Moonlight NightCrawler Focuser at Remote Site
Jerry GerberArun HChris White- Overcast ObservatoryJohn HayesLinwood Ferguson
49 replies1.3k views
Jerry Gerber avatar
I’m noticing the Moonlight Nightcrawler (WR3.5) focuser is taking between 3.5 and 4 minutes to focus. This is done remotely, my telescope is at a remote site. It’s been homed this afternoon.
Is there a way to speed up this process? If it focuses 20 times throughout the night, that’s nearly 80 minutes of time not imaging. I take 5 second focus exposures when using LRGB filters and 8 second exposures when using SHO filters. My autofocus step size is 500.
I have the focuser set to AF After HFR Increase (sample size 10, amount 5%).
Thanks,
Jerry
Jerry Gerber avatar
AstroStew · Oct 21, 2025, 07:17 AM
Jerry Gerber · Oct 21, 2025 at 06:44 AM
Thanks,
Jerry
The only way to speed up a focus routine, is to shorten the focus exposures, shorten the amount of steps and shorten the step size, and increase the HFR increase to 10% will limit the amount of times it focuses. 👍🏻
I’ve read that small step size can increase focus time?? I am noticing my autofocus is running about every 15 minutes.
Jure Menart avatar
Jerry Gerber · Oct 21, 2025, 07:25 AM
Thanks,
Jerry
Hi Jerry,
The steps should be ‘just right’ - too small steps it will need to run much more samples to get the min in the curves (the sharpest or most focused point), too large steps it might not get the resolution to really focus well. 4 minutes seems excessive - maybe try to lower the exposure (I lowered it from 5 to 3 seconds for both - broadband and narrowband) and get number of points (in combination with ‘just right’ step) as low as possible. Check and try to lower also settling time after focuser change.
15 minutes (through all night?) is for sure much too often. First ~1.5 - 2 hours I autofocus at period of around 45 minutes because FSQ106 is notorious for slow cool-down, but after temperature stabilizes I don’t need to run it for long time (1.5-2hours or even longer), except if I change filters of course.
You should check what is triggering auto-focus every 15 minutes. You should also check HFR at start and at the end of auto-focus: If it’s approximately the same, for sure you don’t need autofocus so often.
If you are triggering on HFR change it might be that you have some guiding issues which is triggering autofocus. I had problems with my mount and got a lot of bad frames which were triggering autofocus, so I disable it during that period and trigger only on temperature change (trigger when temperature delta of 1°C).
Jure
Jerry Gerber · Oct 21, 2025, 06:44 AM
Thanks,
Jerry
Jerry,
You have posted dozens of times here — are you sure you are equipped to run remotely? It seems the more you run your system, the more you need feedback from others — far more than any other remote imager I have ever seen, and on manners so basic it is hard to not say anything about it.
Answer: Use Voyager, it focuses 10 times faster than NINA.
-Bill
apennine104 avatar
Jerry,
Being at a dark site, I think you could get away with shorter focusing exposures. Also, I’m surprised it runs so often using the HFR method. That does almost sound like guiding or something else is incorrectly setting it off once the telescope is thermally stabilized.
Also, that step size seems big. But, I use a ZWO EAF, not the Nightcrawler so I am not sure of its resolution, but I assume it’s greater.
I developed my settings by running through the NINA autofocus guide , “Determining Ideal Parameters” section. By using this guide I was able to develop the autofocus settings (specifically step size and exposure time) that work for me, with the shortest routine runtime. Approx. 2-3 minutes every 45min-2hr depending on thermals.
Good luck!
-Chris
Kevin Morefield avatar
Jerry,
You should base your refocus trigger on temperature change rather than HFR. The HFR can change rapidly with seeing fluctuations and that has nothing to do with focus.
Maybe start with 1 degree C temp change as a trigger and see how that goes.
My focus runs in NINA with the Moonlite take about two minutes. So looking at your setting and optimizing them can surely shorten the time. Dedicate a night to doing successive focus runs with different filters and settings till you get a shorter run that works repeatedly.
That trial and error approach is how most of us learned our software and hardware.
