Support requests are handled via the support form so they can be tracked and resolved properly. This section is for community discussions about the AstroBin platform.
I need some general advice concerning plate solving in PI. I have the gdr3sp-1.0.0-s-01 and gdr3sp_1.0.0-s-02 files downloaded. I’m getting astrometric fails at the end of stacking. Also get fails when I run solver or spcc. The image(s) solve fine if...
Directly addresses plate solving failures, likely same advanced issue.
Hello everyone! As you can guess from the title, I’m still fairly new to this hobby. I have a tracker but not a go-to mount unfortunately, so all my targets so far have been the classic easy ones to find - the ones you can pretty much see with the na...
Different problem; focuses on target finding in light pollution.
Hi, I am using an ASIAir Mini with a Skywatcher EQ AL55i mount connected via the serial cable (could not get any other connection to work properly). I can control the mount from the ASIAir app and I got my camera and focus set up. Plate solving works...
Troubleshooting mount/alignment issues; may relate to plate solving problems.
