How to handle 'bloaty' filter on bright stars?
3 replies93 views
John Stone avatar
I have an Esprit 100ED, an ASI2600mm Pro with Antlia Dark LRGB filters.
The problem I'm having is that on bright stars I'm getting uneven star "bloat" so what happens that I get really funky colors on those large star halos after SPCC.
I've triple checked the focus offset between the L,R,G,B filters (NINA Filter Offset Calculator 10x iterations). And I've confirmed the offsets with manual focus runs close in time to each other, but still I get uneven halos.
For example
Red:
Green:
Blue:
That fat blue halo is causing this star's halo's color to be completely wrong.
Any ideas?
Get a B filter with a cut-off above 420nm.
John Stone avatar
Looks to be about 390nm or 395nm FWHM.  Do you really think the 30nm difference will make a difference?
Yes
Star shape error
Star halos are prolonged backward. What is causing this, and how to fix it.
Star bloating on bright stars; similar optical/imaging artifact issue.
May 28, 2025
Halos with DeepSky RGB filters
Hi there, I just bought a set of Astronomik Deep Sky RGB filters so I can use them with a new Poseidon M PRO (switching to MONO from my ASI294MC PRO after two years). I've noticed that with no filter or with my current Astronomik L2 filter, there...
Discusses bloaty/halo artifacts with mono camera and LRGB filters; directly relevant.
Feb 12, 2024
Fuzzy halos around bright stars with directional orientation
I’ve noticed that I typically end up with fuzzy halos around bright stars, for instance in the bright stars of Orion’s Belt: 📷 Orion's Belt https://app.astrobin.com/i/182vjp/ They seem to have an orientation to them- near the center of frame, the bri...
Addresses similar bright star halo issues; may provide troubleshooting insights.
Feb 17, 2026
