Dark bands at top and bottom of Minicam8M
Kyle CernigliaAdamJJohn StoneScottFTony Gondola
37 replies566 views
Kyle Cerniglia avatar
EDIT: QHY support responded with the following statement:
“We can basically confirm that this phenomenon stems from the light-gathering limitations of the Minicam8M sensor structure at extremely fast focal ratios (F4), rather than from mechanical obstruction or contamination of the optical path.”
The whole experience from start to end with QHY has been a nightmare, I shouldn’t have strayed from ZWO x.x
Hello all,
I’ve been having a strange issue with my minicam8M. It seems to have part of the frame cut off at the top and bottom of the image.
Up until now, I have been using this camera with a long FL telescope, where the image would bounce around enough that the bands would get averaged out during stacking, but now that I’ve put it on a Carbonstar 150, its extremely noticeable, and is making the camera almost useless.
Here is a stacked image through the Carbonstar 150 with a GSO Coma Corrector, and the Minicam8M through the luminance filter, notice the dark bands on the top and bottom of the image. It’s so severe, that the background gradient tool can’t fix it without significant artifacts.
📷 mc8_f4_stack.jpegmc8_f4_stack.jpegLooking at the flats, you can see a clear band going across the bottom of the image, it seems to have higher contrast the brighter your target image is, so flats don’t work correctly (Not to mention, there is really bad internal reflections you can see splotched all over this frame, which also change with light intensity so that flats don’t remove it all):
📷 mc8_f4_flat.jpegmc8_f4_flat.jpegAt first, I thought this was light leaks, and while I did find some around the focuser that I fixed, it didn’t fix this issue. Now when I have the endcap on the scope, it sees no light.
I thought that there was an obstruction within the OTA, but the artifact stays in place if you rotate the Minicam. I then though it was the filterwheel, but it stays in place even during filter movements (At high framerates I can watch the filter wheel move, the artifact stays in place).
I then wanted to rule out the GSO CC, so I bought the Apertura PRCC designed for this scope, but the artifact did not go away (Although the PRCC works much better than the GSO CC in other areas!).
I then decided to eliminate the camera altogether and reverted back to my ASI533MC Pro with a single filter screwed onto the end of the CC. Everything looked very clean, with the artifact not showing up on flats or stacks. I just had a bit of vignetting that flats couldn’t fully fix in the far corners.
Has anyone else seen this issue with the Minicam8, or other 585 sensors? I’m also reaching out to QHY for their feedback.
BlackStarsAstro avatar
Have you tried the CarbonStar flattener to rule out if is the the one your using? I use a Minicam8 with great success on longFL, shortFL, fast and slow scopes.
Looks like an issue with either the filters or the filter wheel. Return it pronto.
Since you see it in your flats and it’s independent of rotation my guess is that its not optics or light leaks but something in the camera. It should be very easy to confirm that. Take just the camera, point it at a wall and pull an image. The sky at dusk would work well also. If you still see the artifact it’s RMA time.
BlackStarsAstro · Nov 8, 2025, 05:04 PM
I started with a GSO CC, now I’m using the PRCC that Apertura built for this telescope.
Tony Gondola · Nov 8, 2025, 05:27 PM
I only see it when the light is focused (Carbonstar 150, Towa 339, Askar 128 Guidescope). If it’s unfocused ambient light, then I don’t see it.
Good news, it’s not the sensor or camera back end. Basic trouble shooting at this point would say that you need to start subtracting parts of your imaging train, take a flat, keep going until the effect goes away.
Concise Supportive
Tony Gondola · Nov 8, 2025, 05:57 PM
Per the original post, that’s exactly what I did.
The common denominator is the Minicam8.
I’m assuming that your test using unfocused ambient light was without the filter wheel in place?
Well written Respectful
Tony Gondola · Nov 8, 2025, 08:44 PM
You can't remove the filter wheel.
I did try it in an open position with no filter though with the same result.
Well written Concise
AdamJ avatar
Assuming you are not using the off axis guider? If you are make sure the prisum is placed correctly.
AdamJ · Nov 9, 2025, 04:12 AM
Correct, I’m using a separate guide scope.
John Stone avatar
https://www.astrobin.com/forum/c/equipment-forums/player-one-uranus-m-pro/im-getting-terrible-pictures-with-this-camera-can-someone-help/
Well written Respectful Concise
AdamJ avatar
I take it that the carbonstar is F4? So ifnits not working at F4 what F ratio is it designed to go down to?
