Windows remote app on iPad
14 replies303 views
Celestron2 avatar
I’ve recently switched to a Mele mini pc and NINA to run my astrophotography setup and connect remotely via the windows remote app on my laptop. I know it’s also possible to use the Windows remote app on an iPad which could be very helpful when I go outside to check the focus.
Has anyone had any experience with the remote app on iPad? Are there any pitfalls to be aware of?
Also, I would need to upgrade my current iPad to be able to install the remote app (it’s quite old and incompatible with iPad OS 17 which is required). Is there any noticeable difference in performance when running the remote app between the base model iPad and the ones with the M-series chips?
David Jones avatar
No iPad experience, but I’ve been using Intel/M-series MacBooks and even my iPhone with the prior and current Windows Remote App for a few years without much issue. On the mount side I’ve had Q2 and Q3s from Mele. I do commit to fixed IP address on the Mele side as I don’t always have the best of luck with Network Discovery finding the unit by name. The only other “challenge” I experience with the Mele Windows update - sometimes I find it necessary to hardwire into the Mele following an update. I find https://www.amazon.com/dp/B0D59RS829?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_2&th=1 (Innoview Portable Monitor ~$110) does the trick with a USB-C and the touchscreen is a reasonable interface.
Daniel Cimbora avatar
Not what you asked but I switched from Windows RD to Google Remote Desktop when installed at HCRO. Works GREAT on iPhone and iPad.
Gordon Pegue avatar
Before I retired from IT a couple years ago, I was responsible for (among a bunch of other things) remote management of firewalls, switches, servers, packet-based radio system and dispatch PC’s for a LE organization.
My remote access tool of choice was RoyalTS. They make a version that runs on iOS and costs next to nothing for the full version. Perhaps the free version is a better fit for you. It’s limited to IIRC 8 remote connection definitions.
I found RoyalTS to be far more powerful AND user friendly than the admittedly cludgy (strictly my opinion here) Remote Desktop.
Heres a link
Note that you need nothing more than the app and a rudimentary knowledge of how RDP works (what TCP port is exposed in windows for example) to build a connection definition to your remote device.
Dave Ek avatar
I have a newer iPad and have run the Windows app a few times to remote into a Windows mini PC. It worked fine, although I prefer to use another PC for remote access instead of the iPad. This mainly because of the screen size of the iPad and the lack of keyboard and mouse. But why not just try it out and see what happens?
Quinn Groessl avatar
I use it with an iphone. It can be hit or miss. Some nights it works perfectly. Other nights it disconnects so often that I give up and just walk back and forth to my indoor PC while polar aligning. No idea why because my set up is always pretty much in the same spot, and nothing changes except for maybe windows updates. I also use Google Remote Desktop, but find that to be a bit more laggy. Still usable though.
Your second question, I don’t think the more powerful iPads are necessary. If all I was going to use my iPad for was remoting in to my Astro setups, I would get the cheapest one that is capable.
lunohodov avatar
Hello,
I’m exclusively using the setup you mention (with one addition):
  • iPad Air (4th generation)
  • Windows App
  • N.I.N.A. on a MeLe Mini PC running Windows 10
  • TP-Link N300 Nano router
From my experience, the above setup is incredibly reliable. The PC connects promptly after boot, and the connection remains stable, with low latency and an excellent WiFi range. Additionally, the entire setup is portable.
Using Mount’s Build-In WiFi
Initially, I used my mount’s WiFi network (iOptron GEM28). However, the disconnects were frequent and subsequent reconnects were slow. There was a high network latency which caused the UI to “freeze” or feel laggy at best.
I won’t recommend it.
Using a Separate Router
After I switched to a mini router, all issues went away. The TP-Link N300 is amazing:
  • It fits within a small palm and weights nothing.
  • Strong signal range (30-50 meters)
  • USB-powered (cable included)
  • Rock-solid connection, zero latency issues
  • Low cost ~20 EUR
Here a couple of things:
  • Setup the Windows App to connect using an IP. I had trouble connecting using PC’s name.
  • Configure the router to assign a specific IP address to the PC. Otherwise, every time the PC joins the network, it might receive a different IP address. In such cases, you’ll need to look up the new IP address and update the connection information within the Windows App, which is inconvenient.
  • Install WifiMan. In case of trouble, scan the network and check if the PC is connected and what its IP is.
  • Consider powering the router from a separate source. I noticed longer initial connection times when powering from PC USB.
Blue/Black Screen of Death (BSOD)
Remote desktop requires running services. If Windows crashes (BSOD), you can't connect—and with no monitor, you won't know why.
One time I went to a dark site. Mid-session I fiddled with the task bar icons and suddenly lost connection. After an hour spent in fruitless restarts, I packed up and took the 1.5 hour drive back home. When I plugged the PC to a monitor, I found that I’ve accidentally turned off the WiFi. I facepalmed and turned it back on. With a monitor, I'd have spotted it instantly.
The good news is that starting with iPadOS 17, one can use an iPad as an external screen. Since then, I bring a mini keyboard and a mouse to dark sites. It works at home, but I’m yet to need it on the field.
Useful accessories
I hope this helps. Let me know if you have more questions.
Clear skies
Edit: Added links to the accessories I use.
Well Written Helpful Engaging Supportive
BlackStarsAstro avatar
I Have used windows app (formerly known as remote desktop) for 2 years on Ipad over my home network. Never had an issue. With Ipad sized screen make sure you have a mouse. Not a lot of space for sausage fingers.