Kevin
Rick Krejci avatar
Kevin Morefield · Oct 21, 2025, 02:23 PM
Jerry,
Kevin
Agreed. I gave up on the HFR trigger because seeing HFR deviations are often larger than focus shift HFR variations. I also found temp change triggers were a little fiddly as well. I settled on time and filter change based AF. Generally focus every 30-45 minutes early in the session since the TOA130 takes a long time to settle and then about every hour through the night. Focusing with my Moonlite Nitecrawler takes about 2 minutes. Use 1 second for L, 2 for RGB and 6 for HSO.
Arun H avatar
Kevin Morefield:
Kevin is correct. Triggering based on HFR is a questionable method because things that have nothing to do with focus accuracy can cause HFR to change and then you are getting no benefit from refocusing. Assuming your set up is mechanically sound, the only real thing that should trigger a refocus is temperature.
Voyager is certainly faster than NINA for focusing but the real question here is why you need to focus so often - 20 times a night an absurdly high number. If there is a mechanical drift in your system, you need to address that rather than use focus to compensate. You appear to be using an f/7.6 system, which should be quite forgiving to small drift.
Jerry Gerber avatar
Dark Matters Astrophotography · Oct 21, 2025, 10:11 AM
Thanks,
Jerry
Jerry,
-Bill
Bill—Did you wake up with back pain or a stomach ache? I’ll ignore your unhelpful condescending tone.
Well Written Concise
Jerry Gerber avatar
Jerry,
Kevin
Thanks Kevin, that’s helpful. I’ve read that HFR is the most accurate approach, but like so many things in astrophotography, people have varying opinions on the same thing. I’ll try 1c temperature change. Right now the autofocusing is kicking in every 15 minutes or so, which seems too frequent.
Jerry Gerber avatar
Jure Menart · Oct 21, 2025, 07:41 AM
Thanks,
Jerry
Hi Jerry,
Jure
Thanks Jure!
Bill McLaughlin avatar
Definitely agree that you should use temp to trigger focus and not HFR. As mentioned, HFR suffers from focus triggered by seeing which will do you zero good and just take up time. It also “closes the barn door after the horse is out” in that it only triggers after the HFR has gone up, sometimes just insuring at least one bad frame.
The Nightcrawler has an external probe that should be attached to the OTA as that is the part that reflects the temp change best.
The methodology is this:
1) Calculate the depth of focus distance range for your system in microns. There are several formulas for this that can be found with a web search. Take half of that as the amount you can allow the focus to change and still be focused (half because you can’t be sure that you were centered in that range with the last focus). Convert that to steps for your focuser. Now you know how many steps you can allow the focus point to move due to temp w/o being out of focus.
2) Do a several runs (several nights) to determine how your focus shifts with temp in steps.
Combine the results of the above to determine how many degrees between focus you can tolerate.
For my FSQ 106 N and Nightcrawler that was .5 degree C but that is the older “N” version, not the EDX.
Helpful Insightful
Noah Tingey avatar
Why does it take so long to focus? Is it just slow when it’s moving?
I have not used a Moonlight NightCrawler, but a tip a NINA developer told me for my ZWO EAF: Decrease your device polling interval down to 0.5 (or even 0.35) seconds. The default is 2 seconds, which is a safe default, but autofocus runs can be made much faster if you decrease it.
Also: Just to confirm, do you have filter offsets set up? Focusing 20x in one night is surprising to me… I usually only need to focus maybe 3-4 times with offsets properly configured.
Well Written Helpful Respectful Concise Supportive
Jerry Gerber avatar
I made an adjustment to NINA’s polling interval time because NINA’s logs were warning that my GM1000 mount was taking too long to respond. This stopped the warning but it seems that this polling interval time applies to every device NINA is connected to, so I am now wondering if the focuser has slowed down because I changed the interval time from 2 to 10. I can change it back to 2 and live with the Log’s warning as that’s far better than having my focuser take so long. I am not even sure that the polling interval time is affecting the focuser, but I think it might be…
Any thoughts?
Jerry
Noah Tingey avatar
Jerry Gerber · Oct 21, 2025, 06:54 PM
Any thoughts?
Jerry
Just asked the NINA dev. He says that all device polling is indeed affected by that same setting.
If your mount behaves normally with a 2-second polling interval (and only logs warnings in NINA), I would definitely try lowering it again. At least for one night to see if that fixes things. It should actually speed up a lot of actions in NINA, so you might find that your whole sequence is much snappier.
Jerry Gerber avatar
Noah Tingey · Oct 21, 2025, 07:04 PM
Any thoughts?
