I like galaxies, but....
TiffsAndAstroDoug CroweCraig Towellandrea tasselliErlend Langsrud
52 replies1.3k views
TiffsAndAstro avatar
I'm a noob but it seems in my bortle6 with very average backyard seeing, maybe 2", and I think galaxies and clusters, eg m51, m106, maybe down to Stephans quintet are reasonably achievable astrophotography targets for me one day. Depending on your definition of reasonable of course.
Most cameras are 3.76 microns and my weather sucks, so gathering more photons in less time is important.
This means about 1000mm to avoid over sampling? So a 12 inch f3.3 would be ideal.
What would be a more realistic scope  without too much compromise on aperture, weight, and focal length?
My mount is probably ok for a 8 inch mirror, maybe a 9.25 with a counterweight. Guides around 0.7
Currently using a C6 at f10
Craig Towell avatar
I was in this kind of position a while ago and went for a 200PDS, along with BYU CNC spider and primary mask. Total under £700 though would be even less with the CYCK stuff, haven’t regretted the choice one bit, an 8” F/5 newt is a very versatile scope.
I think a 10" newt would be too heavy, and would still need too many upgrades I'm unlikely to be good at doing
The package with the f3.45 coma quatro corrector is especially attractive though.
Also Im not keen on image train hanging on by compression rings or screws
Médéric Hébert avatar
TiffsAndAstro · Nov 8, 2025, 12:45 PM
Not sure what mount you have or looking to get. But I’m getting good results with a 10” newt on an EQ6-R Pro.
That said, gotta be carefull of the wind. I know I’m pushing my mount past it’s designed limits
Craig Towell avatar
TiffsAndAstro · Nov 8, 2025 at 12:45 PM
Me neither, mine is fully screwed together, no thumbscrews anywhere
Only thumbscrews here and none the worse for it, for 25 years I'd reckon.
Kristof Vandebeek avatar
Médéric Hébert:
I have a 10" newton on an AZ-EQ6. I wouldn't call it "heavy" but the 10" newton is at the edge of being "easily moveable". My AZEQ6 that it rests on is on the lowest position and this makes it fairly easy to lift the 10" tube on it on the Losmandy style clamp that sits on top.
I agree: you have to be careful of the wind, but other than that the mount can comfortably handle the weight of the OTA + the imaging train. It's usually wrong to assume, but I guess the EQ6R and the AZEQ6 are in the same class of mounts. I don't use it in AZ mode though, back in time I had a great opportunity to purchase the AZEQ6 (while I was looking for an EQ6) and that's the sole reason of purchase.
andrea tasselli · Nov 8, 2025, 03:03 PM
I 2nd this, just thumbscrews and compression fittings and never had an issue. I do have the backend of the imaging train on a tether in case I do something really dumb but I’ve never needed it. One plus is that I can easily change rotation without needing a rotator. It’s not the end of the world if you have to work this way.
Craig Towell avatar
When it comes to thumbscrews what kind do you have? Single, double or triple screws? I do have a moonlite focuser on my 12” newt that has a three thumbscrew compression ring on the drawtube, that is extremely secure as the screws are large and you can really torque them up. I would definitely trust that if it was on my 8”, but definitely not the skywatcher version it did have, that didn’t feel like it could hold much at all without tilt.
Three and two screws although I have used configs where there was just one with a compression ring.
Stargazer66207 avatar
Before I could render an opinion, I’d need to know what type of camera you are planning to use…OSC or MONO. Also, chip size and pixel size.
Ron Abbott
Ron Abbott
533 likely but maybe 571. a 585 mono combo is appealing smaller pixels but binnable.
This is just for galaxies m51, m106, NGC 891 ish size. Occasional excursions to groups.
Ty everyone for suggestions.
I'm not keen on newts, as while I like the results of sorted ones, I fear mine would never be
200mm at f4 seems a reasonably happy compromise for either sensor size, but seems restricted to newts?
Médéric Hébert:
Ioptron Hem15. I think more than 8 inches  would be pushing my luck
Carrying it in and out so easily to dodge rain makes it a photon bucket  ;)
TiffsAndAstro:
You would already doing it.
TiffsAndAstro:
My C6 and accessories is too much for it already?
TiffsAndAstro:
...If you were to mount an 8" Newt on it.
Craig Towell avatar
I think with your aversion to newts and the mount you have, you already have your ideal galaxy scope in the C6.
You could be right. I Just need to get the most from it.
Doug Crowe avatar
TiffsAndAstro · Nov 11, 2025, 08:14 AM
That is what I use. A C6 with asi533mc on an Eq6r. I use a celestron .63 reducer. The C6’s are aprox. f/11 instead of f/10, it gives me a focal length of 1058. I enjoy imaging with it. Only drawback to me is if I want to image a larger target, I have to do a mosaic. But it is not that big of a deal. It also has a great fov for lunar.
Doug Crowe:
Ty for this, about to look at your images.
At "F10" I seem to have about 1660mm so deffo f11
1000mm ISH with 533 gets me 0.81 arc seconds pixel scale.
Doug Crowe avatar
TiffsAndAstro · Nov 11, 2025, 05:39 PM
Doug Crowe:
I am getting 0.73 arc seconds pixel scale with mine.
Doug Crowe:
Doug Crowe:
Doug Crowe:
Doug Crowe:
Checking tekescopius my image scale is 0.78 but maybe that will match your 0.81 when I get the reduce close enough.
So are you binning in hardware, software or neither? I'm dubious about binning a osc like ours.
I'm in nw England, I doubt my seeing ever drops as low as 1.5 arc seconds though.
Doug Crowe avatar
TiffsAndAstro · Nov 11, 2025, 06:54 PM
Doug Crowe:
Doug Crowe:
Doug Crowe:
Doug Crowe:
I have never used anything other than bin 1. I have thought about trying binning just out of curiosity.
Doug Crowe:
Doug Crowe:
Doug Crowe:
Doug Crowe:
Doug Crowe:
Me too. You first
Erlend Langsrud avatar
I think the best choice for those galaxies is a very large refractor. Esprit 150 maybe.
The sensible choise is a 8” newtonian.
The practical choise is a 8” SCT or RC. Easier to handle than the newt and less affected by wind
