V Curve from NINA & Moonlight Nightcrawler
Jerry GerberJohn HayesScott BadgerBill McLaughlin
28 replies525 views
Jerry Gerber avatar
Can someone explain why this V-curve looks the way it does? 📷 20251031_202625.jpg20251031_202625.jpg
The focus is good, HFR is acceptable but the curve looks weird…
Jerry
D. Jung avatar
Is this repeatable?
If you are using hocus focus you can enable saving the focus images so you can inspect strange outliers visually.
If you get an hfr of 0 something obviously went wrong.
What settings are you using for the focus curve interpolation?
Jerry Gerber avatar
D. Jung · Nov 1, 2025, 05:49 AM
Is this repeatable?
Not really, it seems to deviate from the normal V-curve once in a while.
Jure Menart avatar
Maybe N.I.NA. log would reveal what caused it?
Scott Badger avatar
HFR of 0 means it’s not finding any stars in that exposure for some reason. Happens to me when I’m trying to image/focus between passing clouds. It might also happen if the change in focus setting occurred during the exposure, distorting the stars enough so they’re not recognizable.
Scott
Well written Helpful Respectful Concise
Very likely a small passing cloud. If it doesn’t happen regularly, I’d ignore it.
Well written
John Hayes avatar
Jerry,
I’ve found that that’s not uncommon with NB filters if the exposures are too short. Try increasing the exposure time by maybe 50% just to see if that fixes the problem. If it does, then dial the exposure down a little to keep it above the threshold where you get this problem.
Jerry Gerber avatar
John Hayes · Nov 2, 2025, 04:19 PM
Jerry,
Hi John,
Yep, and on top of using an Ha filter when this occurred, the moon is getting full. Between the filter and the moon it’s no wonder this happened. I increased the exposure time to 10” and this helped. I’m still getting over 10 points on the curve and the HFR is normal, so I think it’s OK.
Thanks,
Jerry
Scott Badger avatar
Jerry Gerber · Nov 2, 2025, 05:13 PM
Jerry,
Hi John,
Thanks,
Jerry
But….affecting only one image out of nine? And one close to focus vs others more out of focus? And not repeatable?…..my money’s still on the cloud.
Scott
John Hayes avatar
Hi John,
Thanks,
Jerry
I’m relatively new to NINA and maybe there’s a way to solve it but I haven’t figured out how to designate which filter I’d like to use for focusing when shooting narrow band. In SGP, I can tell the system to use the red filter for focusing when shooting Ha. In NINA, it appears to force me to use the Ha filter for focusing which requires super long exposures—and that’s just crazy. Maybe someone can jump in to tell us how to fix that problem, which would fix the kind of data dropout that you originally asked about.
Jeffery Richards avatar
John,
Are you asking about doing/using filter offsets? Usually in NINA filter offsets use just a single particular filter to do all focusing and then a measured offset is applied for the filter being used for the exposure. It does require several runs to figure out the actual good offset to apply for each filter but many folks don't trust them and therefore just focus for each filter.
There is a plugin (filter offset calculator) to run the offset calculator routine.
Scott Badger avatar
John Hayes · Nov 2, 2025, 09:04 PM
I’m still using legacy NINA and in the autofocus section, you can choose the filter used for AF. I have a backup computer with the latest NINA, though, and like you said, I don’t see where you can choose an AF filter…..wonder why not. In any case, you’d want to have offsets, or parfocal filters, if not focusing with the filter you’re imaging with.
Scott
Jerry Gerber avatar
Hi John,
Thanks,
Jerry
Hi John,
Options-Autofocus is where you set your filter parameters. Any settings on individual filter exposure times overrides the default filter time at the upper right. Equipment-Filter Wheel is where you set up your filters so that NINA knows where your filters are. Also, under Options-Plate Solving, you can set which filter you want to default to when plate solving and the exposure time. I always default to Luminance when focusing for the first time at the beginning of the session to ensure that slewing and solving goes OK.
I’ve attached a sample NINA Advanced Sequencer script for you to look over. Place the script file in the folder where you want to store your scripts, you can choose any location for the folder in NINA-Options-Imaging. Then you can open the script in the Advanced Sequencer. I hide the legacy sequencer as the advanced sequencer is so much more comprehensive. The sample script I attached will need the free plugin Sequencer Powerups to work correctly.
Jerry
Mono LRGB Automation Sequence.json
Rick Krejci avatar
Scott Badger · Nov 2, 2025, 09:17 PM
Scott
If you select Filter Offsets button at the top of the Options→Autofocus page, it’ll show the option to set the AF filter on the bottom.
Jerry Gerber avatar
Jeffery Richards · Nov 2, 2025, 09:13 PM
John,
I always focus after a filter change, it takes about 2 minutes and I’ve never shot using more than 4 filters in a nightly session so we’re talking about 8 minutes per imaging session to get good focus for each filter.
