RC collimation
Tony GondolaTobiasz
35 replies978 views
I am going through the process of collimating a GSO/Skywatcher style RC. When I first got it, it was slightly out so I decided to line everything up on the bench using a Cheshire and laser. At that point everything looked perfect through the Cheshire. First look at the stars and I had a field full of comets, my bench alignment made things far worse then it was to begin with. After a LOT of undirected tweaking of both the primary and secondary I was able to get to this:
📷 star test 3.jpgstar test 3.jpgThere’s still some on-axis coma with the P dot not centered. The the off axis astigmatism is also unbalanced. I think my next move is as follows:
  1. With a star centered, adjust the primary to remove the remaining on axis coma.
  2. Balance the off axis astig. with adjustments of the secondary.
  3. Repeat if needed.
    Am I on the right track here?
Off-axis astigmatism means you're shifted from the 2-mirror axis somewhat. You need to act on the focuser instead. the order of operations is in reality the centering of focuser with the primary first and then the centering of the secondary to the primary second.
These versions of the rc have the focuser attached to the back plate without a tilt adjustment that’s separate from the primary. I can get a tilt plate but I’d like to get things closer before I worry about that.
That should be you first worry, not the last!
Matthew Proulx avatar
Tony Gondola · Oct 4, 2025, 08:24 PM
What do you think about this approach:
https://www.deepskyinstruments.com/truerc/docs/DSI_Collimation_Procedure_Ver_1.0.pdf
This is the approach one should use once a decent collimation is achieved with tools. Tools only get you so far. This method is the icing on the cake. Once you learn this you will understand which mirror causes what kind of aberration and it will be easier to solve and collimate in the future should you have to.
In short : Main mirror to adjust coma of star (you want full illumination of the out of focus star)
Secondary to balance the corners of the image.
Then check main again, repeat if needed.
Helpful Insightful Concise
It might work but you'd have to iterate between secondary and primary adjustments so a bit time consuming. And in case of significant tilt in the focuser its collimation would only be partially right. Should things change on the focuser side you'll be out of collimation once again.
Well, the only choice I have for today is to try and get it as close as I can using the above method. This is a learning project for me because If I go with a larger aperture in future it will probably be an RC.
Matthew Proulx · Oct 4, 2025, 08:31 PM
That’s pretty much the plan for tonight. Moonlight will make it easier to find my Allen wrenches when I drop them :)
Tobiasz avatar
For the daylight collimation I use the same tools as you with the help of my eyes and some distance to the back of the scope. What I mean is described within the collimation guide of Tommy Nawratil's blogpost about the GSO RC. (LINK to the image, Source: Blogpost)
You have to make sure your laser is collimated as well. So when you align your laser against the secondary your laser dots should be spot on but you should also see the center mark reflection on the crosshair plate of your laser. Only then you can expect your focuser plane and your secondary to be in line mechanically. Everything else means tilt in your focuser and/or your laser.
After that I align the primary mirror like it is described in the image of Tommy above. Repeat as often as needed until your eyes cannot make out any errors anymore.
This way you should achieve a 90-95% collimation (IF your focuser sits tight and is stable enough) and only very minimal changes should be required under the stars.
Concentrate on an on-axis star first. The poisson spot should be in the center already and only the secondary shadow of the defocused star should show slight displacement. Fix it with the primary collimation screws and then check the “balance” of your abberations in your field. The bigger the sensor the better you can see differences in your field (I use a Canon EOS 6D for that).
All your astigmatic stars should point straight to the center like in the guide from DSI. You may see it better with defocused stars.
Repeat until you're happy.
Good luck!
Tobiasz · Oct 4, 2025, 09:32 PM
Good luck!
That’s a good article, I’ve never seen the stand back and look approach to adjusting the secondary before but I love it’s simplicity. I’ll give that look early tonight and see how far off I really am. I’m a little confused when he talks about aligning the spider vanes though. What exactly is he doing there?
Tobiasz avatar
When you're standing back you will see the spider vanes in the reflection of the secondary mirror, too. If your primary is aligned well, they should form a perfect X.