Jerry
I think you’re right Noah. I am going to lower it again to 2 and live with the log warning. It has no affect on slewing, guiding or anything else as far as I can tell.
Ashraf AbuSara avatar
I use 1s exposures for LRGB filters and 3s for my narrowband filters on my TOA-130 at f/7.6. Focus runs about 2.5 minutes each.
I am also perplexed at the suggestion to switch from NINA to Voyager. 10 times faster? I would be shocked if any software out there can run a FF sensor AF routine in 15 seconds.
Jerry Gerber avatar
Ashraf AbuSara · Oct 22, 2025, 02:11 AM
Hi Ashraf,
Everyone’s got their opinions. I love working with NINA and find it to be a superb software program. The person that recommended Voyager thinks the cause of the autofocus taking so long was NINA, but this is not correct, there was a setting I changed that caused the issue.
I fixed my focuser issues. The best advice I got on this thread by Kevin and Rick is to use AF after temperature change (1c) instead of HFR and this is reducing the frequency of autofocus. The other big change is that I altered the NINA polling frequency to 10”, The default is 2”. I did this because I was getting a warning in the NINA log saying my 10Micron mount wasn’t sending polling data in that amount of time. But I learned (by asking questions) that the 10Micron mounts don’t need to communicate with NINA on that level because of the absolute encoders and the model that I created for it—my 3-5 minute exposures are unguided, the mount’s doing the guiding not NINA or PhD. I brought the polling interval back down to 2”. My autofocus is now completing in about 1.5 minutes, with 4 data points on both sides of the V curve and an HFR of 2.38 pixels, which is pretty good for my 1000mm focal length when the seeing is about 1.09 arcseconds. I may try lowering the step size a little to get a few more data points if I see a problem, but so far so good.
John Hayes avatar
Arun H · Oct 21, 2025, 04:21 PM
That’s not the real question. I check and adjust focus my system every 6 seconds or so and I see focus drift all the time and sometimes it happens on a pretty short time scale. The real question is: How do you keep focus within the depth of focus for your particular system under varying environmental conditions. The chart below shows how to compute the thermal sensitivity for a Cassegrain type system using (for example) an aluminum OTA structure.
📷 Cassegrain Thermal Stability with Temperature 2-19-19.jpgCassegrain Thermal Stability with Temperature 2-19-19.jpgThe chart below show a computation of the temperature sensitivity for various telescopes using both the known CTE for the OTA and the dn/dT values for refractor objectives. The calculation uses a conservative measurement of the maximum rate of environmental temperature drift that I measured at my site in Oregon. Obviously the more stable the environment, the less focus will drift but these are reasonable starting points to see what works best at your own site.
📷 List of Telescope Sensitivity to Temp 2-19-19.jpgList of Telescope Sensitivity to Temp 2-19-19.jpgNone of these numbers take into account any mechanical flexure that may affect focus changes due to the changing load on the OTA structure as the telescope tracks. That is often not an insignificant effect; although in most cases, it will be slowly varying.
The fastest variation in focus is most often due to seeing itself. The strongest aberration that seeing induces is normally tilt but I’ve seen nights where that’s not the case. Rapid focus variations can be the most significant factor that drives the seeing limit. There are also times when seeing induced focus variation changes “slowly” (<~1 minute) under fairly stable atmospheric conditions as “waves” of index variations slowly roll through the light column.
Here’s a night with superb seeing with a fairly stable focus signal.
📷 image.pngimage.pngHere is what it looks like when the focus signal transitions from being unstable to being much more stable—all due to how the stability of the atmosphere affects the focus term in the wavefront.
📷 image.pngimage.pngClearly, if the atmospheric conditions are very stable, you don’t have to check focus very often but you rarely know what it’s going to do a priori. The trick is to check focus as frequently a possible in a way that it doesn’t take any time away from your total imaging time. That’s is the key advantage of ONAG. Focusing is done in real time, while the shutter is open with zero time penalty. ONAG isn’t possible on all systems and in that case, I agree that the best strategy is to use temperature sensing to trigger focusing events. If it requires focusing 20 times in a night, that’s what it takes.
- John
Helpful Insightful Engaging
lunohodov avatar
Jerry Gerber · Oct 22, 2025 at 02:54 AM
Jerry,
How did you come to this conclusion? Is there a formula or guidelines one could use to determine a good HFR value for their optical system?
