Going back to 135mm
21 replies568 views
YingtianZZZ avatar
Hi Guys!
Getting board with setting up every time, I’m recently considering getting a Samyang 135mm F2 to use with my Nikon D810 Ha mod one as an easy use and wide-field scope, as it has wider field and sounds to be much faster than my FMA 180 pro. However it’s just a thought. I have too many 300-500mm scopes and several longer scopes and running a 800mm Newt at remote observatory, but FMA180 was my smallest one, so I had no experience with these wider imaging. Will anyone recommend this lens, for its high speed, or wider from 180mm to 135mm, or it will not be a great upgrade and I can save the $350?
Yingtian
There is no comparison, the 135mm wins hands down.
Spacetime Pictures avatar
There is a new Sigma 135mm F1.4 for full frame; it is quite expensive, but judging by the reviews of its sibling the 105mm f1.4, it could stand as a promising lens for astrophotography.
Not @ f/1.4 and not for a FF either. The 135mm f/2 is the odd one out there.
Icharuss avatar
andrea tasselli · Oct 9, 2025, 08:49 AM
Why is that?
One is a f/2 67.5mm clear aperture lens with potentially no significant aberrations on APS-C format (at f/2!) the other one is a tiny refractor of 40mm aperture @f/4.5, that is nearly two stops of aperture more for the Samyang. I mean my guiders are bigger than that!
YingtianZZZ avatar
andrea tasselli · Oct 9, 2025, 06:13 PM
Thank you for the explanation! My only concern is there are too few objects for that wide, only thing I can think about is Orion with part of Barnard ring, and rho ophiuchi area. I’ve looked into these areas many times with longer FL, do you think the fast but wider one still worth?
If you skies are good  (dark) enough then absolutely, but you have to like the wide views. Use AB's search engine and there should be plenty of examples to what can be achieved with such a fast, wide lens.
Tim Ray avatar
While I don’t have any of your scopes as to compare to a Samyang/Ronikon 135, I do own a Samyang 135. Love that lens. I have several images on my page with it. Those images were well received with likes from the AB community. I have used it with all of my cameras and delivers great data. I don’t know if I would want it as my only portable rig, however, I take it with me every time I travel to image. There is always a widefield target to be captured. I also notice interesting things in a wide field, usually because those items are out of the FOV of captures taken with a “traditional” FL for the target…
CS, Tim
Arnie avatar
YingtianZZZ · Oct 9, 2025, 09:49 PM
Not true at all! I have the 135mm lens attached to my ZWO ASI6200MM camera at a remote site in New Mexico and I have a list of targets that may possibly keep me busy the rest of my life! In addition to Barnard’s Loop and Rho Oph that you already mention, Sh2-264 (Lamda Orionis Nebula) fits perfectly in that field of view. There are also wide-field shots of M 42, M 31, the Pleiades and the California Nebula. Then there is the Veil Nebula and the North American Nebula. There are huge swaths of nebulosity throughout all of Cygnus that make beautiful compositions. How about the whole Garnet Star Nebula in a single shot? The Rosette Nebula. Even wide-field views of things like the Cocoon Nebula take on a whole new look when you include the vast swaths of dust that surround it. Wide-field views of the Aquila Rift. There are tons of Lynds’ Bright Nebulae and Lynds’ Dark Nebulae that are too large to fit in a smaller FOV. How about a wide-field view of the Witch Head Nebula that includes all of the surrounding H-alpha?
I’ve just started exploring some of the really faint supernova remnants out there, many of which fill the frame of the 135mm/ASI6200 combination.
Another thing I like to do is get a wide-field view of a particular area, identify the small objects within it, and then zoom in on those with a larger scope. The side-by-side views of the wide-field and the smaller objects really gives a nice sense of where all the smaller objects are in the sky in relation to one another.
There is tons of stuff out there perfectly suited to this lens. I can send you my observing lists privately if you like.
