Batch processing multiple single frames with sub and dark frame.
1 reply92 views
Joe Haberthier avatar
I want to try to take a movie of star trails, but I would like to subtract a dark frame from each sub, and save it with its individual file name. then make the series of modified subs into a movie. Is there a way of doing this automatically? In Deep Sky Stacker? I dont want to use the cameras mode of doing this , because ill be missing twice the data.
planethunter avatar
You probably have to use 2 programs to accomplish the task.  DeepSkyStacker can easily subtract all the dark frames.  Then you can load those frames into Photoshop and easily create a movie or GIF.
Deep Sky Stacker
1.  load light frames and dark frames then check all
2.  click stack checked pictures then click stacking parameters
3.  select intermediate files tab and select create a calibrated file for each light frame
4.  then you can go into your light frame folder to get all the calibrated frames (which are the dark subtracted frames)
PhotoShop
1.  load all frames as layers
2.  create frame animation, then select all layers and choose make frames from layers
3.  export to file as animated GIF or movie
Siril v0.9
Hello, I would like to present you, Siril, a astrophotographic tool that has just been released in the end of 2015. 1 - Presentation: Siril is meant to be Iris for Linux (sirI-L). It is an astronomical image processing tool, able to convert, pre-proc...
Astrophotography processing tool that may automate dark frame subtraction workflow.
Jan 5, 2016
