Soft images from remote observatory - clouds or dew on optics?
4 replies148 views
Roger Renberg avatar
I use a remote observatory, so I couldn’t physically check. But my images were very soft tonight. Maybe someone could tell me if this is clouds or dew somewhere on the optical train? if so, is it the sensor or on the lens?
Thanks
Roger
More like thin cirrus clouds
Scott Badger avatar
Fog? And if fog, then probably dew too, on the lens.
Scott
ItsMeAstro avatar
I have a very interesting lecture about Dew, Frost, causes and solutions. Also discussed are some similar issues as mentioned with soft objects !
https://www.youtube.com/live/5Wp2bkz85-o
SonnyE avatar
Roger Renberg · Oct 16, 2025, 10:37 PM
Thanks
Roger
I have to wonder why you would be using a remote observatory and not have any sort of monitoring camera.
Shucks I use one on mine and it is only ~75 feet out back. (wireless WiFi) Solar.)
Do you monitor the weather at the location?
No signal in my new filters
Hello, I have recently bought a new set of filters. Antlia V-Series LRGB and 7nm HSO. I recently installed everything and had "first light" last night from my DIY remote observatory. When I remoted in to the PC and started imaging I noticed...
Remote observatory imaging problems; soft images could indicate optical obstruction.
Aug 17, 2025
One dew solution that may not be for everyone.
I live in coastal Southern California and I have always struggled with dew prevention on my 10” DIY newt… I’ve tried dewshields, dew heaters, burning sage, shamans, you name it. Dewshields are ungainly and huge. Dew heaters would generally overheat t...
Dew prevention techniques relevant to diagnosing soft images from optical train issues.
Nov 28, 2025
Do you know what is wrong with my image capture?
I've been troubleshooting my imaging on the Lobster Claw Nebula over a few sessions now. I have an artifact that I'm stumped as the the problem. 1. Collimation has been verified to be good 2. Tilt has been verified to be little or none 3. Foc...
Troubleshooting image capture problems similar to author's soft image issue.
Aug 15, 2025