Clear skies,
Arnie
kmcloughlin avatar
I’ll echo what Arnie said (and btw Arnie, I’d love to get a copy of your target list too). I’ve posted a few photos with this rig; the most recent had the Garnet Star Nebula (IC 1396), the Flying Bat and the Giant Squid in one frame. It’s such a treat to be able to image the Rho Oph nebulosity and many other huge objects without having to create a mosaic; and the f/2.0 ratio puts a lot of faint objects within reach (Spaghetti Nebula, anyone?).
If you buy this lens, I highly recommend you also get the ringset custom designed for it by Astrodymium (available from Agena); it’s inexpensive, greatly simplifies the process of attaching it to a mount, and provides an attachment and belt drive for a ZWO autofocuser.
Arnie avatar
I used to use a belt drive for this lens but when it would get really cold it would slip and my focusing runs were less accurate. I’ve since switched to a solid split gear (can a split gear be called solid? 🤣) from Rigel Systems that is driven directly by a spur gear on a small stepper motor attached to the same mounting plate to which the camera and lens is attached. Much more solid, less backlash and consistent focusing no matter what the temperature. If I were to do it again I would probably 3D print a custom ring and spur gear and use an Arduino-driven stepper motor, but I had this lying around from when I was using a 180mm Nikon lens and it fit the 135mm Roki perfectly!
Tim Ray avatar
I downloaded a setup for the Samyang 135 from Thingiverse. Had my friend 3D printing it up and have been very happy with this setup. No off axis weight to contend with.
Eric Benedetti avatar
Arnie · Oct 13, 2025, 11:28 PM
I’ll offer the inverse experience, I’ve used a few different 3D printed ring/spur gear setups on both the 135mm and Redcat 51 scope, IMO they are awful for automated focusing (and I say that as someone who 3d prints a fair bit of astro stuff). During the cold winters here the plastic would contract and that introduces a lot of backlash into the focusing routine making autofocus runs extremely unreliable with low reproducibility. During the warm summers the plastic would expand and deform causing binding and autofocus failures altogether. If you use high quality belts and a solid mounting of the EAF (or whatever autofocuser) then the belt is far more accurate with zero backlash. Switching from a ring/gear system to a belt system improved my AF routines on both the Samyang 135mm and Redcat 51 all year round and with the 135mm at f2 you need very precise, reproducible autofocus since the focal plane is so tiny.
Arnie avatar
Wow! What a difference! I guess I’ll stick to the commercially produced gears, then.
I wonder if the outer surface of the 135mm where the belt rides has a more robust texture than my old 180mm Nikon. It was so frustrating having the belt slip on that lens in the cold weather that before I switched to the nFocus I actually put a dab of caulk on the barrel of the lens and pressed the belt down into it!
Adam Drake avatar
I switched from the Astrodymium system to the 3D-printed solution Tim is using, and prefer it over the former since putting the EAF below the lens makes it much easier to balance.
Interesting observation about the focus ring contracting in the colder months to come. I had not considered that and would be interested in sourcing a shorter belt to use instead.
Well Written Insightful Respectful Concise Engaging
Adam Drake · Oct 16, 2025, 02:26 PM
I agree with putting the EAF below the lens, should be more stable as well. Another thing to consider with temperature/environment, is if you happen to leave your gear outside. For a while during the summers I’d just leave our gear out, uncovered, when temps were mild and I knew it’d be clear with no risk. But the UV damaged some 3D printed parts, including one of the gear rings (can’t remember if it was for the Redcat51 or the Samyang), over time. I really noticed the AF routines failing with the gear ring at the start of one winter when temps would still be in the 50’s-60’s during the day, but drop into the 30’s at night. For several nights I remember banging my head wondering what the heck was going on with the AF curves, they all looked so bad or would just fail. Finally I went out to our observatory to watch the equipment while the AF was running and sure enough, the whole thing was just binding up. Luckily I had a belt and cog lying around so I ripped off the geared rings and threw the belt on, no problems after that.