AstroGadac avatar
I use the windows remote app on my Ipad, works flawlessly. I switch between touch screen mode and virtual mouse mode depending on if I need to be accurate or not. Its really easy to do.
Though I have starded to use the Touch And Stars android app more and more these days when I am at home but on the field where I need to edit the advanced sequencer on the fly I use the Ipad.
Concise
Jim Raskett avatar
I used Windows Remote Desktop app on my iphone and ipad for quite awhile before I saw a similar post were someone really liked Chrome Remote Desktop.
I now only use the Windows Remote Desktop app as a backup. I now use Chrome Remote Desktop exclusively.
The biggest thing that i like about CRD is that even though it is touch activated, I can very simply expand the screen and easily and accurately make selections.
I have yet to find a way to log into Windows on my remote pc (Mele Overclock 3c) with CRD without entering my password. This feature is easy to set up in Windows Remote Desktop.
Both apps are free and to me, the best way to compare is to try each one and swap back and forth until you have found which application works best for you.
woodmutt avatar
I use SpaceDesk Viewer specifically for this purpose—polar aligning or making adjustments at the scope. Works well except that it can be tricky selecting and clicking on tiny icons on the screen. Can be used simultaneously with Team Viewer, which I use on my PC inside to run the scope.
Jon Woodhead avatar
I routinely use a pretty ancient iPad (2017 iPad Pro) to control one setup using NINA running on a Mele mini-PC (Windows remote app) while simultaneously running other scope via ASIAir. It is all pretty seamless to transition between the two wireless networks - after I implemented the Mele wireless hotspot startup hack described by Cuiv
https://www.youtube.com/watch?v=JkpoHGUyQLo
I have not seen any hardware limitations using such a ‘basic’ iPad, the main issue is just the limited screen real-estate when using NINA and all its windows. You definitely need a stylus rather than trying to use your fingers!
ValeryL avatar
Celestron2 · Oct 14, 2025, 10:24 PM
Hello,
I just switched from using Asiair to mini pc with NINA (Rbfocus Gaius s2), and I use an Ipad with remote desktop app (Windows app) for the polar alignment (also for sequence programming from my sofa and controlling aquisition in my bed xD)
It works just fine! You would probably want to use an ipad keyboard with a touchpad (apple ones are very expensive but they are great) because NINA is full of small buttons and using the tactile screen would be a pain in the …
I have the ipadpro from last year but i don’t think it makes any difference, the most restrictive factor would be the miniPC anyway.
Another thing I changed, I don’t use the miniPC own wifi network, now i connect my mini PC to my home wifi network (from my internet box), it does not change any config for remote desktop but it has several advantages : I have a better signal from everywhere, and all equipment (mini PC, house PC, ipad) have internet access while using remote desktop.
Stelios_Stergiou avatar
I’m Imaging like this for 2 years, the first with iPad air3 (2019) and now with Air 6 13’’ M2. If is there any issues its probably the network and the ip connection of the pc and not the windows app on the iPad. Make sure you have good connection I ended using a mesh WiFi and all my problems solved… best accessory for the iPad is a keyboard with mouse tab it will make your life easier
Celestron2 avatar
Thanks very much for the advice! On a different note, has anyone had any experience using Affinity/Photoshop for processing the captured data? Would a base A16 iPad be capable of handling this? I’m thinking it could be effective for processing on-the-go and wondering making masks might be made a bit easier with an iPad and pencil rather than with a laptop trackpad.
Note: I’d still use the pc/my laptop for stacking and running plugins like Star Xterminator/Noise Xterminator as I don’t think they can be installed on iPad yet. Looks like the macros can be installed in Affinity so most of the workflow is potentially doable.
Remote Imaging - which mini-pc
Hi everyone. I apologize if the topic has already been discussed in the past, but I haven't found any recent posts on it and given that mini-PCs evolve quickly I think it's not wrong to open a new post. I'm thinking of buying a new PC for...
Windows remote app demonstrates remote connection method for mini PC setups.
Jun 24, 2024
Recommendations for Windows tablet with good battery life for astronomy rig control.
Currently, I drive to remote sites and run one setup with a Mele computer controlling the rig. I use an iPad Mini via Windows App to control everything. I am assembling a second rig so I can run two setups simultaneously, but I really do not want to ...
Windows remote app solution directly addresses author's need for tablet control alternative.
Mar 2, 2026
Windows 11 switch and Astronomy
Hello everyone, so far, I was very reluctant to switch over my desktop and my laptop from Windows 10 to Windows 11. Now that the support for Windows 10 finally comes to an end, I will have to make a decision! Are there any known issues with astro-sof...
Windows 11 switch relevant to mini PC astrophotography setup considerations.
Sep 3, 2025
Mini PC crashing caused scope to hit mount
Looking for some help/advice please, on how to understand what caused my mini pc to crash & also how to stop the mount continuing to drive in the event of a pc hanging-up.. Following a recent imaging session I awoke to find my mount (an EQ6-R) ha...
Mini PC stability issues directly relevant to author's Mele mini PC setup.
26 days ago
Complete Windows 11 astrophotography PC build guide from scratch
🛰️ Windows 11 Astro Imaging PC Full Build Guide From Bare Metal to Stable Observatory Appliance This guide describes a complete rebuild from scratch of a Windows 11 PC used exclusively for astrophotography. The goal is not convenience. The goal is st...
Windows 11 astrophotography PC build guide applicable to author's system setup.
Dec 18, 2025