Well written Concise
Tobiasz · Oct 4, 2025, 09:53 PM
ahhh, ok. Not offset from each other.
Tobiasz avatar
Exactly.
Rajat Kumar avatar
Tony Gondola · Oct 4, 2025, 04:19 PM
Hi Tony
I’ll follow your thread because I’m going through a similar experience.
Earlier this month, I tried the Cheshire + laser + DSI method and was able to reach this level: 📷 NGC281-300x300-session_1_session_2_session_3_session_4_session_5.jpgNGC281-300x300-session_1_session_2_session_3_session_4_session_5.jpg
(This image is a stack of 300 images)
I’m not sure whether the issue is with collimation or backspacing. The stars in the corners seem to be radiating inward, yet according to the DSI method, the image appears balanced—or at least that’s what I think. I should mention that I have installed a tilt plate, though I haven’t made any adjustments to it yet.
Last week, I travelled with the scope to a Bortle 2 site (a rough, hilly drive with the scope kept on the back seat—EAF and camera still attached, resting between two pillows 😄). Things seem to have worsened since then—the corners have degraded noticeably. 📷 2025-10-01_03-02-42__-9.80_180.00s_0012.jpg2025-10-01_03-02-42__-9.80_180.00s_0012.jpg
(single frame). I did not try to tweak collimation because of the bad weather.
I have not followed the DSI method to the hilt. I removed the On-Axis Coma by adjusting the primary mirror following the DSI method. But after that, I simply adjusted the secondary mirror and centred the dot. This was more because I did not want to waste a night, and the subs looked more or less “balanced” to me.
About the tilt plate: I have not made any adjustment yet to the tilt plate itself. However, my tilt improved quite a bit after installing the plate. The aberration inspector in NINA showed an improvement in the tilt measurement.
One resource to share: https://lambermont.dyndns.org/astro/rc/
It collates all the articles on RC collimation on the internet. Ignore if you have already seen this.
Do share if you manage to fix the collimation. I will get on to it when the clouds move away.
Clear skies!
Tobiasz avatar
A good collimation does not translate into a perfect flat field. The mirror design will still suffer from field curvature and astigmatism. If I look at your profile, you’re using a 6 inch RC with an APS-C camera and without a flattener right? Then it is expected to see pointy stars off-axis with such a big sensor.
You have to crop in or use an additional flattener.
Well written Helpful Insightful Concise
Rajat Kumar avatar
Tobiasz · Oct 5, 2025, 08:01 AM
That’s what I even thought that I may need an additional flattener to correct the corners. However, the source of confusion was also the NINA Aberration Inspector (Hocus Focus), as it suggested that my backspacing might be off by 170+ microns. Do you think that assessment is correct?
Tobiasz avatar
Rajat Kumar · Oct 5, 2025, 08:23 AM
Without a flattener you don’t have to keep track of correct “backspacing” as there are no corrective optics (like lenses) in the light path. This would only apply if you use a flattener (109mm for the 2 inch, 89,5mm backfocus for the 3 inch version).
Another topic would be mirror spacing, but you will need a Ronchi eyepiece for that and not NINA.
Rajat Kumar avatar
Tobiasz · Oct 5, 2025, 08:39 AM
Noted. Even I thought the same. Thanks!
Ok, update from my end.
I tried the rough alignment method of standing back a meter and centering up. On the stars that once again resulted in comet like stars across the field. At that point I tried to get to a round donut by adjusting the primary. I could get it mostly round and not completely and the P dot was all the way to one side. Then I moved on to the secondary and managed to get the P dot centered. That resulted in a slightly oval donut at center field and no matter what I did with the primary I couldn’t make it round. On close inspection of the star images at center of field they were clearly astigmatic, focusing to a cross not a dot. Here’s an image of where I ended up:
📷 0000_IR_SNAPSHOT_2025-10-04_21-06-51_10.00s.jpg0000_IR_SNAPSHOT_2025-10-04_21-06-51_10.00s.jpgI did the visual one meter back test this morning and the center dot was shifted far off center and the secondary was tilted so much as to be clearly oval.
