Question for owners of the Asi26500mm (P25) camera
4 replies534 views
Mateusz Wiśniewski avatar
Can I connect the new version of the 2600mm pro (p25) to the EFW 7x36 2021 without a tilter, just like the previous 2600mm? The ZWO website doesn't offer this option. Does anyone have the new version and connected it without a tilter to a 7x36 EFW? Can I have some pictures?
Robert Žibreg avatar
It should be possible, what is your imaging train? Did you calculate backfocus?
BlackStarsAstro avatar
the website does show that option. with or without tilt plate.
Makrem Larnaout avatar
Mateusz Wiśniewski · Oct 24, 2025, 07:57 PM
Yes, you can connect it directly, but keep in mind that removing the tilter changes the backfocus from 17.5 mm to 12.5 mm. You’ll need to add a 5 mm spacer to maintain the correct 55 mm total distance to the sensor.
Well written Helpful Insightful Concise
Marcelof avatar
Yes, it is possible. Please refer to this diagram. Depending on your configuration, you may need a 22.5 mm spacer, which is sold separately, or you can use the included 16.5 mm spacer and an additional 5 mm spacer (I did the latter, and it works great).
https://www.zwoastro.com/2024/09/26/asi2600-guide-4-connection-methods-to-get-55mm-back-focus-length-2/
Also keep in mind that if you don't use an OAG, the mounting holes are exposed and if they are not covered, they will be an obvious source of light leakage. I simply used black electrical tape to cover those holes.
Backfocus Epsilon 130ed
I have an Epsilon 130ed, which is the backfocus recomended, the stars in the corner looks like unfocused. I use a camera zwo 2600mm pro with EFW 7X2.
Relevant connector/compatibility information for ASI2600MM Pro and EFW setup.
Dec 24, 2025
2600MC Pro disconnection issues
Hi all, Having an issue with disconnects every since getting a new 2600MC Pro. I am using an ASIAIR Plus and have had over a year of use with a DSLR without this issue ever occurring. This my 3rd night of using a new 2600MCP and on each night have ha...
Discusses 2600MC Pro camera issues; similar equipment to your 2600mm Pro question.
Nov 25, 2025
