Bayer-like checkered pattern on mono subs
4 replies208 views
André Moleiro avatar
Hi everyone. This started happening about a week ago: I have this checkered, debayer-like pattern all around my subs, even though I’m using the ASI1600MM, which is a monochromatic camera. The pattern is gone if I zoom in or out a little bit. It’s still bad enough to disrupt my workflow, since I like to analyze and select my subs before integration, and also because it’s very annoying needing to change zoom levels at every step of processing.
I have heard the feedback that this might be just an optical illusion, and the pattern is not there. However I didn’t have this issue a couple of days ago, and now I have. So I want to fix it regardless.
I recorded a little video with a demo of the issue, and how it affects my workflow. Any ideas what could be happening? Thanks in advance!
Well written Engaging
Mikołaj Wadowski avatar
Looks like Moiré patterns to me. I saw similar artifacts when dealing with more noisy subs and that's likely why you're only seeing it in some frames and not others - their SNR is lower.
They shouldn't be visible in the stacked result.
Well written Insightful Concise
John Hayes avatar
Something has indeed changed in your camera. The pattern that you are seeing is a moire pattern between the pixels in your display and a high spatial frequency periodic error in your images. That’s why the patten is only visible at certain magnification values. I suspect that if you zoom in to where you can just start to see the pixels in the image, you’ll see a very faint checkerboard-like pattern. In the days of interlaced cameras, this short of error was called an “odd-even” error and if was the result of tiny gain differences in the amplifiers that handled the even and odd rows (and/or columns). I’m not sure why this might be happening in a CMOS camera but it may have to do with the way that the electronics in the camera handles the signal. I don’t know if this will work but you might try to add a small offset of say, 40 ADU, to see if that makes a difference. The problem may be caused by a small change in the bias level so adding an offset might make a difference. If that doesn’t help, you may have to go back to ZWO to see what they have to say.
There are ways to salvage your data. The Canon debanding tool in PI applied to both the columns and rows should fix it. Convolving with a very small kernel should also work but that will also very slightly blur the image. It shouldn’t be very hard to write a Pixel Math expression that would fix it as well.
John Hayes · Oct 7, 2025, 03:44 PM
This is the most thoughtful and concise response I have seen to this problem anywhere. Now I have a clear course of action. Thank you, John!
Ani Shastry avatar
I had a similar but even more exacerbated issue, which turned out to be an issue with the components on the PCB on which the sensor is mounted on. I sent the camera back to ZWO and they had it fixed and shipped back within a few days. They never identified which specific component was the issue, but replaced the entire PCB and it has been flawless since.
My camera was under warranty so this was rather easy, but reach out to ZWO directly and see what they think.
Ani
Whats wrong with my DSLR?
Hi everyone, I bought full spectrum canon 450d and I can’t use it with objectives. Every time I shoot with objectives I got image like this one. Please tell me what’s wrong with my camera or how to fix it. Thanks for advices.
Both involve unexpected visual patterns appearing in camera images during astrophotography.
Jan 10, 2024
Debayering issue in moon video processing?
Hi everyone, I’m trying to process an AVI video of the lunar surface captured with an ASI678MC at 1080p, with a Bayer pattern that should be RGGB. I’m using the classic PIPP -> Autostakkert -> Registax workflow, which usually works perfectly fo...
Bayer pattern debayering issues with ASI camera AVI files similar to yours.
Nov 17, 2024
Bluish patch appearing in stretched images despite unchanged optical setup
This started happening about two weeks ago, and I haven’t made any changes to the optical train. Setup: ZWO 2400MC + EdgeHD 11 at f/10 (no reducer). I’ve been taking flats the same way as always, but for some reason this issue is now appearing and I’...
Checkered pattern troubleshooting may help diagnose the bluish patch artifact issue.
Dec 21, 2025
Help finding source of light reflections
Any idea? It happens on long subs (>2min) and using all filters except Luminance, for some reason. It’s a Carbonstar RC6 with a ToupTek camera, filter wheel, OAG, and a manual rotator. Thanks in advance for your help.
Checkered pattern on mono subs addresses imaging artifacts similar to reported issue.
Apr 19, 2025
Creeping dust artifacts, or.. ?
My R filter is producing some really bizarre artifacts, hopefully highlighted the below gif. A couple observations: Only the R filter is having this issueFilters are in a FWIssue doesn't show up in my R flats, or darks Below is a Blink output of ...
Checkered pattern artifacts in mono camera subs similar to described issue.
Dec 25, 2023