Clear skies
Jerry Gerber avatar
John Hayes · Oct 22, 2025, 05:33 AM
- John
This makes sense to me John. I am currently experimenting with autofocus using a 1.67c temperature change threshold, using a 1000mm refractor. This corresponds to your chart above, as I notice the autofocus occurring about every 40-45 minutes. The seeing is good tonight, about 1.09”. If on a night where the seeing isn’t so good, I think it would be a good idea to perhaps reduce the temperature threshold to 1.5c or even 1c, but if it’s the seeing that is producing the focusing challenges rather than just the temperature why not autofocus to HFR rather than temperature? I also notice that when I look at tilt data it changes from sub to sub, they’re not large changes, which seems to confirm what you’ve said about seeing affecting tilt.
Jerry Gerber avatar
lunohodov · Oct 22, 2025, 05:42 AM
Jerry,M
Clear skies
There is a formula, but I am not using a formula, I’m basing this on how my system has been performing over the past year and a half or so since I’ve been doing remote imaging. Tonight NINA is reporting the seeing as being about 1.09”. If my HFR is in the range of 2.38 pixels to around 2.85 pixels, based on my experience with my 1000mm refractor, I think that’s about what can be expected. As I continue to learn my system better, I’ll know if I can get better results out of my equipment when the seeing is as good or better than it is tonight. The FWHM is measured in arc-seconds and is a measurement of seeing conditions, the HFR is is the measurement of a particular optical/mechanical system and will always be different for each system and each focal length.
lunohodov avatar
Thank you for the clarification, Jerry.
Recently, I revisited my focusing routine and noticed that changing NINA’s autofocus noise reduction setting resulted in a different HFR reading. While it makes sense when you think about it, I was surprised at first. This is something to keep in mind.
Clear skies
Arun H avatar
John Hayes:
Hi John,
I am confused about something. I completely get how seeing will influence measured HFR values. But - will refocusing change that? Meaning, isn't it true that the best HFR value will still be at the point of optical focus which is unaffected by seeing? Or is the optical focus point somehow influenced by seeing?
I used your formula (which equates half depth of critical focus to length change due to thermal affects) simplified for a refractor. Assuming that L for a refractor is simply the focal length (the actual value of the length of the OTA can be used instead), for the OP's case of a f/7.6 refractor of 1000mm f/l, I get allowed DT of 3 degrees C for a wavelength of 500nm. Your formula and its dependence of (F/#)^2, because CFZ is larger for larger F/#s, is why I said his OTA should be more forgiving. That is consistent with your graph. If he truly needs to focus based on temperature change 20 times a night, the atmospheric variation in temperature would be unrealistic. Assuming the change was all in one direction through the night, you'd need a 60 C temperature change!!!
Incidentally, I did realize something, that I need to change my refocus frequency. For my case, I have it set at 3C, whereas it should be set to 2C.
Your equations and graphs are, as usual, providing great insight. Fast scopes and/or long scopes will be much more sensitive to temperature variation on account of the smaller depth of the CFZ, the longer length resulting in larger values of Delta L for a given temperature change, or both.
TiffsAndAstro avatar
Jerry Gerber:
Jerry,M
Clear skies
Is there a plugin or something for Nina that can calculate seeing,?
Focuser trouble when NINA starts
Hello, I’m new to NINA (was using ASIAIR before), I was able to connect and set everything and to perform two nights of imaging. Here is my issue, the last two times I turned all my equipment on, my focus was lost (I mean stars wereway out of focus, ...
Focuser connection issues may explain slow autofocus performance with NINA.
Sep 3, 2025
Autofocusing from a Remote Site
Hello, Does NINA have a log of error messages? I ran autofocus, stars look fine, but at the very end I got the message saying autofocus couldn't complete. It seems to have completed. What should I do when I get this message? I'm using the Ses...
Electronic focusing speed optimization; directly addresses focusing routine duration.
Aug 6, 2024
TOA-130 temperature / focus management strategies?
Finally have my TOA-130 up and running at DSP remote in New Mexico. TOA-130 is definitely very sensitive to changes in temperature. I have a moonlight nightcrawler 3.5" installed on it. I was looking at my imaging history last night in NINA, and...
Direct experience with Moonlight NightCrawler focuser at remote sites.
Dec 29, 2024