Well written Helpful Concise Supportive
John Hayes avatar
Thanks for all of the answers about AF in NINA. Yes, I know where to set the AF filter, but that’s not what I’m looking for. NINA appears to assume that you will always have offsets set up and that’s certainly the best way to operate. However, it is also possible to operate without offsets if you can choose to focus for NB imaging using a broadband filter. The difference in focus position for a red filter and a Ha filter will be zero. So, in this case, I simply want to tell NINA to use the red filter for focus whenever the sequence is calling for the Ha filter to image. That is easy to do in SGP so I’m wondering if the same capability exists in NINA.
Well written Insightful Respectful
Jerry Gerber avatar
John Hayes · Nov 3, 2025, 12:47 AM
As Rick pointed out, it’s possible to turn the offset button on or off. The sequence can be programmed to focus using the red filter, then change filters to the Ha and image. Maybe I am not understanding the question…
Rick Krejci avatar
Then just set the offset to 0.
John Hayes · Nov 3, 2025 at 12:47 AM
For narrowband imaging, I have always found it best to use V-Curve based focusing on a single nice bright star centered in the field.
This is what Voyager has an option. Focus on the field, or on a bright star. Can even combo them, so focus on the field for LRGB and focus on a star centered with a ML-backed Focus Max like curve of the focuser, for Narrowband.
We do not use offsets at all. We could if we wanted as measuring the offsets can be done with a few lines of Python code — but we focus the telescope instead as we believe that produces the highest quality data over using static offsets.
John Hayes avatar
Ok, it sounds like what I’m asking for is possible so I’ll just have to go play with it a bit more to figure it out. Thanks everyone!! - John
John Stone avatar
John Hayes:
John,
Here's how I might do it in my sequence, though I'm not exactly convinced there's no filter offset between the broadband filters and the narrowband ones.
Bill McLaughlin avatar
One thing that I would note about offsets in NINA is that a lot of folks use the “filter offset calculator” to obtain the offsets. I use this as well but have found that it can yield often wildly different offsets from one run to the next, despite having a high quality focuser (Nightcrawler, Optec, etc.) set up properly and a well set up focus routine that yields nearly perfect curves and high confidence levels. I suspect it is not the routine but the variable conditions between runs that are the cause. The short version is never depend on just one or two runs.
To the “but that is not possible” folks, I would suggest that you do a few runs. You will find the results vary and what is worse, the variance is often significantly greater than the depth of focus for your system. Use those results and you all but guarantee bad focus.
My procedure is to figure my DOF and then do many runs of the calculator, keeping track of the results for each. When you have at least 6-10 runs, you should be able to reject the outliers and converge on an offset that is within the DOF for your system.
One of the things about a good set of offsets is, of course, speed, since you do not need long exposures for the narrowband filters but it also lets you (in NINA) specify multiple exposures per focuser position in the curve, which statistically improves the results. That does take a bit more time but nothing like what focus per narrowband filter does.
Results may vary but I always focus with the green filter. It is not much more time consuming than the luminance but yields smaller stars and is mid-wavelength so works well for both red and blue.
Helpful Insightful Engaging
John Stone · Nov 6, 2025, 11:44 AM
I would agree. I have found that there is a small but consistent offset between Red, Ha, and S2.
Daemon de Chaeney avatar
I tried that test you suggested Bill, and I got a max variance of 4 focuser steps which is 0.25 degrees of rotation and a median variance of 1 step or 0.0625 degrees over 10 runs. My maximum filter offset on my Antlia set is also 4 steps, which may well just be variance on a basically parfocal set since 5 of the 7 from a 3 run average have offsets of 0 steps, but on my little scope this doesn’t make any meaningful difference. Might be enough to upset something with a longer focal length though.
Arun H avatar
Bill McLaughlin:
I guess it depends on your configuration, but do you really save that much time from using offsets?  For example, if you have to focus three or even four times a night - out of 480 minutes of imaging time,  you are maybe losing 16 minutes to focusing time. Which is about 3%. Seems not worth it for poorer quality focus than an actual V curve focus. I think the bigger benefit is if you wish to switch between filters in an imaging loop to collect RGB or SHO "simultaneously", i.e., have a set of "complete" exposures at all times in case you need to cut your image short for lack of imaging time. But if you are taking Ha during nights of higher Moon interference and OIII closer to the new moon, focusing per filter makes more sense.
Why no one in NINA is looking into developping a single star autofocus instead of current local field method
I am surprised no developpers in NINA are looking into implementing a single star autofocus method versus the current one which average the HFR of several stars in the image field. You can find the single star autofocus method in Voyager which was th...
Discusses autofocus methods and HFR measurements relevant to V-curve analysis.
26 days ago
