Looking for some general critiques for NGC 4535
14 replies600 views
David Friedlander-Holm avatar
Hi, new here. I’m trying to nail down a process in Pixinsight for processing my images, but I’m having a crisis of where to go from here. I was also hoping to get some general image critiques. Anything helps! (a brief note that I know about the star trails, our off-axis guider has been uncooperative recently)
https://app.astrobin.com/i/v36wy1
Overall it looks good but it does need more time. I background is rather dark and I suspect you could go a lot deeper into this field given your hardware. There are some odd red streaks up near the top of the frame which I assume are reflections from a bright star outside the FOV. You could and probably should retouch those out.
John Esser avatar
Hi David,
the picture of NGC 4535 doesn't look bad. I had a look at the histogram and think, you could try to stretch it a little bit more. You cannot expect much more from only 42 minutes of integration though.
What is your general workflow? Maybe we can tell you, which steps you can make or improve.
Greetings
Helpful Respectful Concise Engaging Supportive
bigCatAstro avatar
Tony Gondola · Oct 27, 2025 at 08:24 PM
I suspect the background is darker due to those red flares being present. OP, you can try to blemish blast/clone stamp those flares in PI, Seti Astro Suite, or Photoshop on the starless layer. Im very confident they’d come right out.
Thanks for the feedback! What tools should I use for removing the blemishes inside PI?
I’m following this process in the image. 📷 RGB2-Processing_of_monochrome_LRGB_images.pngRGB2-Processing_of_monochrome_LRGB_images.png
Thanks again for the feedback, I’m planning to take more subs in the future.
bigCatAstro avatar
David Friedlander-Holm · Oct 27, 2025 at 08:48 PM
I use Seti Astro’s Blemish Blaster in PI.
David Friedlander-Holm · Oct 27, 2025, 08:48 PM
The clone stamp tool that can be found in most photo processing packages like PhotoShop, GIMO and Affinity Photo.
Daemon de Chaeney avatar
Please feel free to correct me if I’m out of place, but something seems off about the galaxy colour. I’d expect a barred spiral to be warm in the core and blue in the arms, and other images of this target do show that pretty normal trend, but yours is warm in the arms and blue in the core.
Well written Insightful Respectful Concise Engaging
Habib Sekha avatar
Daemon de Chaeney · Oct 28, 2025, 10:52 AM
Good catch! Perhaps the colour channels might have been mixed up when using ChannelCombination or something equivalent to it.
Well written
That is a good catch, thanks.
My G subs stood out quite a lot (seen here) 📷 Screenshot 2025-10-28 at 09.34.04.pngScreenshot 2025-10-28 at 09.34.04.pngbut after plate solving and using SPCC, this is what I got.
📷 Screenshot 2025-10-28 at 09.33.21.pngScreenshot 2025-10-28 at 09.33.21.pngI’m confident that I selected the correct channels in Channel Combination, is there anything else that would cause the odd inversion that you pointed out?
You got the channels wrong. Try every possible permutation (hint: RGB, GBR, GRB, BRG) assuming no repetition (still a possibility though). Forget about SPCC, just do a CC and BN and see which one that matches expectations.
Michael avatar
Which galaxy type are you selecting in SPCC?
I think, this galaxy is a “Sc” galaxy
In the White Balance dropdown in SPCC the default is “Average Spiral Galaxy” —> in the dropdown menu you must scroll down to the bottom, where you find Sa, Sb, Sc, Sd.
Sometimes it helps to try the adjacent types.
(For M81 I struggled a lot … until I learned to select Sa in SPCC.)
I don’t think it’s possible for the SPCC white balance choice to fully transpose colour Michael. It can make a hash of the colour and give you odd things like purple galaxies (I found out by trying to work out how people got purple galaxies with RGB subs), but not transpose the yellow and blue information. Again of course, I speak from little experience with PI, but a lot as a photographer.
Ok, I’ll take another look, thanks for the feedback.
Well written Respectful
Habib Sekha avatar
Just FYI, I seem to recall a recent post somewhere of someone who had unexpected colours in his stacked images. The “right” images were added into ChannelCombination, however, it turned out that he had interchanged a few filters in his filterwheel or put in the wrong slot numbers in the software.
Concise
[RCC] Honest Critique of my Jellyfish Nebula
I’ve been doing astrophotography for about three years and have been looking to improve my image quality. I welcome honest critique of my jellyfish image. Thank you in advance! https://app.astrobin.com/u/Scottchambers24?i=b4fdhk#gallery
Seeks processing advice and critiques for deep-sky image; directly relevant experience level.
Apr 17, 2025
Round stars using a guidescope at 1000mm - possible?
Hi All, I recently bought a ZWO FF130 to supplement my great little FF65. Normally with the smaller scope I’ve been getting good guiding with the ZWO 30F4/ASI120mm combo of between 0.5”—0.8” RMS. This is all sitting on an AM5N/TC40 (with weights in t...
Off-axis guider issues relevant to star quality problems mentioned.
Feb 5, 2026
One Click, Real Science
Early last summer, while I was working on a new image, it occurred to me that the SpectrophotometricColorCalibration tool in PixInsight was generating all of the information that is needed to plot star data from a globular cluster as a Hertzsprung-Ru...
PixInsight color calibration tool directly applicable to processing workflow.
Oct 13, 2025
Critique my image!
Hello everybody, ive recently finished one of my largest projects yet, a 115h integration of Bodes Galaxy in HaLRGB, and I was looking for some criticism, because sometimes im blind to some problems Ive done in my editing, was looking to get some fre...
Author seeks general critiques on deep sky image; similar RCC request format.
Apr 12, 2025
New scripts for PixInsight: ExtensionToolset
Hi everyone, I have developed ExtensionToolset, a collection of scripts to support image processing and analysis in PixInsight. Features included in ExtensionToolset: - AdditiveColorCalibration: A high-accuracy and robust additive color calibration t...
PixInsight scripts may assist with image processing pipeline development.
Aug 10, 2025