For the belt, unfortunately I had to order 3-4 different ones to get one that fit just right, they’re not expensive, but it is a little hassle. What I would do now is get a piece of string, get the rig fully assembled, then run the string around the lens and down/around the cog on the EAF to get a somewhat close number for the length needed. This is where I got the belts from before, based on my order history I bought 280mm, 320mm, 300mm, and 308mm. But I cant remember which were for the Samyang and which were for the Redcat.
https://a.co/d/9Wn4wM6
Arnie · Oct 16, 2025, 01:54 AM
The surface of the 135mm will depend on which version of the lens you buy, I currently have a Cine version which has a smooth outer surface EXCEPT for a toothed ring at one point. The toothed ring makes it easier to incorporate a belt with teeth, but you still have to print something to make sure the belt doesn’t slide off that toothed ring. The previous versions of the 135mm I had were just the normal version, which has a tacky rubber sleeve on the outside with some indentations across the width, that was good enough to give the belt some bite and not slip during autofocus if you got the belt tight enough. I imagine some strong double sided tape or some caulk would also be more than sufficient in the case of lenses with very smooth surfaces, otherwise I’d design and 3d print a toothed ring to attach to the lens to help.
Tim Ray avatar
My 3D parts were printed using PETG. Imaging from Missouri with 90 degree summer to -20 winter nights have never had an issue with slippage during focus, etc. This system has focus motor belt tension adjustment if you have shrinkage or expansion for the belt… but never an issue with the 3D cog ring on lens…
Printed with an Ender 3 3D Printer
CS Tim
Keith Hanssen avatar
I get vignetting with my Canon 135mm f/2 and Canon R even at f/4
Arnie avatar
Eric Benedetti · Oct 16, 2025, 06:11 PM
That was exactly the problem I was having. My older Nikon 180mm had the rubber sleeve with very shallow indentations. To keep the belt from slipping when it got cold I had to snug it so tight that I was causing tilt in the image. Adding a dab of caulk allowed the belt to be a little looser but then backlash was a problem. The Rigel Systems nSTEP fixed both problems. In a rare stroke of serendipity, the gear for the Nikon 180mm lens also fit the Roki 135mm (at least the Nikon version).
Arnie avatar
Keith Hanssen · Oct 17, 2025, 03:39 AM
I’m more familiar with Nikon cameras than Canon. Is the Canon R a full frame sensor or crop sensor? With my full frame D750 or ZWO ASI6200 I get significant vignetting but flat field calibration frames take care of the problem. It’s much less of a problem with my crop sensor D5500 or QHY268. Stopping down from f/2 to f/4 helps with star shape and other optical aberrations, but to my knowledge, stopping down won’t help with vignetting.
Well Written Helpful Respectful
Canon 5D + Samyang 135mm. Worth it in the long run?
My main setup is "finished" and Im planning on maybe buy a smaller widefield kit that I can use while my main rig is doing its thing. I have a Canon 5D and a 14mm widefield lens, but im thinking on maybe add a samyang/Rokinon 135mm lens + a...
Author considering 135mm lens; discusses Samyang 135mm F2 practical experience.
Jul 21, 2024
Thoughts on the Samyang 135mm f1.8?
Hello everybody, so ive been slowly putting together a wide field rig for Milky Way shots, but I also would like to have a 135mm lens that I can pair up with my Sony a7ii astro modified camera. now I thought about going with the famous rokinon 135mm ...
Direct experience with Samyang 135mm F2 lens for astrophotography applications.
Jul 28, 2024
14" Celestron EdgeHD versus 12.5" Planewave CDK
Hi, I have an opportunity to buy one of these scopes used in my area. Does anyone with experience with either have comments on why one would be better than the other? The EDGE is similar in focal length and speed when used with a reducer. The OTA wei...
Discusses telescope focal length and speed considerations for imaging.
Nov 25, 2024
