2600 MMPRO COOLING TEMPERATURE ISSUE
4 replies82 views
Jandro.rm avatar
Hi i have two 2600mmpro. I have some issues with one of them because I can’t reach the temperature I’m waiting for. It gets stuck along the way, even with the cooler at 100%. Example: with 20º in my backyard is not possible reach to -10 and if i want to -5º the cooler gets high to 85 or 90%. Is there any problem with the camera? maybe the fan?
I wouldn’t hurt to open it up and have a look.
Oscar Pilhoefer avatar
I had a similar problem.  Check and make sure your fan is running.  Mine stopped and overheated my camera to the point it damaged the CMOS chip.
Well Written Concise
Tim Ray avatar
Verify correct voltage at the plug for the camera in question…
Jandro.rm avatar
Hi. thanks for your response. The power is a zwo 12 dc adapter only for the camera. The fan is working but i don´t know if the speed´s correct
[Need help] cooler system
I have a problem with my camera's cooling system, every time I try to plug in the cable the fan starts for two seconds and then turns off and then starts again etc.. is it a power problem, maybe I'm using the wrong adapter?
Cooling system malfunction directly relevant to fan cycling issue.
Feb 5, 2025
Mysterious star trailing solved: a cautionary tale of fan vibration with a fan cooled (especially ZWO) camera.
Suddenly after no problems with star shapes, the next night out they were just terrible! Below I show a gif comparing two 2 hr stacks, one with the good stars, and the next with elongated stars. In this example the distortion was vertical. But later ...
Fan issues causing temperature regulation problems similar to your cooler malfunction.
Nov 18, 2025
QHY600 not reaching target temperature
Hello all. During my last imaging session I lowered my sensor temp to -15c, the ambient temperature was 0c. . Tonight I tried to take darks in my basement which has a temperature of 13c. The camera would only reach about -10c, a difference of only 23...
Similar cooling temperature issue with different camera model, troubleshooting approach applicable.
Dec 4, 2024
One dew solution that may not be for everyone.
I live in coastal Southern California and I have always struggled with dew prevention on my 10” DIY newt… I’ve tried dewshields, dew heaters, burning sage, shamans, you name it. Dewshields are ungainly and huge. Dew heaters would generally overheat t...
Dew prevention and cooling equipment troubleshooting relevant to temperature management issues.
Nov 28, 2025
