Circular artifact in WBPP processed image, suspect flat frame issue
7 replies105 views
Catalin Iordache avatar
Hi everyone,
I’m seeing a circular artifact in my image after running WBPP. I used dark frames and the attached master flat. The artifact closely matches the flat frame, so I suspect it may be an issue with my flats. If that’s the case, I can reshoot a new set.
For this image, this issue occurs on all of my filters.
Any suggestions would be appreciated.
📷 Screenshot 2025-09-29 at 16.37.37.pngScreenshot 2025-09-29 at 16.37.37.png📷 Screenshot 2025-09-29 at 16.38.15.pngScreenshot 2025-09-29 at 16.38.15.png
Well written
You have severe vignetting, that's all.
Hey Andrea! Thanks for replying. Yes, I do have some vignetting, but I would expect flat frames to fix that. Here is another picture that shows better the ring/gradient I am writing about. I am not sure if this is because my flat frames are bad or maybe my dark frames have an issue. I already applied DBE and Gradient Correction, but the result is still bad.
📷 Screenshot 2025-09-29 at 22.36.26.pngScreenshot 2025-09-29 at 22.36.26.png
Flats correct up to a point. If the loss is too high they are never going to replace the actual signal. Have you actually measured the light loss at the corners?
Brian Puhl avatar
Flats should correct most vignette. If not, then i’d start chasing a light leak. First step i’d recommend is using bias instead of darks. If that doesn't alleviate the issue, the start shining a flashlight around your scope while looping exposures.
@andrea tasselli @Brian Puhl Thank you for comments. I did re-shoot my flats last night. I forgot to move the focuser close to focus position while acquiring the initial batch of flats. The problem is now gone.
Well written Helpful Respectful Concise
Rostokko avatar
Catalin Iordache · Sep 30, 2025, 11:28 AM
The problem is not gone.
…or did you mean to type “now gone”?
Before:Screenshot 2025-09-30 at 15.09.24.pngAfter:Screenshot 2025-09-30 at 15.09.34.png
Issue with flat frames
Hello everyone, I need some advice about flats. A few months ago, I switched to a monochrome camera with an IMX571 sensor (ToupTek ATR2600M), paired with a ToupTek filter wheel and Antlia LRGB filters. As my main telescope, I use an Askar 103 APO. I ...
Flat frame issue causing artifacts; similar equipment and processing workflow.
May 6, 2025
Strange persistent structure/artifact in old (2025) subs — what could it be?
Hi everyone, Quick (and kind of funny) question. I revisited some March 2025 data of the Dolphin Head Nebula—only 13 × 180s frames. A few days ago I resumed the project and decided to register/align those 2025 subs to my new 2026 data so I could comp...
Circular artifact matches flat frame; similar calibration issue investigation.
Jan 24, 2026
Help with odd master lights after WBPP
I have some simple RGB masters of NGC891 from about a month ago that ended up with an odd gradient on the green and red channel masters. I can't see anything in the individual frames that would point to this and the darks and flats look normal. T...
Circular artifact in WBPP processed image, suspect flat frame issue — flat frame issues cause artifacts
Dec 12, 2023
PixInsight WBPP - dust motes/donut still not cleaned with flats
Hello, I am still seeing dust motes/donut shaped spots even after calibrating with flats. I tried few exposures with flats but no improvement. I use dark, bias and flat calibration frames and default wbpp settings. from the attached screenshot, you c...
Circular artifact in WBPP image suspected flat frame issue
Sep 30, 2025
50 images from my 15 year old camera Orion Nebula processing issues, Can it be improved?
📷 Wrong Flats I believe.png📷 Sequator Try.png📷 Random (Unstacked).png📷 Hoping for Details.png📷 Blurred Histogram.png📷 Sequator Autostreched.png📷 Wrong Flats I believe.png📷 Sequator Try.png50 images from my 15 year old camera
Flat frame issues causing artifacts in processed images; directly relevant to troubleshooting.
Feb 3, 2026