Adam
ScottF avatar
I’ve used it on the carbonstar 150 without this issue.
ScottF · Nov 11, 2025, 12:42 AM
Hi Scott,
Are you able to share the camera settings you’re using?
ScottF avatar
Kyle Cerniglia · Nov 12, 2025 at 12:35 AM
Hi Scott,
You mean gain and exposure time?
ScottF · Nov 12, 2025, 03:22 AM
Hi Scott,
Anything really.
Gain, color balancing, HDR, etc.
Dave avatar
I have the ToupTek 585 Mono on a Carbonstar and haven’t seen this exact issue, but did have something similar with a readout error and the image shifting right with with what should be the right edge of the image filling in the left side like an old VHS tracking error. Very frustrating. It seems to have been down to a bad USB3 cable (at least I hope that’s it and the last I’ve seen of it) but one interesting bit was that I only saw the issue in NINA and couldn’t reproduce it in SharpCap. So new cables and different software may both be worth a try here.
I also recall seeing others had issues with the ToupTek filter wheel having an internal IR light/sensor combo that was causing internal reflections/glow. It was fixed in firmware to turn off the light when not rotating filters so might be a similar issue with the Minicam8, but I’d think others would have flagged that by now if so.
AdamJ avatar
Yes F4 is really not thst fast if it was an intrinsic issue I woukd expect more reporting on it. It almost looks like a stacking issue to me, am assuming the OP has checked the alignment of all his subs etc.
I dont really see the issue in the flat that he tried to point out?
AdamJ avatar
What I am not getting is if it is visible in the flat why its not correcting out. Are flats sufficiently long, properly matched in gain, taken in the dark etc. Using the right settings so using darkflats, not offset or dark scailing.
Lots of images at faster than F4 not showing this issue, am goingnto say its a stacking artifact or user error in flat calibration.
ScottF avatar
Kyle Cerniglia · Nov 12, 2025 at 05:40 AM
Hi Scott,
Anything really.
I used it at gain 80, 300sec exposures on the carbonstar for DSO.
John Stone avatar
You can say what you like, but there is a problem with the sensor for some customers.   I have a PlayerOne 585 mono camera that produced "blotchy" flats that no matter what I did simply could not calibrate the lights.   I took that camera off and put on a Touptek in the exact same conditions and now everything calibrates fine.
I suggest the OP open a ticket with QHY and get the camera exchanged.  That's what I'm in process of doing.
Helpful Concise Supportive
ScottF avatar
Here is a master flat for the sulphur filter with my QHY mini cam 8 mono with the carbonator 150. It’s a compressed jpg, but I see none of what you do. Like others have said, may be a return to QHY is needed. SulphurMasterFlat.JPG
Mysterious star trailing solved: a cautionary tale of fan vibration with a fan cooled (especially ZWO) camera.
Suddenly after no problems with star shapes, the next night out they were just terrible! Below I show a gif comparing two 2 hr stacks, one with the good stars, and the next with elongated stars. In this example the distortion was vertical. But later ...
Author experienced camera issues; fan vibration troubleshooting may provide alternative explanations.
Nov 18, 2025
Band Across Sensor
Hello I own a 367C Pro and lately I have noted a band of what appears to be vignetting from light leaking into the optical train. Always across the top part of the sensor. Any ideas?
Dark bands on sensor; likely same light leak/vignetting problem as source.
Jun 7, 2024
Where to Look?
I’m doing LRGB imaging with a 120mm refractor with a reducer. I’ve got a blotch showing up on my subs, however, only on the R,G,B filters, not the L. The blotch is in the exact same place and shape on all three filters. Under normal circumstances I’d...
Dark bands artifact may relate to filter-specific optical path issues causing blotches.
Nov 10, 2023
Dark vertical streaks in stacked image
I've been struggling with trying to understand the source of these streaks I see in some recent stacked images. I'm hoping someone here can offer an idea as to what the source is. I'm hoping it's not the camera itself. My set up is a ...
Dark streaks in stacked images could relate to author's unspecified Minicam8M problem.
Aug 21, 2025
Etaloning effect with 2600MC and dual band filters
Hello all, I’ve been trying to work out the cause of what seems to be an issue with an etaloning effect in my images recently. I’ve only been imaging for a little over a month now but this is the first time I’ve seen this. Doing some research, I’ve r...
Etaloning at fast focal ratios (F4) directly relates to author's sensor light-gathering issue.
Jan 4, 2026
