Weird Artifacts when shooting with SCT
Zhaoyu XubigCatAstroandrea tasselliJohn Tucker
45 replies552 views
Zhaoyu Xu avatar
Hi, I’ve noticed I get a weird border artifacts on all sides of the picture when shooting with my SCT. I did not have this problem when I use the same camera/filter on a refractor. Anyone know what is causing this and how to fix it? I’ve shot multiple targets with the SCT and all seems to have this problem
The telescope is Celestron 925 Edge HD and the camera is ASI2600MC
bigCatAstro avatar
Zhaoyu Xu · Sep 22, 2025, 04:33 PM
What do your flats look like? It appears, to me at least, that there’s something going on with the camera glass like dewing or fogging.
Well Written Respectful Concise Engaging
Zhaoyu Xu avatar
bigCatAstro · Sep 22, 2025, 04:48 PM
Here is one of the flats. I’ve used NINA‘s flat wizard to take it. I do also have a dew heater strap running at around 50% on the front of SCT. Do I also need one at the mirror at the back? Should I increase it to 100%? I also had the anti dew running on the ASI2600 as well
📷 FlatWizard_2025-09-15_20-59-31_S_-9.80_4.70s_0003.jpgFlatWizard_2025-09-15_20-59-31_S_-9.80_4.70s_0003.jpg
Bad flat-fielding, that's all. It could be a number of things so please describe in detail the steps you take to calibrate your lights.
Well Written Concise
bigCatAstro avatar
Zhaoyu Xu · Sep 22, 2025, 05:01 PM
This flat doesn’t look right, too bright and not capturing the problems with the imaging train. It should be just bright enough to illuminate the dust motes and other imperfections.
Zhaoyu Xu avatar
andrea tasselli · Sep 22, 2025, 05:09 PM
I just take 50 Flats with NINA flat wizard and 50 Dark Flats and with 50 Dark Frames, I run WBPP in pixinsight with default values. I do the exact same thing with my refractors and the same camera, the artifacts doesn’t appear.
As for flat field, do I need to decrease the amount of light from the light pad?
Zhaoyu Xu avatar
bigCatAstro · Sep 22, 2025, 05:13 PM
In this case, I need to decrease the power of the light pad then? But wouldn’t the Flat wizard from NINA auto calculate the exposure time so that it would not be as illuminated?
bigCatAstro avatar
Zhaoyu Xu · Sep 22, 2025, 05:15 PM
I would start there, lowering the brightness, since the flat looks basically white on my processing laptop. I never use NINA auto calculate for flats since it gives me really odd numbers. I take an iterative approach to finding the right brightness—granted I am using a DSD lid that I can control the brightness steps.
Zhaoyu Xu avatar
bigCatAstro · Sep 22, 2025, 05:18 PM
So the border artifact is related the flats then not really issue with dew on the corrector lens or the mirror?
Zhaoyu Xu:
*WBPP is where it can go wrong. Redo the calibration as a single process (ImageCalibration, remembering to disable dark optimization and use no bias master) , not in WBPP, and post the outcome here. In NINA check what is the average histogram level you have set (got to be between 50% to 20% of the dynamic range) check also that you have the same gain and offsets between calibration and light frames. Makes no difference the exact level as long it is below the  90% threshold for most sensors (and above 10%). Pi doesn't care as long as you are in the linear range, If all checks out then you have a reflection problem.
bigCatAstro avatar
Zhaoyu Xu · Sep 22, 2025, 05:21 PM
I would start with squaring away the flats first and if that doesn’t solve it, go to the next step. There may have been some fogging/dewing at some point in time and now it’s just a part of the imaging train. If proper flats are taken it should correct them out of the image as @andrea tasselli also suggested.
Derek Mellen avatar
A few people in my astronomy club have that telescope. I don’t know if you are using a reducer. They get dew on the reducer and need to use a dew heater strip on the reducer. It does look like your flats could be off.
Zhaoyu Xu avatar
Derek Mellen · Sep 22, 2025, 07:17 PM
yes I do have the reducer, but I get the same issue without the reducer. So it might not be the issue for now
John Tucker avatar
Agree with the comments above that your flats are overexposed. The underlying hardware issue is likely something to do with condensation on your camera sensor, as the fogging effect creates a rectangular border around the edges of the image. Everything else in your imaging train is round and would produce a typical vignetting pattern with a circular “hole” of higher exposure in the middle of the image.
You might check to be sure that your sensor isn’t exposed to ambient air and try cooling the sensor less or more slowly.
Zhaoyu Xu avatar
John Tucker · Sep 23, 2025, 10:39 AM
but if its the sensor being fogged up, would that also fog up in a different telescope? I used the same camera on my refractors and it was fine. I do have the ASI camera anti dew on in both cases. Since I use asi air, I don’t think there is a way to control the cooling speed and I set the temp to -10C.
