov 9, 2025, 04:00 AM
did not even consider this!! I have a qhy268m with filter I was going to test also but I will go and uncheck that right now.
thanks
pfile · Nov 9, 2025, 04:43 AM
dark side is 0.40 and middle of the flat registers around 0.46. I am going to do some more research on the filter wheel issue, but it seems it is something related to settings and I’m getting conflicting answers between bidirectional and unidirectional. I will probably just recalibrate and then uncheck or check whatever option I have for direction
Brian Puhl avatar
As I understand it, it’s kinda like a backlash thing. If you run it in the same direction always, it’s not an issue.
Willem Jan Drijfhout avatar
Have you tried calibrating the ZWO filter wheel? Sometimes they can develop a little bit of an offset, and running the calibration routine can sort that out. If you do, don't worry about the strange noises coming from the filter wheel. It is quite a noisy process, but should come out fine.
Well written Concise
Geert Vanhauwaert avatar
Hello
Have you checked that the cental baffle tube is correctly placed centered and perpendicular to the primary mirror? For me, il looks as of the light path is partially obstructed by the tube.
Also, even when the telescope is collimated, it can be that the primary and/or secondary mirrors are not centered in the tube or trust, so that the light path is partially obstructed by the top ring.
pfile avatar
Brian Puhl · Nov 9, 2025, 06:14 AM
ok. but if i understand your original post you’re saying that QHY has a bug with unidirectional motion, so they removed the option entirely from the firmware but the driver still lets you set the unidirectional bit, leading to some kind of undefined state in the filter wheel?
Matias Svenningsson avatar
Same issue and found this post and started to investigate on my scope, a SW 150 PDS.
I have collimated it to perfection (i thought).
I always use a laser and stars and gotten very good results with sharp stars but I have had this bad vignetting from one side and always figured it was a street lamp at the corner of my garden.
BUT when googling i made a DYI collimation cap and then I saw my secondary mirror was not in center of the focuser tube. Re-aligned it and collimated and now the vignetting is more centered.
It is not perfect but much better and Im getting there eventually. I made an aggressive stretch to make it more vivible in the pictures below.
Hope this helps.
How to fix circular gradient?
See this image that I recently took. I cannot for the life of me figure out how to fix the circular gradient in the middle of the image. Any help would be appreciated!
Circular gradient in middle suggests vignetting issue affecting image quality.
Aug 25, 2024
New to using a Full Frame Sensor / 50mm round filters. What kind of vignetting should I expect with an f/5 system?
Hello everyone, Now that I have the AG Optical FA12 (12.5", f/5, fl 1570mm), with a stated corrected field of 50mm, I am trying to make sure I am utilizing as much of that cone of light as possible. My imaging train currently is a little bit wei...
Vignetting issues may result from improper imaging train configuration and adapter choices.
Jan 1, 2024
Bright circle in my images
Hello good people. I created a topic a couple days ago about flat frames and i uploaded some images when it was pointed out to me that my images have a bright circle in them and that it might be a problem within the imaging tube with reflections. I d...
Extreme vignetting in flats and lights across multiple equipment setups.
Dec 15, 2023
Strange things in my lights
Hi everyone I am new to the astrophotography world. The other day while i was capturing my light frames i noticed some strange spots. I don´t know if it is dust or if something is wrong with my set up. I would appreciate any advise about what it is a...
Feb 7, 2025
Flat files showing "central obstruction" of Skywatcher 130PDS
I have a Skywatcher 130 PDS, and for imaging I have a TS GPU coma corrector, 5 position filter wheel and ASI533MM. For my flats I use a fairly thick white opaque acrylic plate and this has been working well - it calibrates out dust and vignetting. Bu...
Discusses vignetting issues in flats and lights, directly relevant to author's concern.
Nov 12, 2023
