How do I set WBPP to reject files with background issues
7 replies174 views
DavesView avatar
Is there a setting to reject the worst subs in WBPP?
Brian Puhl avatar
Use Subframe Selector, or Blink.
I wouldn’t trust WBPP alone to reject anything. If theres just a single bad sub, maybe two, and you have 50-100 good ones, pixel rejection will do it’s work and essentially get rid of those bad ones. Beyond that, you’ll want to do manual intervention.
Andrew avatar
As far as I know no…
You can only adjust the weighting parameters which won’t entirely reject it but will weigh the bad subs so low it won’t have any affect on the final stack.
This is already pretty good on default. However I just cull them using blinking methods and or subframe selector. Keeping bad or subpar subs to me just feels weird.
bigCatAstro avatar
Brian Puhl · Nov 1, 2025, 12:26 AM
I agree, I would use Blink to page through your subs and just make sure that you have a low number of poor subs to good ones if you’re going to let pixel rejection do its thing. If you have a lot of iffy subs, then go through them yourself and reject them from your batch.
DavesView avatar
Yep! Blink is how I currently weed out the bad. Thanks!
Kevin Morefield avatar
Agreed on Blink. Get rid of the subs with obvious gradients (that differ from the other subs) and those with glowy stars from high clouds. Rejection can’t handle those situations well.
BlackStarsAstro avatar
Brian Puhl · Nov 1, 2025 at 12:26 AM
I agree. Even better than blink, Tenmon app on Macbook allows you to do full screen blink with the ability to delete the bad frames. Not sure if it runs on PC. Its been a while so im not sure if you can currently delete directly from the blink in PI.
Rick Krejci avatar
I wish Nina let you have median values in the name. I have HFR to give an idea of seeing and star count which does help identify background issues ( as well as seeing). Median values tend to be the best identifier of clouds for me at bortle 4. I track it on the image graph, but would be nice to have it in the name of the file to quickly see it
How to identify which images WBPP rejected during stacking?
I ran Pixinsight WBPP and during the integration step a number of the images are rejected. Not an issue with that but how can one trace back afterwards which images have been rejected? In this instance, I was stacking data from 2024 and 2025 and abou...
Identifies rejected images during WBPP integration, directly addresses rejection tracking.
Aug 17, 2025
WBPP Frame Selector (new): how do you decide which frames to reject?
Hi everyone, I’m new to the AstroBin forum, but I’ve been doing astrophotography for quite a long time. Glad to be here 🙂 Recently, WBPP in PixInsight has implemented the Frame Selector, and I’d like to learn how to use it properly. Until now, I’ve a...
Discusses frame rejection decisions in WBPP Frame Selector tool.
Feb 4, 2026
WBPP interactive frame selection: tracking included frames for Astrobin uploads
I used the new interactive mode for frame selection in WBPP and it works great. It is easy to see what should be rejected in your light frames and what to include. It saves the hassle of getting into SubFrameSelector and making a copy of the selected...
Covers interactive frame selection and rejection in WBPP process.
Feb 1, 2026
APRENDE WBPP FACILMENTE
https://fosc.sacastello.org/wbpp-facil-castellano/
Relevant - directly addresses WBPP settings and file rejection options.
Jun 13, 2025
