Help with dust on QHY600M sensor after cleaning attempt
10 replies95 views
Robert Lowenthal avatar
Seeking advice regarding dust on QHY600M sensor and sensor window.
This is one of those “The enemy of good is better” stories. I am truly embarrassed and feeling very sad.
Several days ago I noticed ice crystals on my QHY600M sensor window. So I used the desiccant tube to dry out the sensor chamber. Afterwards, I noticed a dark blob in lights and flats. It was large, irregular, and very dark, so I figured it was most likely the black foam that is present inside the sensor chamber to (ironically) keep dust out of the chamber when the desiccant tube is placed. I opened the sensor chamber and discovered that the black foam was, in fact, brittle and crumbling. So I removed the foam (I’m using a small piece of PEC-PAD in the desiccant tube instead). I cleaned the sensor, sensor window (outside and inside surfaces) and reassembled. Now, instead of one large spot I have dozens of smaller, lighter spots. I tried several times and this Lum Flat represents the best I can get. Unfortunately, even though it looks spotless immediately after cleaning (looking through magnified loops), dust accumulates on the sensor and window while I’m reassembling everything. The smaller, darker spots are likely on the sensor. The medium sized spots are on the sensor window, and the few large spots are on the filter.
From looking at the flat, does it appear that the dust is significant enough to affect images and should I send the camera to QHYCCD to be cleaned?
Thank you,
Robert
Well Written Helpful Insightful Respectful Engaging
I think the first question is, as always, does it calibrate properly?
Tony Gondola · Oct 8, 2025 at 11:06 PM
Good question, Tony. I just finished “cleaning” it today and haven’t had the opportunity to take any lights. I’m wondering if it’s worth testing or does it look so bad that I should just send it in?
In these cases the best course of action is to have it cleaned by a professional, you don't have a dust-free chamber and the attendant apparel. Or directly to QHY and bear the annoyance. This stuff is most likely to move around quite unpredictably.
bigCatAstro avatar
andrea tasselli · Oct 8, 2025, 11:36 PM
Totally agree here. Given your situation, with that foam being brittle and breaking, I would have it serviced and cleaned at a dedicated full-service camera store (if there’s one in your city/town). They would have the proper cleanroom, equipment, and supplies to handle the issue. If you don’t, I would send it back to QHY for service and cleaning.
Well Written Concise Supportive
Robert Lowenthal · Oct 8, 2025, 11:15 PM
Tony Gondola · Oct 9, 2025, 02:22 AM
It’s certainly worth a try. If it does calibrate you’ll can be a bit more selective about when you send it in.
andrea tasselli · Oct 8, 2025 at 11:36 PM
You’re right about the particles moving around. If they moved after a meridian flip, calibration flats would be useless.
bigCatAstro avatar
Tony Gondola · Oct 9, 2025 at 02:23 AM
I worry that the brittle foam has probably fragmented in other hard to reach places and may randomly show up in different places on the flats. I suppose they could calibrate out, but they may move freely and unpredictably.
bigCatAstro · Oct 9, 2025 at 02:45 AM
I agree. I think my best option is to send it to QHYCCD for cleaning.
bigCatAstro · Oct 9, 2025, 02:45 AM
They might or they might not, probably depends on handling more then anything else.
Cleaning sensor (player one poseidon C pro (imx571))
Hi, I encounter some issue with my player one Poseidon C pro. It’s a telescope on a pier on western Europe weather. I have some leaks on the sensor (never opened). See picture attached. What are you recommendation? Is that possible to remove the fron...
Sensor cleaning advice after failed cleaning attempt; directly applicable situation.
9 days ago
Review of the QHY5III678M for ground-based satellite imaging
This is a review that shows the performance of the QHY5III678M planetary camera for ground-based imaging of satellites, I will showcase the specifications of the camera and example images I have taken with it of several satellites. I also want to kin...
Relevant as it discusses QHY camera sensor issues and maintenance concerns.
Jan 12, 2026
Need help with Flat calibration
Hi guys, I’m in a big problem for two months and couldn’t find a solution. In my remote setup of Skywatcher-250 Quattro, I’m consisting getting dust donuts in low height areas, maybe light polluted sky area. I know that easiest way is clean the filte...
Discusses dust problems and flat calibration issues with camera sensors.
Feb 17, 2026
ZWO ASI 2600MC producing doughnut artifact in center of images
Hello everyone, I have had a ZWO ASI 2600MC for about a year now, and I have noticed that all the images I have taken with it since then have a strange artifact in them. Basically, it looks like a doughnut in the center of the image. This is particul...
Documents sensor artifacts similar to dust contamination problems author experienced.
Nov 27, 2025
Mysterious star trailing solved: a cautionary tale of fan vibration with a fan cooled (especially ZWO) camera.
Suddenly after no problems with star shapes, the next night out they were just terrible! Below I show a gif comparing two 2 hr stacks, one with the good stars, and the next with elongated stars. In this example the distortion was vertical. But later ...
Shares troubleshooting experience with camera equipment performance issues and solutions.
Nov 18, 2025