Thomas avatar
andrea tasselli · Sep 22, 2025, 05:27 PM
Zhaoyu Xu:
Agree with the WBPP comment here. I routinely find that for whatever reason, calibration via WBPP does not work for me. As long as I do my calibration before using WBPP, everything comes out right. I only load calibrated frames into WBPP and let it do everything else.
Concise
John Tucker avatar
Zhaoyu Xu · Sep 23, 2025, 01:49 PM
I see your point but its hard to come up with an alternative explanation for the rectangular pattern. Perhaps different ambient humidity on this occasion? Or connection of the camera through a plastic connector that conducts heat less well than a metal one used with your other telescopes?
bigCatAstro avatar
I think the answer really has to do with your flats. The flats should be exposed uniquely for each differing imaging train and filters. I’ve never found NINA’s flats wizard to work exactly as needed for exposing flats. For my set-up, it produces a flat that is either over or under exposed. I’ve had to iteratively increase or decrease brightness on my lid until I reached the desired peak range.
A side note, an easy visual check would be to disconnect the camera and look at the senor window under light, I’m going to guess that you’ll see that “fogging” pattern under the glass. If you’re flats are calibrated right, they should get rid of the artifacts.
Zhaoyu Xu avatar
bigCatAstro · Sep 23, 2025, 02:30 PM
Ok, I checked the sensor and it was all looking normal. The question now I have is that if I were to take my flats not right after the imaging session, but say the next day when my scope is indoors, would the flat be able to solve the issue?
Just post somewhere so that it can be downloaded all the relevant files, such as master dark, master flat and some example of light frames and we'll look into it.
bigCatAstro avatar
Zhaoyu Xu · Sep 23, 2025, 04:29 PM
Probably not, but it might work. I take flats after each imaging target session, so others can weigh in if trying your idea of taking flats indoors after the session will work.
Typically you should take your flats during the session (before or after imaging) or in the morning with a diffused sky flat. If you’re going to use a wall for flats, really they should be done either before or after the imaging session. Likewise, you don’t want to move the imaging train (or as little as possible) before taking the flats. Again, I use a Deep Sky Dad automated flat panel lid, so I have NINA take my flats at the end of each target session.
John Tucker avatar
bigCatAstro · Sep 23, 2025, 05:30 PM
I mean, if the “fogged” area is rectangular, it pretty much has to be these sensor, right? Because there is no other rectangular orifice in the light path. I don’t think checking it the next day rules out the possibility of condensation on the sensor the previous night, as it will evaporate in warmer temperatures.
The flats are “the issue” in the sense that properly exposed flats should correct for the underlying problem, which is fogging of the sensor.
I apologize if this comment strayed into the “who is right” territory, the forums here are mostly blissfully free of that sort of thing. I’m just thinking that understanding the problem is the best way to avoid it in the future. There has been some discussion of this issue on that other, unspeakable astronomy forum…. https://www.cloudynights.com/topic/843215-do-cooled-cameras-dew-up/
bigCatAstro avatar
John Tucker · Sep 23, 2025 at 05:47 PM
Sure, these points all make sense and probably get closer to a root cause.
John Tucker avatar
sorry duplicate post
John Tucker:
*You can't correct for "fogging" of the sensor, assuming it means either frost or dew forming on the sensor and it is virtually impossible to have dew forming on the camera window with modern sensors/cameras.
DeepSNR - Artifacts or Stars?
So I've tried to jump on the DeepSNR bandwagon but I keep getting weird results. I don't know if it's showing me the next level of dim stars in my image which were hidden by noise or if it's creating artifacts. I've tried using th...
Discusses artifact identification in astronomical images, relevant to DeepSNR artifact concerns.
Aug 4, 2024
What do you do when PHD2 sees ghosts?
I have been chasing a problem in my guiding for several hours yesterday night and tonight. I use an OAG with a SCT (C8); PHD2 (managed by NINA) is the brain. The experienced problem was that, for a specific target, guiding would work well “in most ca...
SCT optical issues with ASI2600MC; border artifacts may relate to guiding problems.
Thoughts on my collimation of 9.25 sct
SCT border artifacts directly applicable to source image problems.
Sep 23, 2025
SCT general optical alignment
I removed my 9.25 EDGE corrector plate retaining ring today to clean the inside edge where some fibers or lint had collected. When I did, I noticed the corrector plate is nowhere near the center of the OTA. There are four set screws that hold the cor...
SCT alignment and optical corrections directly relevant to border artifact diagnosis.
9 days ago
Need Filter Recommendations for Lunar Photography
I'm reaching out to my fellow Lunar photographers or anyone with good knowledge of Lunar Photography. My question is: What is a good filter for photographing the Moon? What part of the light spectrum is wanted and unwanted to achieve the best res...
SCT artifacts troubleshooting applicable to author's previous C9.25 experience.
Mar 13, 2025
