Dave Stearn avatar
M31 Critique please
This is a test image with only 5 hrs of data.
I will be adding more this week as well as Ha.
This was imaged with my wide field setup SQA55 2600MC Pro.
I tried to be more careful with the stars considering that the image is undersampled.
This was processed in Pixinsight using FBPP since this is a test.
https://app.astrobin.com/i/eykt0u
Nice!
I like that you’ve retained the star-like core.
Grigory2020 avatar
Oh man… I would die for an image like that.
sebaromano avatar
Colors look quite nice and natural. I won’t even touch it much more. We all have the tempation to boost colors and detials during last seteps of post-processing and ending up often with distroying the natural look.
Quinn Groessl avatar
Looks great. You could try adding some time towards Ha, but I don’t think it’ll really improve it much.
TiffsAndAstro avatar
Maybe some more Ha but I'd be extremely happy with this result as it stands smile
Vandewattyne avatar
Looks nice (colour & structure) but there are some weird stars, they look like an O.
Dave Stearn avatar
Vandewattyne · Oct 26, 2025 at 09:43 AM
Dave Stearn avatar
📷 image.pngimage.pngThanks, this could be due to my settings using Blur Exterminator. I will reduce the amount of sharpening
Dave Stearn:
📷 image.pngThanks, this could be due to my settings using Blur Exterminator. I will reduce the amount of sharpening
I doubt BXT can produce such a thing, it might enhance it but that is about it. The "hole" is due to pre-processing (CosmeticCorrection) with under-sampled stars, I suspect. This occurs when set to "Auto".
Dave Stearn avatar
andrea tasselli · Oct 26, 2025 at 08:06 PM
Dave Stearn:
CC was not set to auto
Then some other settings, worth checking.
Rick Krejci avatar
Looks nice! I’d look into the star shapes, though. Besides above, they are cross/tic-tac-toe shaped. Did you drizzle? That may help
Dave Stearn avatar
I think I solved the star issue. With the 2X drizzled image I used Correct only BXT and then Resample down to the native resolution using integer Resample.
Dave Stearn avatar
Rick Krejci · Oct 27, 2025 at 01:00 AM
At a high zoom you will see square patterns especially for small stars. The image was undersampled to begin with. I was able to 2X drizzle Gaussian and then Resample down after using BXT. From a normal viewing distance the stars should look good.
Aloke Palsikar avatar
Good colors and quality of image. Has come out well. I personally also have a SQA55 and hence can appreciate the wide angle view !
Great Effort !
Supportive
Al Loan avatar
Nice image, well done!
Manfred Baumann avatar
I like the “natural” colors. Looking forward to see the final result, maybe with Ha. From my POV, making the Ha regions more visible would add value to the image. I am currently working on a M31 image too, but I have to wait for better weather to finish.
Respectful Supportive
Rainer Ehlert avatar
Vandewattyne · Oct 26, 2025, 09:43 AM
Have you checked your alignment parameters?
Dave Stearn avatar
Rainer Ehlert · Nov 20, 2025 at 12:03 AM
How are you viewing the image?
How am I viewing the image?
Well, on my PC monitor
Which software do you use for aligning?
Dave Stearn avatar
Rainer Ehlert · Nov 20, 2025 at 04:56 PM
Reason I asked if you were to view in Classic Mode at full resolution the stars would look good. If you just zoomed in the image would appear stretched.
Ah OK. I just answered to a posting where somebody posted a zoomed image. You wanted critique and some body found it out and it was not me, Sorry.
OK, I understand. I had a similar problem and then tweaked my Star Alignment settings and now everything is OK.
OK, I tried to download your image in order to analyse it but it is not possible.
You know what, forget everything I wrote…
I made a single screen shot of one of the corners but did not find anything, so I really do not know where it comes from.
Sorry for having written those dumb comments…
Request for constructive criticism
RCC: https://app.astrobin.com/i/dj9ou5 Happy Halloween!
M31 test critique — requesting feedback on deep-sky galaxy image.
Oct 31, 2025
Etaloning effect with 2600MC and dual band filters
Hello all, I’ve been trying to work out the cause of what seems to be an issue with an etaloning effect in my images recently. I’ve only been imaging for a little over a month now but this is the first time I’ve seen this. Doing some research, I’ve r...
Author uses 2600MC camera; etaloning could affect image quality.
Jan 4, 2026
ZWO ASI 2600MC producing doughnut artifact in center of images
Hello everyone, I have had a ZWO ASI 2600MC for about a year now, and I have noticed that all the images I have taken with it since then have a strange artifact in them. Basically, it looks like a doughnut in the center of the image. This is particul...
Author uses 2600MC camera; doughnut artifact is relevant troubleshooting issue.
Nov 27, 2025
