Abdul Thomas Jnr avatar
Hi. I’m just wondering which filter thickness to get between Baader High Speed 6.5mm or 3.5mm Narrow Band CMOS Optimised. Set up will be the Rasa 8 and Zwo 294mm pro camera. I know the 3.5mn are more expensive but I just want the best for this setup. The guy from the astro shop recommended the 6.5mm but it looks like most people are using the 3.5mm with the Rasa. Thanks in advance
The Rasa is at F2, won't the F3 filter makes a difference?
You won't see much of a difference in terms of out-of-band shift between the nominal f/2.3 and an actual f/2.
Okay. So is the 6.5mm at F2 not good enough?
The 6.5nm filters are good enough if high-speed versions otherwise the out-of-band shift is too much to make them worthwhile for a f/2 telescope with a CO of 35% or worse (e.g., a RASA). If you want the absolute best of contrast and your skies aren't that dark then the more expensive variants are your best choice, if you are willing to spend that much (I wouldn't but that's me).
Okay thank you for your time. I will get the 6.5mm high speed ones. Those are the ones I was gonna get anyway
Baader >F3.4 filter on the Rasa 8
Hi. I was thinking about buying the Baader Cmos narrowband high speed filter F2 for my rasa 8. But someone is selling the Baader next grade ones F3.4. I’m just wondering if the F3.4 will work just as fine as the F2 filter on the Rasa. Thanks in advan...
Discusses Baader High Speed filter thickness options for Rasa 8 setup.
Sep 17, 2025
Focuser for RASA 11V2
Hi folks, I'm setting up a RASA 11V2 and wondering what autofcusers are working for you. Thanks in advance for your input. Dave
Discusses Baader filters for RASA 8; relevant for autofocuser compatibility considerations.
May 8, 2025
Moving on from RASA 8
Hi folks! Up until now I have been using a Rasa 8 and love it! After some initial struggles with tilt, it ended up being a well tuned photon sucking machine. But! I have come to yearn for more! Especially a bit more FL, even at the cost of some speed...
Author upgrading from Rasa 8; filter thickness choice relevant to new setup.
Jan 25, 2024
Which camera do you suggest ?
Hi I have recently purchased an 11” rasa v2. I am wondering which camera would be best to use with it. I have a zwo2600MC and a zwo2600mm DUO. I have a photon cage on order to help dial in tilt and back focus. I have purchased Baader f2 Ha, Su, and O...
Discusses Baader filter thickness options relevant to author's filter selection decision.
Jul 11, 2025
Advice on duo-band filter selection for astrophotography setup
Hi, I am looking to expand my astrophotography setup with a duo-band filter. Well, possibly two depend on how the pricing goes. I’m looking to have my feel-pinions validated and possibly a correction from someone who knows what they’re talking about....
Discusses filter selection for astrophotography setup with similar equipment considerations.
Aug 31, 2025
