RedCat 71 WIFD vs Ultra-Cat 76 — which one’s really better?
13 replies620 views
Deniz Üzel avatar
Hey everyone,
I’m setting up a deep-sky rig and can’t decide between these two William Optics bundles:
🔹 RedCat 71 WIFD + ZWO AM3 Full Package
🔹 Ultra-Cat 76 + ZWO AM3 Full Package
Both are almost the same price, so I’d love to know:
– Which setup would you go for, and why?
– What are the real differences between the RedCat 71 WIFD and Ultra-Cat 76 (optics, image circle, sharpness, speed, etc)?
– Is the 76 worth it, or are they basically the same in real-world performance?
Any insights from people who’ve used either (or both) would be awesome.
Thanks in advance — clear skies!
– DÜ
ScottF avatar
I don’t have either but if it were me, I’d get the 76mm. Having a standard focuser makes adding an electronic focuser easier and avoiding belts and such.
Dunk avatar
ScottF · Nov 7, 2025 at 09:28 PM
The 71 is a WIFD - no belts needed.
The 76 appears to be the better scope though - 5-element Petzval (vs 4 “Petzval-like”), better glass, larger image circle, slightly faster/longer for essentially the same price.
Well written Insightful Respectful Concise
ScottF avatar
Dunk · Nov 7, 2025 at 11:48 PM
Yep. I looked at the wrong scope.
Rick Krejci avatar
If you look at the spot diagrams for both, the Ultracat 76 should have far tighter stars from the center and especially the corners.
Well written
AstroÅmazer avatar
Not RedCat 71. I had a refurbished, non WIFD version with the helical focuser, I got directly from William Optics, traded in for a new GT81IV.
I have not used the UltraCat 76 but is has comparable glass to the SQA 70 which I have now and there is no comparison. SQA 70 is super sharp and only limited by my seeing.
I like William Optics build quality. Even though my RedCat 71 developed focuser issues, their customer service was great. It was within the warranty period, and I did not want it back as I did not like the helical focuser. They gave me the option to trade up (or down… I went up 10cm) to a GT81IV bundle paying the cost difference (I think it was ~$100, GT81WIFD bundle would have been much more). If the UltraCat76 had been available then, I would have gone for that.
But comparing my RedCat 71 before the focuser issues, to the SQA 70, the glass quality, hence the picture quality is in a different ballpark. FPL55 > FPL53, especially if you plan to use small-ish sensor cameras (3.76um or less).
Al Loan avatar
Hey there, I have been imaging with the newer RedCat 71 WIFD with a ASI2400MC pro for ~one year. The scope has had zero issues, the removal of back focus has been a real boon. The images are excellent with tight stars right to the edges,. My only issue, if I was to have one, would be the screw that hold the rotation of the focuser barrel. It has a tendency to loosen which results in the inadvertent rotation of my camera and the ZWO filter wheel. My solution, (very high Teck) was to attach a wire to the filter wheel to fixed location on my scope to prevent any rotation.
Keith Hanssen avatar
I purchased a spacecat 61 wifd last year and love it with a full frame camera so much I bought the ultracat 76 last month. I used it once on comet Lemmon full frame and it performed perfectly. My only issue is that the ultra cat doesn’t have a built-in adapter for a 2-inch threaded filter like the spacecat so I’m returning the ultra cat for a redcat 71 wifd. I missed that tid-bit of information before purchasing the ultracat.
Brooks Weiner avatar
Ultra Cat 76 Arrived today! paired with 2600MC pro, 120mm guide, on AM3 mount. Got it assembled, went out just to polar align, check focus. Took some test shots stars look good. Will try and do a short run tomorrow night. Moons gonna be a bit bright though. Had been running a redcat 51 for a while. Took the guiding a while to settle down. It did but I am a little concerned it was the weight, I had my top end all on the scale, I was under 15 lbs .
Bob Santos avatar
Can’t wait to hear your thoughts. I just picked up an Ultra-Cat 76 yesterday. It will probably be a few weeks before I can get it it outside.
Deniz Üzel avatar
im very excited to hear u guys opinion about the ultra-cat 76 im thinking of buying one after new years, i would really appreciate your opinions and concerns about the scope.
Thank you
NittanyAstro avatar
AstroÅmazer · Nov 8, 2025, 02:59 AM
Interesting - I have a RC 71 original model with helical focuser and mine broke as well. It is fine now, but I didn’t think to ask them to let me trade for something different - good thinking.
DavesView avatar
Deniz Üzel · Nov 7, 2025, 03:50 PM
Hey everyone,
– DÜ
I have the UltraCat 108 with an ASI6200MM Pro. The HFR I have been getting using HocusFocus from all of my filters ranges from 1.54 to 1.67. That is far better than any other scope I own. I love the scope, but I was never able to master the STX (tilt adjuster). The push plate is sort of floating as it has no ‘nut to butt’ position (zero tilt coming from the tilt adjuster) where the push plate is flat against the pull plate. Instead it is riding on auto tension screws. I replaced the OTA tube extender, the STX and the rotator with an adapter I had made in Germany. Coated the inside with air brushed Musuo Black. For any tilt, I put an OGMA Z’Tilter on the camera and with 5 adjustments, I was as flat as you can get it. In short, the optics are outstanding. I would expect the same out of the UltraCat 76. Beware of the STX, but I’ve read where some people love it. I own 3 WO scopes, RedCat51 WIFD, FLT91 and the UC108. But in fact, it’s always something with William Optics. The FLT91 came with dust all in the tube and don’t get me started on the focuser sag of the 91. The UC108 came with a huge spec in between the front lens group, so I sent it back and got another. Also, I discovered a huge light leak in the UC108 and it turns out eight screws had not been inserted and a gasket had not been placed inside the tube. They sent the screws and gasket out to all of us that had ordered in the first batch. It seems to be a crap shoot when it comes to WO.
EDIT: And I forgot to mention that I now have a permanent black cloth covering the ruler window of the WIFD focuser of the RedCat 51 as it has a light leak. Not too bad, but enough that I can see it in the BIAS and DARK subs if I shoot in a lighted room, or outside in daylight. Even more so in the histogram of those subs.
Well written Engaging
DavesView avatar
Check out https://www.astrobin.com/3bhoo3/. Yungshih apparently has access to everything WO, including the UC76 (link posted) and even the prototype UC132.