The fact that the usual alignment techniques won’t work, combined with the reality to I have to put the secondary so far out of alignment to even get close to a normal image, tells me that something is very much out of alignment from the very beginning.
I wonder if the best approach might be to tighten all the collimation bolts on the secondary and primary to the stops in the hops that at least mechanically, everything is close to where it should be. The only other thing I can think to do is a complete teardown to look for an issue. The OTA is used so who knows what’s been done to it. I knew this would be challenging and I thought I understood it, now I’m not so sure.
Tobiasz avatar
Resetting the collimation bolts can work to get something like an “inital” position of everything.
How tight are your bolts screwed in? Once I managed to tighten the secondary screws so much that I even had astigmatic stars on axis.
One of them is very tight. I will get that one backed off a bit and then reset everything mechanically. Back to the bench we go.
John Hayes avatar
Tobiasz · Oct 5, 2025 at 08:39 AM
That’s mostly right; however, you still want the BWD to be roughly correct to avoid introducing SA, although SA varies VERY slowly with spacing changes. As for the field curvature, you can introduce a small focus bias to deal with the field curvature. I can’t recall the best zone but if you focus around the 50% zone, it will introduce an insignificant amount of defocus at the center but it will reduce the field astigmatism by a noticeable amount. Then, BXT acts like a “digital” flattener to remove the residuals. I’m planning to remove the flattener in my ASA600 RC to eliminate halos and this is how I’ll operate going forward.
- John
OK, I’ve pulled both mirrors back to the stops, went out one turn on everything and did a visual alignment. After going through that, I think I know where I went wrong. My best guess is that I initially visually centered the secondary center ring while the primary was really far off. That was indicated by seeing one side of the primary baffle coming into view as I centered the dot and ring in the secondary. At that point the secondary looked right but in fact the mirrors were very much askew. The secondary had to take on an extreme angle to compensate for the primary. I’ll know for sure with my next star test. Right now it looks perfect in the Cheshire and with the 1 meter look test.
Tobiasz avatar
Good luck!
Why are my stars shaped like flat discs???
If I hadn’t seen it, I wouldn’t believe it was possible. A little backstory: For various reasons, I’ve struggled with collimation on my Meade SN8. Finally feeling I got it down, I went out 3 nights ago and got the best collimation I’ve ever had. This...
RC collimation — author successfully collimated scope; RC collimation process relevant.
Jul 27, 2024
My first six months with the Sharpstar 15028HNT-AL - A trial by fire!
So I bought my Sharpstar 15028HNT-AL back in September last year, based off a few users brilliant images, and the spec-sheet alone… Lets face it, it’s hard to argue with F/2.8 when you’re primarily a narrowband deep sky imager. Having owned a few new...
Collimation sensitivity relevant to fast F/2.8 Newtonian telescope maintenance.
Mar 4, 2026
Secondary mirror tilted in its holder
With this post I want to draw attention to a problem I found with my GSO 10" Truss RC. During collimation I found that when I align the optical axes of the focusser, secondary and primary mirror, the mechanical alignment as it can be seen in a C...
RC collimation — directly addresses GSO RC collimation issues and alignment problems.
Jun 24, 2024
Hotech Advanced CT Laser Collimator - What is causing this?
Greetings, I purchased the Hotech CT Collimator and have had a difficult time getting good results with it. I have watched the instruction videos multiple times over and I think I understand the concept well, but my collimation still suffers. My use ...
RC collimation — discusses collimation techniques relevant to author's collimation difficulties.
May 2, 2024
Diffraction Pattern Question
So I’ve acquired a small Sharpstar 15028hnt F/2.8 newt and been playing with it to see if it’s truly capable of delivering or working across a full frame sensor. It’s been a couple weeks of precise bench collimation, star testing, tilting, backfocus ...
RC collimation experience may inform newt collimation troubleshooting approaches.
Aug 27, 2025
